Go Back  Bike Forums > Bike Forums > Fitting Your Bike
back pain for 6'2 - 6'3 rider
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 01-30-17, 10:53 PM
superdex
staring at the mountains
superdex's Avatar
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times in 112 Posts
Originally Posted by cmac77
//goo.gl/photos/teFfAu6cE4hgMRbz7
Im not sure if anyone is still paying attention to this thread anymore, but here is a link to a picture of me on the bike.
shorter stem. looks like you're reaching a bit. And yes, core strength helps, and miles. more miles.
superdex is offline
Old 01-31-17, 01:04 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3878 Post(s)
Liked 1,930 Times in 1,377 Posts
If anything, longer stem. Try turning it over and rotate the bars a bit as mentioned above. You want to be less upright and have more arm bend, about 15°. Try this: with your hands on the hoods and the pedals horizontal, bend your elbows until your forearms are horizontal. In that position, your elbows should be in front of your knees by about an inch. Also, your bars should hide your front hub when you look down.
But the most important thing to get rid of back pain is to straighten your back. You are sitting back on your sitbones and then bending at the waist to lean forward. Instead, rotate your hips forward so that your whole back is straight from butt to neck. So . . . more forward lean and a straight back.
Results matter
Carbonfiberboy is offline
Old 02-02-17, 07:38 AM
Tusky
Tusky's Avatar
Quoted: 8 Post(s)
Hi Chris,
I am 6'3" with a 36" inseam. I usually ride an old 61 frame or a TCR large.
I would say that you should drop your seat a bit.
You have your stem set high. In time you will probably want to cut down the steerer tube and/or flip the stem.
I think we both have a positive ape index so it helps to bend the elbows a bit.
Work on your core and put on the miles.
Tusky is offline
Old 02-04-17, 07:36 AM
cmac77
Quoted: 23 Post(s)
Thank you all for the advice. I've started working my core at the gym. I'm going to take my bike in soon, they told me to bring the bike in after 10 hours for adjustments. I will address the stem handlebar position an d seat height at that time.
Happy riding!
cmac77 is offline
Old 02-05-17, 01:02 AM
andrushaa
Originally Posted by 10 Wheels
Build up your core and Take B-12 everyday.
I agree - thats what was happening to me
andrushaa is offline
workingthrewit
General Cycling Discussion
17
02-07-16 06:08 PM
Deontologist
16
01-19-16 04:45 PM
SideSke
Fitting Your Bike
4
09-02-13 07:09 AM
kuan
Road Cycling
65
12-12-11 10:42 AM
Frankthetank727
Road Cycling
7
08-04-11 08:05 PM
