Pay it forward...
#76
DOES ANYBODY WORK WITH A KIDS CHARITY?
You can tell them that you worked uphill 40 miles in both directions to get this running for them...needs minimal work and I missed the cutoff for Denver Kids donations this year. It's a cross between the 1st generation MTB's and dirt bike/BMX. Canti brakes: How cool is that!
Bob H. helped me I.D. this 1988 Schwinn Enduro that was made in Japan by Panasonic. I thought it would be nice to donate to a rugrat. I'll pay for shipping if somebody works with a kids' charity or knows of a needy little guy (Then again, maybe I'm a fool. Most kids would maybe think this is junk...or would they like it??)
#77
Squirrel
52t and 42t Stronglight Crank
Are we still doing this? I've been trying to figure out some of the stuff I have, and I've only been able to figure one out so far. I had to plea for help! Stronglight gave me the lowdown, and said I could quote any and all of it, so I'm just going to post what he said, because it's terrific information! It's quite a sales pitch for a not very special part, but I spent about 3 hours trying to figure out what it is, because there wasn't really markings on it.
It is a lower range Stronglight cotterless crank and I had its twin which indeed came mounted on a mid level early 1980s Peugeot which I had used for many thousands of miles as my commuter bike. I later gave the bike away to a someone in need of similar transportation, so it's probably still in use! The pedal threads would be for standard 9/16" x 20 (not French). And as I recall it also had tattered plastic dust covers which were 22.0 mm (NOT the obsolete Stronglight 23.35 mm) so threaded replacements are easy to fine, or of course simply the plastic push in type, just to keep the the extractor threads clean... and best of all this also means the cranks will accept standard modern crank extractor tool. The square tapered spindle used was the standard 118 mm length, as on most 1970s French double chainring cranks.
You'll notice the outer ring is permanently bonded to the crank arm. Not a good design really, since the ring cannot be replaced, but in this case the chainrings are actually so strong that these would probably last as long as the bike for which they were intended. The inner ring is 122 BCD so that one could be easily replaced with any commonly found Stronglight chainring, and it is usually the smaller rings which will get the most wear... in my case, it never seemed to wear, anyway.
So, nothing fancy about these cranks, but certainly practical and durable and best of all without a lot of the quirks of earlier French threaded crank sets. Depending on the bike these may be used on, they could probably accept a 68 x 115 or 68 x 118 "UN-53" Shimano square tapered cartridge bottom bracket which are still easy to find, inexpensive, and should last also for many tens of thousands of miles.
Unique Vintage Steel
I have a front fork for a very small frame bicycle (50-52cm?). It could use a fresh coat of paint, but it's straight and functional. I'll it out tomorrow for more details for those who may be interested. I may have a suitable box, but a few dollars to help cover shipping would be appreciated.
#80
Bikes: Motobecane Mirage fixed gear, Nashbar Alpha Road 5000, Bianchi Grizzly, Coppi Fiorelli, , Schwinn Trike, , GT All Terra, Old Peugeot, Nishiki 3 speed, Bugatti, Cannondale Black Lightning, Dura All, Bianchi Touring, Bridgestone T700 & more
Edit!!!!!!!!! !!!Gone to Business810!!!
Now lets keep this thing rollin' guys!
After a series of losses on Ebay......I've decided I need some good bike Ju-Ju so I thought I'd revive this thread with a new offering.
~First one to PM me gets it.
~I will ship the 15th of this month at my expense anywhere.
Here ya go! Early Dura Ace brake caliper. With original pads and holder thingies hangin' off of them. I didn't even lose the adjuster barrel thingy! There is some corrosion on the quick release. It also doesn't have the nut on the rear or any washers. Sorry it's just the one caliper.
Good day!
Kelly D
Good day!
Kelly D
#82
From the 'not for your show bike' department, I have a 46 tooth Stronglight 99 chainring (86 bcd) that's a good news/bad news part. I got this in a lot of Stronglight rings a while back, and I don't have a 99 crank. Anyway, the good news is the teeth look like it's never seen a chain. The bad news is there's some serious corrosion on the chainring body, including one of the mounting tabs. Some of the corrosion is deep; this isn't just something you can buff out. But overall, it looks like it would work, and it's an uncommon size in an obsolete bcd.
#83
Villainous
Bikes: Trek 420, Cyclops
Edit: All Gone!
Shimano 6 speed indexed DT shifters. They aren't NOS, but they are functional.
Also, beat up Shimano Light Action rear derailleur and Suntour SR front if anyone wants them for parts, flips, or whatever.
#84
ITM quill stem silver and black bars.i think 11cm and 42. stripped bolt holding the bars. But the bars are held on VERY firmly. Whoever wants them, great. just shipping.
#85
Quoted: 111 Post(s)
Liked 213 Times
Raleigh lugged steel fork, recessed brake, 700c, off of a mid-80's 56cm frame, minty fresh green.
7 inches of tube, 40mm of thread. Threads could be chased, they're rough in a couple spots.
#86
Hey leftthread! Love your avatar! The trillium is one of my favs.....I make a habit of trying to save them from areas being developed (boy they have deep roots/bulbs in my sweet valley soil). First thing to bloom every year in my yard. Love 'em.
#87
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
Being from Puyallup aren't you supposed to only like Daffodils???
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
#88
stringbreaker
Bikes: specialized crossroads hybrid 2006 Raleigh Cadent 2 1971 Schwinn Varsity, 1972 Schwinn Continental, 1977 Schwinn Volare (frame)
Quoted: 9 Post(s)
At one time years ago the big crop was hops then some kind of blight or weevil got to them and ruined that major agri business. A lot of fortunes were made and then lost at that time. Then it was tulips and daffodils. Now we mostly grow warehouses and they ain't pretty at all
(Life is too short to play crappy guitars) 2006 Raleigh Cadent 3.0, 1977 Schwinn Volare, 2010 Windsor tourist. ( I didn't fall , I attacked the floor)
#89
Lanky Lass
East Hill
___________________________________________________
TRY EMPATHY & HAVE LOVE IN YOUR HEART, PERHAPS I'LL SEE YOU ON THE ROAD...
#90
Quoted: 111 Post(s)
Liked 213 Times
Thanks, kpug505. Trillium are supposed to be up here first week in May, but it's snowing right now, so who knows how late they'll be. Fork goes to dannygl.
#91
Lanky Lass
East Hill
#93
^^^ Dang! Very generous! ^^^ Wish it wasn't so huge. Actually I wish I wasn't so short.
#94
Dolce far niente
Quoted: 20 Post(s)
Liked 17 Times
I have an old rear mount generator with front/'rear light. Dirty with some surface rust, needs cleaning and probably repair. Made in Hong Kong, unknown manufacture, probably circa mid-80's.
Probably not worth the postage, but does anyone need this and feel handy enough to bother with it?
"Love is not the dying moan of a distant violin, its the triumphant twang of a bedspring."
S. J. Perelman
S. J. Perelman
#96
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,394 Times
#97
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
I definitely got a use for them. Yeah, I ride Helicomatic. And like them.
Syke
No one in this world, so far as I know and I have searched the records for years, and employed agents to help me has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.
H.L. Mencken, (1926)
Syke
#98
Liked 4,394 Times
#99
OK, I've been cleaning out the basement, so here you go:
One pair of Schwinn marked (Weinmann?) brake levers with suicide levers. These are the quick release levers with the orange anodized quick release mechanism. The levers were removed from a girl's frame Continental. They have some minor scratches but no road rash -- looks like the the kind of dings you get from being knocked around a shed for 30 years. They polished out beautifully, and are very presentable. Sorry, but I do not have the barrel adjusters -- I looked.
I set of steel Schwinn stem shifters. These were removed from the same girl's frame Continental. Condition is very good.
You can have both the shifter and brake levers or pick just one item. PM with your location, and I'll figure out the postage.
First come, first serve.
#100
Quoted: 221 Post(s)
Liked 237 Times
Resurrecting the thread.
Anyone interested in doing this again this year? I have to admit, this thread gave me a lot of enjoyment last Christmas . . . . . . . . and considering that my feelings toward the Christmas (never Holiday) season are curmudgeonly to that point that I always felt that Ebeneezer Scrooge was a bleeding hear liberal, I suppose that's saying something.
Same rules, same intent as last year. And I'm digging through the garage.
Syke
Syke
