Creative drop bar thumb shifter mounting idea?
The Rabbi
Quoted: 16 Post(s)
I've seen a few on here, particularly in the Vintage MTB Drop Bar Conversion thread, but wanted to see what everyone is doing and what is working out best. I'm going to run either a mustache bar or a WTB Dirt Drop on my MTB and could easily do bar-end shifters, but I always like doing things a little differently.
An I've had is to mount thumb shifters on the inside of the brake levers (or on the underside in the case of mustache bars) which would then allow me to shift from the hoods (I think... that's how it works in my head anyway). Anyone try this? How do you like it? Any other ideas worth considering? I want to keep it very clean-looking.
Quoted: 1372 Post(s)
Liked 1,751 Times
one life on two wheels
Liked 18 Times
This is about as cool as it gets IMO:
https://retroshift.com/
The Rabbi
Quoted: 16 Post(s)
Cool, but expensive, and holy crap are they ugly (IMHO). I'm trying to think of cleaner, cheaper solutions. I may just have to buy a pair of thumbshifters and experiment a bit.
MFA
Bikes: 1973 Italvega Nouvo Record; 1965 Hercules; 1982-83 Schwinn Mystery MTB
This isn't too crazy. An 8 speed DuraAce lever on a Paul Thumbie. All the crazy is after because this is what controls a Nexus Inter8 hub.
Liked 18 Times
They may be overkill for most, but once you lose a cross race because your brifters are clogged with mud you'll flip your script real quick. They do a good job for what they're designed for. Maybe not the best solution for the OP, but still a nice product. I happen to think they look cool too.
MFA
Cisalpinist
Bikes: blue ones.
Quoted: 5 Post(s)
Liked 16 Times
Hm, no experience in cross, but still. If it was a 20$ solution from the far east it would make a lot more sense at a lot more pricepoints and situations. "unfortunately" it is a well designed product made by hand
Liked 18 Times
I will add the Paul thumbies jjvw suggested are a great way to go too. Great looking a much more affordable. They seem to be the best of both worlds.
MFA
VO also had a Thumbie type mount. They use a hinged clamp, so you don't need to strip the handlebars to add or remove the mount. They are also polished aluminum. Sadly they have been out of stock for a while.
Pennylane Splitter
Bikes: Yes
Quoted: 1796 Post(s)
Liked 1,439 Times
How about this? Its a thumbie purchased from Velo Orange being used on an MTB with a 25.4mm clamp drop bar that has a channel for brake cables for aero brake levers. Friction shift only, but it works, and it was only $12/pair (I'm not using a FD on this bicycle). It has a simple, flexible mounting strap similar to a hose clamp that can be flexed to fit any handlebar. Jenson also sells individual thumbies for aroung $7/each (also friction shift). Cheap (like the non-aero brake levers in the pic) but they work great!
Bikes: 1985 Eddy Merckx Corsa Extra, 1978 Schwinn Super Letour 12.2, Schwinn Paramount PDG 50, 1992 Schwinn Paramount PDG 3, Sears ToteCycle in the works
Depending on budget and style, it's hard to go wrong with a set of Shimano SIS 7-speed thumb shifters. I think I paid like $6 for them on ebay and they shift with typical Shimano precision.
your ticket is at will call
Bikes: Schwinn Paramount P15, Fisher Montare, Proteus, Rivendell Quickbeam
Quoted: 12 Post(s)
I have run a thumb shifter on a stem. Most thumb shifters won't fit a drop bar.
Quoted: 213 Post(s)
Liked 1,508 Times
i used this set up until I found some used bar ends at a reasonable price.
They are a basic set of Suntour shifters I took off a pitiful Murray junker that had a cheap swept back bar of some type.
I could not get the clamp to fit until I substituted a longer screw to get
it tightened down.
Then it worked great.
All in all I was pleased. Wrapping bars was an issue & I did not do a great job & even used a variety of left over tape as I knew I would soon be changing out cockpit.
I like the clean look of bar ends much better but glad I still have these to use in a pinch
for free as someone gave me that old Murray.
it tightened down.
Bikes: Focus trash find commuter, Eddy Merckx Corsa, BP Stealth TT bike, Leader 720 TT bike, Boardman Comp Hybrid drop bar conversion, Quantec CX budget cyclocross build, SerottaNOS frameset ready to build up!
Quoted: 128 Post(s)
Liked 104 Times
Quoted: 128 Post(s)
Liked 104 Times
Thanks, Italinium! It would have worked but (as so often!) the build ended going in a different, more conventional direction. Cantilevers & Sora/105 STI. Works very well too!
