Racing with Tiagra
Racing with Tiagra
Hi all,
I have this nice alloy frame waiting to be built up. I'm slowly starting training again after a few years off the races. Most of my riding before has been on Ultegra 6600, Campagnolo Xenon/Mirage 9 speed and Campagnolo Veloce 10 speed and now 11 speed DA on the TT bike.
I have a kind of a tight budget with a newborn in the house so I can't justify spending too much money on cycling right now.
So I'm looking at the 10 speed Tiagra 4700 group. Would anyone actually recommend this for racing instead of 105? I know it's 300g heavier than 105 but I'm 7-10 kilograms overweight right now so really why should I care. I can probably get the bike close to 8 kg even with Tiagra. I'm not convinced I truly need 11 speed either.
Is there any difference in functionality or durability compared to 105? I've heard mixed opinions. Brakes are a common complaint but can probably be fixed by changing the pads.
I'm probably going to ride 7000-10000km max yearly and most likely going to update the groupset after a few years anyway. I'm 31 and my FTP is somewhere between 250-300 so strictly amateur level with a calendar of maybe 5-10 races next year.
I have turned to shorter cranks on my current old steel bike so I'm delighted to see Tiagra offers 165mm cranks readily available online with the complete group.
Should Be More Popular
Quoted: 22590 Post(s)
Liked 8,924 Times
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Isn’t Tiagra a PED?
Likes For Darth Lefty:
Tiagra works fine. Especially the newest tiagra.
10 speed vs 11 really isn’t that big of a deal unless you need to swap/borrow a rear wheel. Most racers I know have 11.
Likes For BK84:
It works well and spare parts are much cheaper than Ultegra. Its heavy, but you know that. Only thing I can think of is the right brifter only does two gears at a time vs three for 105 and up.
Likes For Racing Dan:
Likes For MyTi:
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
I definitely wouldn't. If you're planning on riding that much, I'd certainly get the 105. Plus, 10 speed is old. Pit wheels/neutral service will likely be 11. Probably won't come up, but if it does it can be an issue.
105 has 165mm cranks, too.
It's not that it won't hold you back or that it's heavier. It's functionality and durability.
Expired Member
Quoted: 3661 Post(s)
Liked 5,408 Times
From what I can see it's less than $100 more for 105 group.
Disco Infiltrator
Liked 2,105 Times
In the past Tiagra or its equivalent Deore have been the level where every part is made from metal that is either aluminum, or steel that is stainless or shiny plated, not painted or black oxide. It's not going to get UV damage or rust. You can rely on it for the life of the bike, barring wear and damage. Higher levels get lighter (forged aluminum, carbon fiber, hollow crank arms) or more efficient (ball bearings in the pulleys) and have more adjustments, but might not actually be more reliable. If the bike is for riding alone I think it's a winner. But in a race... @rubiksoval 's note above about neutral support of 11 speed is really good and I think the most relevant you're going to see.
Genesis 49:16-17
Genesis 49:16-17
Mostly Harmless
Bikes: Have two wheels
Quoted: 13707 Post(s)
Liked 4,523 Times
Likes For rjones28:
Liked 8,924 Times
Likes For datlas:
Quoted: 871 Post(s)
Liked 726 Times
Tiagra 4700 lever throw is the same as the other Shimano 11-sp, so couldn't OP race with an 11-sp chain to readily accept an 11-sp wheel?
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
I've always ridden Chorus - 8, and now 11. My trainer bike is 10-speed Tiagra. Seems to behave just fine. But, as others have said, small price differential to 105 (I had 105 on my older trainer bike - Tiagra is good enough that I didnt move the 105 parts over yet - saving them for if/when the Tiagra wears out). In either case, what are you going to do for wheels?
Lever throw (cable pull) is the same but the derailleur moves through the same old 10-speed cog spacing (10s cassettes are still the same as before). So a Tiagra system would not shift an 11s cassette. I'm pretty sure , correct me if I'm wrong.
Quoted: 871 Post(s)
Liked 726 Times
Whoops, you're probably right, it would only work if one were to get a rd change in addition to a wheel change. So not useful in a race.
Quoted: 2952 Post(s)
Liked 3,106 Times
Anywho, although neutral service wheels are a potential drawback, I don't think it's that big of a deal. Bring your own pit wheels, or accept the fact that a flat might mean the end of your race. Which it will if you flat in the last five laps of a crit anyway.
I built up my kid's race bike with Tiagra because it was a heck of a deal on Chain Reaction or Ribble or one of those UK sites, don't remember which. And it allowed me to share wheels with my own 10-speed bikes, including a nice set of carbon tubulars that wouldn't take an 11-speed cassette. It shifts gears just as well for a few grams more and a few dollars less.
So, put me in the pro-Tiagra bucket.
