A Physics Question
A Physics Question
Old 12-21-03, 09:08 PM
Prosody
Are we having fun yet?
Prosody's Avatar
Bikes: Fuji Roubaix, Trek 7200
A Physics Question
I ask this question out of pure curiosity. In a strong crosswind, 25 to 30 mph, is a bicycle more stable at slower speeds or at faster speeds, and why?
You're east of East St. Louis
And the wind is making speeches.
Prosody is offline
Old 12-21-03, 09:54 PM
Mtn Mike
Super Biker
Mtn Mike's Avatar
Bikes: 2014 Curtlo, 2006 Serotta Coeur d’Acier, 2005 Independent Fabrication Steel Delux, 2003 Surly 1x1, 2003 Surly Cross Check, 1986 Schwin Worldsport SS commuter, 1980's Mongoose Supergoose
I would say that a cyclist is more affected by a strong crosswind while traveling at higher speeds because the total wind resistance would be greater. You have 1) a perpendicular wind force vector, and 2) a parallel force vector both from moving forward, and from the effective forward force of the crosswind. Of course it's been a while since I've taken physics, so I might be talking out my a$$. But personal experience on the bike supports this, I think.
Mtn Mike is offline
Old 12-21-03, 10:19 PM
cycletourist
opinionated SOB
cycletourist's Avatar
Of course in practice the biggest problem with strong crosswinds is what happens when an 18-wheeler passes and temporarily blocks the crosswind.
cycletourist is offline
Old 12-21-03, 11:39 PM
roadfix
hello
roadfix's Avatar
Quoted: 150 Post(s)
Liked 3 Times in 2 Posts
Your bicycle will be more stable at higher speeds due to a more effective gyroscopic effect of your wheels. But of course, if your riding disc wheels....forget it!....you're get blown off the road regardless of speed!
roadfix is offline
Old 12-22-03, 12:30 AM
skiahh
skiahh's Avatar
Bikes: 08 Stumpjumper FSR Expert, 02 Litespeed Tuscany, 04 Specialized S-Works Epic
Fixer's right. You can look at airplanes, too. The faster you go, the less "crab" - or angle into the wind - you need for a given crosswind component.
skiahh is offline
Old 12-22-03, 11:04 AM
Dave Stohler
60mph in the 42 ring!
Dave Stohler's Avatar
Well, I have an advanced degree (MS, mechanical engineering), but since nobody likes my posts, I can't answer your question. Sorry.
Dave Stohler is offline
Old 12-22-03, 11:45 AM
shokhead
05 Roubaix Comp Double
Bikes: 2012 Trek Madone 6.2
Gust and straight blowing makes a difference also.10mph straight blowing and then a 20 mph gust is different from a straight blowing wind.
shokhead is offline
Old 12-22-03, 04:18 PM
Jonny B
Not-so-Senior Member
Bikes: Orbea Enol roadie, Fly Micromachine BMX, Fort Track fixed
The direction the wind is blowing would probably make a difference. If it's slightly from in front I think it'd be harder to ride, slightly from the rear would be easier (as far as front-to-back wind resistance goes anyway. Stability is another matter of which I have little knowledge).
Jonny B is offline
Old 12-22-03, 05:21 PM
Allister
Devilmaycare Cycling Fool
Allister's Avatar
Bikes: 1998 Cannondale F700
Even then you can compensate to a degree by leaning into it if it's a constant wind. It's when the it's gusting that it's really dangerous. But yeah, the faster you go the more stable you'll be.
Allister is offline
Old 12-23-03, 09:24 AM
AndrewP
Bikes: Peugeot Hybrid, Minelli Hybrid
I dont think you will have any stability at 0 mph, so I would vote for more stability at high speed.
AndrewP is offline
Old 12-23-03, 09:56 AM
jedi_rider
Nut Job
jedi_rider's Avatar
My quick assessment: At certain high speeds, you've got wind directly in front of you and to the side. This clash of the winds may create turbulence causing instability in your steering.
Conclusion: You probably have more control at slower speeds.
Of course, I'm not sure at what speed you have to go, but if you can effectively go fast enough to create an airfoil around you sufficient enough to keep the crosswind from effecting you, then you'd be OK. I'd imagine that you'd have to be going very fast ---> faster than 50mph probably.
Disclaimer: There are those that think I'm full of of it, so take this with a large grain of salt.
jedi_rider is offline
Old 12-23-03, 10:33 AM
lsits
Desert tortise
lsits's Avatar
Bikes: Ibex Corrida LT 4.4 (2003), 2006 Bianchi Vigorelli (Red)
Well, there's the actual wind direction and then there's the aparent wind direction. Say the wind is from the northeast and you're traveling north. The faster you travel the more the wind will seem to be coming from the north-northeast. I vote for more stability at higher speeds.
Wish I didn't know now what I didn't know then. - Bob Seger
lsits is offline
Old 12-23-03, 10:39 AM
cycletourist
opinionated SOB
If it is cold outside, I vote for staying home when the wind is blowing. I am most stable when sitting on my couch :-)
Old 12-23-03, 10:58 AM
shokhead
I vote it doesnt matter because you cant stop the wind,you can only ride in it and beat it.
shokhead is offline
Old 12-23-03, 11:41 AM
don d.
Guest
Posts: n/a
Quoted: Post(s)
Test Pattern
why this question was posed...
Old 12-29-03, 08:54 AM
miamijim
miamijim's Avatar
Quoted: 325 Post(s)
Liked 6 Times in 6 Posts
Dave stolers nobody lkes your posts because most of them are like your previous post...and most of them are vague at best if not in-correct at many times.
Your more stable at faster speeds
F=MV2...the more force you have to counteract the force of the wind the more stable you'll..
I'm not an engineer but I've been riding for awhile now so what the heck do I know....
miamijim is offline
Old 12-29-03, 03:19 PM
deliriou5
It tastes like burning!
deliriou5's Avatar
even if you're more STABLE at higher speeds (that is, the bike is less likely to get in an accident in the first place), i would choose to ride at the slower speed, because of the better reaction time, increased stopping distance, and reduced momentum in the EVENT of an accident.
deliriou5 is offline
slebo3213
Bicycle Mechanics
3
11-03-16 01:50 PM
1987cp
Bicycle Mechanics
1
03-21-13 05:38 PM
dedhed
Classic & Vintage
4
03-04-11 06:10 PM
swapmeet
Singlespeed & Fixed Gear
1
09-20-07 03:48 PM
