25mm to 28mm road tire
Bikes: Giant Contend SL 1 Disc
Quoted: 155 Post(s)
Liked 78 Times
So changed out the tires on my new Contend SL1 Giant bike...Man the bike should have came this way in my opinion. I ran 95-100lbs in my 25mm, and just a tad less in the 28s at 95lbs max.
The drive is so much smoother and less harsher on my ass and hands! The bike feels more planted and secure at 25-35mph as well.
I hear that 25mm tires and smaller go faster downhill...but also that very few people are elite enough to notice the difference....
Can I have some opinions and possible explanations of why the 28s feel so much nicer?>
thanks yall,
JAG
thanks yall,
JAG
Likes For Harumph:
If you upgraded to a suppler and higher-performance tire, this could also have a lot to do with it. If you have two tires of the same size and you pump them to the same pressure, but one is much stiffer than the other, the less-stiff tire will tend to be more compliant on road irregularities.
Quoted: 155 Post(s)
Liked 78 Times
Wider tires tend to be taller, so they have more "travel" as a suspension mechanism, allowing you to pump them squishier without increasing the risk of bottom-outs. They also tend to give a better-behaved and less-squirmy ride than a narrower tire, if both are pumped to the same degree of compliance.
JAG
Quoted: 20810 Post(s)
Liked 9,456 Times
Liked 9,456 Times
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
My bike came from the factory with 25mm tires. I switched to 28mm. Definite improvement in comfort, handling, and speed. I really would like 32mm but the rear wheel tire doesn't have enough clearance for the frame, so I'm stuck with 28mm. ( 32mm will fit on the front but lightly brushes up against the frame so I'm stuck with 28 there too.
Likes For BengalCat:
Quoted: 663 Post(s)
Liked 496 Times
There are numerous charts with recommendations on the web for various tire widths and carrying capacity. I've been using this one with good results. https://www.google.com/imgres?imgurl...DYAyUQ9QEILjAA
Quoted: 155 Post(s)
Liked 78 Times
There are numerous charts with recommendations on the web for various tire widths and carrying capacity. I've been using this one with good results. https://www.google.com/imgres?imgurl=https://janheine.files.wordpress.com/2010/10/bertopresschart.jpg&imgrefurl=https://janheine.wordpress.com/2016/03/09/tire-pressure-take-home/&h=459&w=1000&tbnid=yV3XNwExjl-QBM:&q=bicycle+tire+pressure&tbnh=96&tbnw=211&usg=__SSSGZw2fOebkRehDbwjUACEFI6E%3D&vet=10ahUKEwioxpz 3jJDcAhVEI6wKHfDYAyUQ9QEILjAA..i&docid=d6L5iCFXHfeziM&client=firefox-b-1-ab&sa=X&ved=0ahUKEwioxpz3jJDcAhVEI6wKHfDYAyUQ9QEILjAA
The pressure stamped on the tire has a lot more to do with legal issues and a whole lot less to do with performance.
The pure pressure vs weight charts also don't take into account rim width which has a big impact on tire profile. The wider the rim, typically, the higher the tire sits from the rim. The higher it sits from the rim, the more protection it provides to the rim from road defects. The more protection implies you can lower the pressure accordingly. Ride quality improves and to a large degree, speed improves unless you are riding on a track with almost perfectly smooth surfaces.
I've found the charts that Enve provides on their wheels to be pretty good for rim width in general (here's an example). I've also found the guidance that Josh Poertner has given in his "Marginal Gains" podcast to be helpful (Josh is the owner of Silca and formerly the technical director for Zipp). I think it's this podcast where he comes up with some really practical way to get your tire inflation correct. Surprisingly, it's lower - not higher - than you think.
There's also a really interesting article that Josh wrote about the first win of Paris-Roubaix on carbon rims and what went into that. A lot of it has to do with pretty precise understanding and setting of tire pressure. One of the big takeaways from their research was that seemingly small differences in pressure can have big impacts and it became essential to measure it accurately. When they looked at their pumps when results are wildly inconsistent, they found that they had more than a 12psi variance between pumps and that made the difference between results that mattered and broken rims.
So for me, I've found that I need to adjust pressure based on my tire size, rim width and rider weight.
J.
J.
Quoted: 155 Post(s)
Liked 78 Times
J.
J.
JAG
Quoted: 212 Post(s)
Liked 83 Times
thanks yall,
JAG
thanks yall,
JAG
I've been using 28mm tires on my road bike for a couple years now, and see no reason to go back to skull-rattling days of old. A Cannondale Synapse with some forgiving rubber on it is a pleasure to ride. On my commuter I use 32mm Conti GP4Season tires, and love every mile I put on them. They're the only thing between the road and the stiff Cannondale Quick CX frameset.
Frankly, if my road bike could fit 32s, I wouldn't be opposed to putting some 32mm GP5000 tires on it. But, alas, the generation of Synapse I have wouldn't accommodate any tire wider than about 28mm. When the day comes that I decide to upgrade to a newer CF Synapse I'll give strong consideration to 32s (but may end up with 28s anyway, we'll see).
6-4 Titanium
Quoted: 92 Post(s)
Liked 36 Times
I prefer 28mm tires but the vortex can only fit 25s with a thin aftermarket carbon RD mount. Otherwise I agree 28s are great wish my ride can fit them but 25 conti gps are awesome and feel great still and I find a carbon wheel set really helps soak up the bumps as well
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
Tire air volume is proportional to the cross section circle. Area of a circle = pi * radius squared.
3.14 * (25/2)^2
vs
3.14 * (28/2)^2
The 28 has 25% more air volume (!), and a few mm of extra travel.
3.14 * (25/2)^2
vs
3.14 * (28/2)^2
Bikes: Konas: Jake the Snake-Fire Mountain-Zing Supreme, Dew Deluxe,Zone Ltd. (frame, needs parts), Surly Long Haul Trucker, Santana Arriva tandem, Montagues: Paratrooper-Fit, Trek 1200, Bianchi Ocelot, Fantom Cross Uno, Bridgestone 200
Quoted: 108 Post(s)
Liked 227 Times
I ran 23s on my Kona JtS for a few years, and tens of thousands of miles.
Sure it was fast enough, but wow... rough roads really made it all the way through my bones.
I still love the bike, though, and have 700x35 tires on it now. VERY nice. Might be a bit slower than it could be for road rides, but I'll probably go to 28s at some point in the near future.
velo-dilettante
Quoted: 1628 Post(s)
Liked 3,114 Times
run 23's, 25's and 28's on the various bikes. if i'm doing serious paved climbing or a 115+ century ride, prefer the 23's,
if i'm doing any significant portion of the ride on dirt/gravel (10+ miles), i'll take the 25's or 28's. urban rides, prefiero the 25's.
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
J.
Quoted: 874 Post(s)
Liked 2,281 Times
In 2017 I bought an old classic racing bike from a bike mechanic who had set the bike up with 28mm tires. I did the Eroica California ride on that bike (1973 Windsor Pro) when it was still in Paso Robles California. I have been slowly changing all my bikes to wider tires since I got that bike and experienced the ride difference. My Super Mondia allows for the wide 35mm tires that I put on and I love the ride on that bike. Loose sand or gravel on the road are no longer a problem , and , I have scored my quickest Strava time on that bike. Joe
Sophomore Member
Liked 1,057 Times
True, but Armstrong was 170 when he won the World Championships in 1993. He simply rode away from Indurain, Fondriest, Lauritzen, Massen, Riis, Ludwig, and the world's best riders, and they could do absolutely nothing to catch him.
Of course, he was an even better rider after he lost 20 lbs.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
They might get me on the climbs, but I always catch them on the other side.
Quoted: 3375 Post(s)
Liked 5,510 Times
So if you just grow 7", you'll be good.
https://www.procyclingstats.com/rider.php?id=141166
Quoted: 4559 Post(s)
Liked 2,802 Times
My '89 steel road bike has gone from 700x18 to 23 to 25 tires, and I'd be using 28s if they cleared the chainstays. In actual practice the cheap 25s are as fast as my more expensive and lighter 23s on our rough rural chipseal. Lots more comfortable too. I weigh 150 and run 'em around 80-85 psi rear, 70 psi front. I could probably go lower.
If we had mostly smooth asphalt, sure, I'd stick with good quality 23s. But there's no advantage where I ride. Rural chipseal is making gravel and cross bikes more practical, or the bikes designed for the cobbles. I wouldn't buy another traditional road bike. No point now the way our roads are maintained.
For us mere mortals, I haven't seen that size is a big factor among the guys I ride with. We're mostly 50something and older. I look like I'm the fittest but the bigger guys with beer bellies often outlast me beyond 50 miles. I'm only a little faster on climbs, but overall it doesn't help much.
Indurain was always a big guy, even bigger than Merckx, and probably weighs about 200 lbs now although he looks to be in good shape in his 50s. He still rides and climbs the same, like a plow horse chugging along calmly, rarely getting out of the saddle. There are some product placement videos of him on YouTube, but worth watching anyway. Inspiration for bigger and sorta-older guys.
Sophomore Member
Liked 1,057 Times
28mm Panaracer Paselas and Gravel Kings run narrow on my various rims, around 26mm actual. I have several road bikes that won't accept other 28mm tires, but the Panaracers clear fine, but with no room to spare. I've found that these Panaracers are the best tires for frames that won't normally clear other 28's.
