Jobst Brandt and how wheels hold load
I was in the bike shop yesterday and I paged through Mr. Brandt's book "The Bicycle Wheel". Anyway, I randomly found the section where he is explaining that how people usually describe the wheel holding load: that the bike "hangs" from the spokes, is wrong. He makes an argument that the wheel is supported by the spokes below the hub. Anyway, the Mechanical Engineer inside of me rebelled against his argument, especially the one where he compares spokes to a pre-stressed concrete beam in bending to argue that the bottom spokes can be both in tension and support a compressive load at the same time.
Anyone else see this in his book and find this argument odd? To me, it makes no sense logically (how can a spoke be in tension and compression at the same time?), and his pre-stressed concrete beam example is hogwash because a prestressed concrete beam (uses pre-tensioned rebar inside the beam to keep the concrete perpetually in compression) is a composite structure. He basically argues that the spoke can be in compression and tension at the same time because a prestressed concrete beam can be pulled in tension and support a tension load even while the concrete stays in compression. What he's missing is that something has to be supporting the tensile load, and if it is not the cement, then it must be the rebar inside the cement (which is holding the beam in compression) that is taking up the tensile load.
It makes it hard to trust any engineering science analysis he presents in his book or any other publications he writes - the fact that he got this wrong. Or, alternatively, am I missing something here? (God only knows how many times I've been wrong in my fundamentals! )
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Certifiable Bike "Expert"
The rim is not very stiff; the force applied to the bottom of the wheel relieves some of the tension on the lower spokes.
search USENET (rec.bicycles.tech) on Google Groups for lots of discussion.
https://yarchive.net/bike/wheel_stresses.html
Dumb@s$ Jarhead
Bikes: Calfee Dragon Fly Pro 1984 Pinarello Montello
my wheels roll round and round
Si vis pacem, para bellum
Ho-Jahm
Quoted: 5 Post(s)
Put your weight on your bike and pluck a spoke at directly above the hub and at one directly below the hub, then take your weight off and pluck the same two spokes again. This is most easily done by leaning on your handlebars and plucking spokes from the front wheel.
Because pitch is a function of tension, a higher pitch denotes a larger tensile force on the spoke. You'll find the spoke below the hub had a much greater change in pitch, while the difference of the upper spoke was harder to discern. The upper spoke will increase slightly in tension, but the increase is very small compared to the lower spoke.
What I'm getting from the usenet discussions is that this is basically a semantic issue of how to go from a complex analysis of how the load is shared amongst spokes to a simplified, watered down version to tell those who don't want to get into details. Ah, screw it then. The Mechanical Engineer in me has lost interest.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Each spoke is one part. The wheel is a composite structure. Tear it down and draw a free body diagram of the parts.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
The spoke is in tension and supporting a compressive load because it is in less tension than the rest of the spokes; the load equals the reduction in tension. None of the spokes are in compression and JB does not claim this.
BSME +18 years.
BSME +18 years.
Eh? You can draw a free body diagram of an indeterminant structure. You just cannot solve it without introducing a constituative stress as a function of strain model.
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
no engineering expertise here, just a question. Couldn't you test this hypothesis by building a wheel with very flexible wire, instead of conventional spokes?
If the wheel hangs from the spokes above, then you ought to be able to use just wire; If however the wheel is supported by the spokes below, wouldn't the wire wheel collapse?
Bikes: 07 Cannondale Six13 (9 speed Ultegra) + 19?? Lugged Steel Specialized Allez Pro
What is interesting is an FEA model I found on the web which shows that only the bottom 2 or 4 spokes (on a 32 spoke wheel) are unloaded and the rest increase in load. Looking how the rim deforms, I can see this: it's because the rim deforms into a squished pear shape and load up spokes below the axle as well as those above it. I imagine that this effect is lessened as the rim is made stiffer and can support bending stresses to keep the rim rounder and transmit more force to the spokes above the axle and unload more spokes below the axle of the wheel. The FEA analysis probably only assumed that the rim could only support compressive stresses.
Aren't there some high performance wheels which use Kevlar fibers as spokes?
The unloading of the couple of bottom spokes is actually the means that does act to oppose the force placed on the axle.
I.e. you end up with a hub that has an even tension on all of its eyelets except the bottom two or three with a low tension. Therefore, the net force acting on the hub from all the spokes is a vertical (up) one equal in magnitude to the amount of slackening the bottom spokes have sustained.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
I've disagreed with stuff Jobst has written before.
Just because you put it into a book doesn't make it right.
Today, I believe my jurisdiction ends here...
Bikes: Bruce Gordon BLT, Cannondale parts bike, Ecodyne recumbent trike, Counterpoint Opus 2, miyata 1000
If the spokes under the hub were (God{ess} forbid) to loose all tension and try to accept tension they would start to turn in the holes in the hub thus shedding any compressive load. One of those composite 3 or 4 spoke wheels could and may just go into compressive loading. Sounds like a good project for an undergraduate student with access to several strain gages.
I thought you weren't interested in this anymore.
I very much doubt that the spoke tensions remain equal around the hub except for the bottom four. This would imply a discontinuity in your rim deflection, which definitely does not happen. You will see a continuously variable level of tension as you test spokes around the rim. From the FEA on the website I saw, the tensile force was at a minium at bottom dead center at below the nominal pretension value, and as you traveled toward top dead center, the tensile force first increases to cross over the nominal pretension, then reaches a maximum around 1/5th of the way toward the top and gradually decreases to a constant value above the preload tension. The rim becomes somewhat pear shaped.
From a structural standpoint though, you don't describe load bearing members by what the deflection looks like from an observer's standpoint. Rather, you "cut" the load bearing member to expose the forces across the cross sectional area. When you do this, you cannot just subtract and discard the preload tensile forces the spokes see. You can calculate them out separately, because forces can be superimposed, but you have to add them back in at the end of the day.
What he does get right is that this is all pretty non-intuitive. The wrongly made assumption that has people assuming that more than just the spokes at the very bottom go slack, that only the spokes above the axle are holding the axle up, is the assumption that the rim does not deform - that it is a rigid body. If this were the case, then yes, logically only the spokes in the top half of the wheel resist the load. But this is not a good assumption, though it gets better when you talk about these deep cross-section rims like the Zipp 404 and Velocity Deep V.
My bad, I missed this. A stiffer rim would transmit that bending stress further up the wheel. As you made the rim stiffer and stiffer in the bending direction, you'd get a closer to a rigid body rim, where the whole bottom half of the wheel has slack spokes and the wheel is truely "hanging" from it's spokes (i.e. with the preload of the spokes set to zero, you could cut out the spokes in the entire bottom half of the wheel and the stress on the top spokes would remain unchanged).
Young and unconcerned
Bikes: Yeah, I got a few.
Jobst has something to say about the Rev-X: https://yarchive.net/bike/spinergy.html
Had some buddies with 'em, but didn't really see the appeal. I do have some Spinergy Spox MTB wheels sitting around - these were good wheels with Vectran fiber spokes, but I've got no bike to put them on.
