Large platform pedals
Old 07-14-19, 02:56 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
Looking for large platform pedals, here's what I've found so far:
OneUp Composite - 115 x 105mm, 355g, $50
OneUp Aluminum - 115 x 105mm, 355g, $125
Crank Brothers Stamp 3 (large) - 114 x 111mm, 455g, $100
Shimano XT PD-M8040 (m-l) - 115x 110mm, 503g, $100
VP Harrier VP-DH5 - 120 x 109mm*, 370g, $60
* heard claims it wasn't really this big
Any other recommendations?
tyrion is offline
Old 07-14-19, 04:34 PM
prairiepedaler
Bikes: Looking for "the One"
Liked 320 Times in 212 Posts
I was going to try the Harriers at some point. Can't add to the list though (I use these MEC platform pedals, FWIW).
prairiepedaler is offline
Likes For prairiepedaler:
Old 07-14-19, 05:10 PM
Rick
Quoted: 612 Post(s)
Liked 387 Times in 270 Posts
MKS Lambda Pedals.
Item Specifications
  • Weight: 420g
  • Intended Use: Road
  • Material: Aluminum
  • Material (Spindle): Chromoly
  • Pedal Type: Platform
Rick is offline
Likes For Rick:
Old 07-14-19, 05:19 PM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,635 Times in 4,050 Posts
Pedaling innovations 143x95 505g $125
LesterOfPuppets is offline
Likes For LesterOfPuppets:
Old 07-14-19, 05:50 PM
Gconan
Bikes: Norco search xr
Quoted: 198 Post(s)
Liked 146 Times in 90 Posts
Just got finished riding my MTB with the largest platform pedals. Pedaling innovations Catalyst pedals. Catalyst Pedals
Length – 5.6”/ 143 mm
Width – 3.75”/ 95 mm
Thickness – .6”/ 16 mm
Weight – 505 grams per pair
Gconan is offline
Likes For Gconan:
Old 07-15-19, 10:49 AM
Korina
Happy banana slug
Korina's Avatar
Quoted: 1530 Post(s)
Liked 1,527 Times in 915 Posts
iSSi makes some big pedals in colors! I have two pair of small Thumps (soon to be three) and I love them, particularly the slightly concave shape; it really does cradle your foot.
Stomp XL is aluminum and $115:
  • Length: 120mm overall, 102mm pin-to-pin
  • Width: 112.5mm from crank to outside pin, 94.5mm pin-to-pin
  • Concavity: 2mm body, 7.5mm effective (pin-to-body)
  • Flip-able traction pins, 5.5mm or 4.5mm length. 11 per side
  • Full-length chromoly spindle, one bushing (inner) and two sealed bearings (outer)
Thump is nylon with either molded or replaceable pins, $40 and $50 respectively:
  • Tough & durable nylon composite body
  • Chromoly spindles, sealed cartridge bearings and nylon bushings
  • Body: 18.5mm thick with 2.5mm of concavity for great control and pedal feel
  • Platform sizes: 119 x 99mm (standard), 113 x 95mm (small)
  • Available with molded nylon pins for casual rides or replaceable steel pins for greater traction
  • Pin height: 3mm out of the box. Remove the 2mm washer under the pin head to convert to 5mm pin height.
Korina is offline
Likes For Korina:
Old 07-15-19, 01:42 PM
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
Ditto, iSSI pedals. I've been considering those to replace my worn Wellgo and Stolen Brand pedals (both good and cheap, but hard or impossible to service properly). The local REI has a couple of iSSi models that appear to have generous platforms.
canklecat is offline
Likes For canklecat:
Old 07-16-19, 12:56 PM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
If you can find them at a bicycle co-op or Ebay, Shimano Adamas AX pedals have a pretty good platform.
Cheers
Miele Man is offline
Old 07-18-19, 04:30 PM
02Giant
Quoted: 1638 Post(s)
Liked 741 Times in 495 Posts
That is a massive pedal!
nine mile skid on a ten mile ride
02Giant is offline
jaycee74
Hybrid Bicycles
5
04-08-15 05:48 AM
escobar147
Training & Nutrition
10
02-26-13 10:01 AM
flashpacker
Folding Bikes
10
07-30-12 10:00 PM
fmt_biker
Road Cycling
15
09-14-11 04:38 PM
the-odb
Singlespeed & Fixed Gear
9
10-15-10 04:08 PM
