Bike friday small wiggle
Bikes: Pocket Llama
Quoted: 30 Post(s)
Hey guys I need an advice my handlebars are wiggle very little and is not coming from the headset ,all my screw are tight what can I do?
Do you mean the bars are loose within the stem, or that the entire stem mast wiggles laterally as you ride?
If the latter, then it's almost certainly the headset. BF headsets take a lot more pounding because of the tall stem mast design.
I'm a big believer in Chris King headsets on BFs for this reason. They seem to withstand the stresses better than other designs.
If you have a non-CK headset, it must be adjusted perfectly for everything to work well. That's where I'd start.
Stardust
Quoted: 18375 Post(s)
Liked 4,510 Times
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
You're not going to get a different answer here than on the BF facebook page, lol. Jarl asked if you had the "tap adjust" headset. If you don't know what that is, I suggest you head over to you tube and look at "bike friday headset" videos. It's either your headset adjustment or just the length of your stem causing normal flex.
Bikes: Pocket Llama
Quoted: 30 Post(s)
Apply the front brake and hold it. Can you wiggle the bars fore and aft with the front brake applied?
Yes: Your headset is not tight enough and needs further adjustment.
No: Your headset is tight enough (assuming it's not binding), and something else is the issue.
I'm guessing your headset isn't as tight as you think it is.
Palmer
Quoted: 1668 Post(s)
Liked 1,820 Times
Picked up a wiggle on a ride. Immediately quit peddling, looked down for a quick cursory inspection and saw the concrete street had a squiggle brush finish.
The Aluminum Folding handle bar mast , that was the build spec option on my Pocket Llama,*
did have some creak, flexing.
so I had a steel non folding bar mast fabricated, of Steel, and now it has none...
*refusenik order declined .. so I saved a bit..
