Everyday Carry
#52
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2639 Post(s)
Liked 3,153 Times
For the record I carry flat repair stuff, multi tool (w chain breaker and spoke wrench), KMC quick chain links and zip ties on every ride. I never need to use any of that stuff outside of flat repair, but I have it because it's worth not getting stranded. I'm not advocating not being prepared, sorry if I came off that way.
I'm just saying this is a weird thing to get worked up about. Also @DrIsotope if you've used all that in the last 30 days I'd say that's bad luck. I know you ride a lot.
"Your beauty is an aeroplane;
#53
Non omnino gravis
Self-induced bad luck, if anything. Hit a driveway lip on a bike that I had just changed the bars on a few days before, and whoop, there they went-- not enough carbon paste, so my fault, not the driveway's. Got a rock stuck between the cleat and the pedal, when I rotated to unclip, it turned the cleat about 5º, so my heel was stickin' out. And any time I go to a new saddle, the mini-adjustments are frequent for at least a few weeks-- and this particular saddle is noseless, so I was effectively starting from scratch. So I've just made it a habit to have a convenient tool at hand whenever I'm on a bike.
#54
Not actually Tmonk
Liked 3,153 Times
#55
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
If I wasn't already familiar with the typical posts on here, I might be surprised by the number of people who purportedly ride bikes, but have never needed to adjust a handlebar, raise or lower a seatpost, or even tighten a cleat on a shoe-- ever, even once, while riding.
On the other hand, I've done all of those things in the past 30 days.
#56
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
My experience is that a new seatpost and/or saddle on an existing bike, or seatpost and saddle setup on a new bike almost always requires dialing in on the road.
1 mm difference in angle or height can mean the difference between comfort and pain. Often this can only be felt when one is warmed up after riding a while.
Adjusting steatpost height, saddle fore/aft position or angle is part of the shakedown ride ritual for me. A 4 mm wrench and a 1 hour ride through the subdivisions is SOP for NBD.
My Niner was really, really close but required a tweak to saddle tilt for optimum testicular comfort.
-Tim-
-Tim-
#57
Non omnino gravis
Try going from a traditional saddle to tensioned leather, or from anything to noseless. I've had the ISM on there for just over 800 miles now (about 6 weeks) and I'm still moving it back and forth, up and down, fiddling with the tilt. It's such a strange sensation from the outset (completely different bones being used) combined with a different upper body position-- sometimes I'll be 40-50 miles into a ride before I decide I want to make an adjustment.
I use a Torqkey for anything carbon, but potholes and pavement lips don't care about torque values. Sometimes, I hit something just wrong enough that the bars rotate down a bit. It's nice to be able to reset that, rather than finish the ride with wonky bars.
#58
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Better wonky bars than wonka bars those might just melt and then you won't be able to ride home at all! Thank you thank you, I will see myself out!
#59
Quoted: 212 Post(s)
Liked 83 Times
Hi everyone,
Just wanted some thoughts on some EDC stuff i am buying
i'm about to start a longer commute (still short by regular standards ~8 miles) than expected and decided on some of these based off reviews and stuff;
BLITZU Gator 320 USB Rechargeable Bike Light
Continental 60mm Presta Valve Tube x1 (budget constraints)
Topeak Road Morph G Bike Pump with Gauge
as for a patch kit and levers
my local shop has some cannondales levers and some regular patch kits
budget is not too big
if there are any other suggestions
they are most welcome
One tube is enough.
Pick up one of those cheap little adhesive patch kids found at the counter in any bike store. It contains six little translucent patches that just stick on. They don't last forever, but they'll get you home. It's a shame to use your only spare tube and then get another puncture a mile down the road. Those adhesive kits are insurance. I always use a new tube as my first flat fix, and then patches for subsequent. ...and frankly I don't bother using permanent patches on tubes. I guess I should.
Tire levers: Pick up two or three of the blue ones at any bike store's front counter. I have always carried two, but after breaking one a few months back I've started carrying a spare.
If everything else on your bike is dialed in and you're never too far from civilization, you don't really have to have a multi-tool. I've stopped carrying mine because I only used it when I was making adjustments... and for those infrequent occasions I can just bring it along as needed.
nappycappy
Singlespeed & Fixed Gear
81
03-07-15 05:33 PM
mountainwalker
Commuting
62
06-23-14 08:10 PM
