Granny Gear for Touring on Older Shimano?
Hi everyone!
I would like to change the gearing on my road bike to have a "granny gear" for a tour I'm doing that's coming up really soon. I've done the same tour before without a granny gear, but just barely with the super long hills extremely tough to do. I'm not as trained up this year so really need to have that option.
Can you guys let me know if it's possible to upgrade the existing gearing to have a granny gear and exactly what parts I would need?
What I have now is a Shimano "Golden Arrow" 105 groupset from the 1980s - as shown here.
Right now, the bike is 12 speeds - 2 front cogs x 6 rear cogs. I 'm attaching some photos, see below ...
SE Wis
Quoted: 2740 Post(s)
Liked 3,386 Times
I believe you would need a 'triplizer" inner ring and a longer BB
https://www.peterwhitecycles.com/chainrings.php
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
Among the problems you will run into, the wider bb spindle will shift the rings out and mess up your chain line. Also, the tripleizer will be replacing your present inner ring, and you would need to purchase a 74 BCD granny (and I'm assuming your present crank is 110 BCD, which is not really a safe assumption). Lastly, the new rings will likely be 9 speed, while your large ring will be six speed, meaning the wider chain that will be necessary to accommodate the 6 speed ring will be a bit sloppy on the 9 speed rings. It's tough.
Phyllo-buster
Quoted: 2295 Post(s)
Liked 2,043 Times
It would be easy to source a wide range 13 - 32 freewheel (IRD) and swap the RD and chain for some useful touring gears
Quoted: 5887 Post(s)
Liked 3,469 Times
We could use some more pictures of the drive side to see the crank and rear derailleur.
Still the suggested solution will work and is likely your most cost effective option. The IRD freewheel runs $60, a KMC 6-7 speed chain runs around $7 on Amazon, and a Shimano Claris rear derailleur that can handle the 32 tooth freewheel run around $29 on Amazon. You can find used stuff that will do the job for less money but this is available right now if you need to order it to get your bike set up.
Likes For bikemig:
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Depends on how much change you want. Current crankset is 130 BCD, so smallest inner ring you can run is a 38. I'd suggest looking for a mid 80's Deore or Shimano 6206 triple crankset, which is 110/74 BCD, so you can run it as a double or triple with as small as a 26 inner ring. You might be able to get by with your current BB if you run a double, but will likely need a wider one if you go the triple route.
Out back, pretty sure that RD is rated at a maximum cog size of 26. You might be able to stretch that to 28 with a little fiddling with chain length, B screw setting (if that RD even has one) and rear axle placement in the dropouts, but for more than that you'll need a different RD. Again, mid-80's Deore will do the trick just fine for both the additional wrap needed for thr front ring change and a cog size up to 34.
None of this is cheap. Assuming you have the tools and know-how and are able to secure the appropriate bits at reasonable prices, it's about a $200 investment.
Quoted: 56 Post(s)
Liked 56 Times
I went to 2 bike shops to get an ird freewheel and was given 2 nutty reasons why they couldn't order it for me. I have the shimano megarange 14-34, works well but the jump from 24 to 34 is driving me crazy(er) 😵
Quoted: 4559 Post(s)
Liked 2,802 Times
Yeah, the jump from 24 to 32 on the Shimano Megarange is horrible. I ditched that freewheel ASAP from my comfort/errand bike. It already has a 28/38/48 triple so I replaced the original 7-speed freewheel with a 14-28 from SunRace. Much smoother transitions, and the 28 is plenty for that bike, even loaded down. The bike weighs about 35 lbs and I haul up to 50 lbs of groceries and livestock supplies. No problems.
Any SunRace or Shimano freewheel in the 14-28 range should do the trick and cost under $20.
Replace the inner chainring with a Vuelta 38T or 39T (the smallest they have for 130 bcd) and you might not need a triple.
Depends on how much you plan to haul on the bike. I'm accustomed to hauling up to 50 lbs on my heavy errand bike, but my longest rides are around 20 miles. Usually much shorter, but with a steep climb. For a proper bike tour, a lighter bike and lighter load of minimalist gear would be fine on my road bikes. I'm not a strong climber but I could get by with the 50/39 chainrings and 13-25, 13-26 or 13-28 freewheels I already have.
Quoted: 3241 Post(s)
Liked 2,512 Times
If you decide to change cranks to a 110/74, Shimano Deore or FC-6206 are good options. Sugino and Sakae both made 110/74 cranks that came on bikes as doubles. No third ring but the holes are there for one.
Liked 3,469 Times
I like shimano freewheels and that's disappointing about IRD inventory. The problem with Shimano freewheels is that the mega freewheel, 14-34, has a huge jump from 24 to 34. That may work for the OP but that is a big jump. Also these are 7 speeds and the OP has 6. That's not a big deal since both are used on 126 mm rear wheels but sometimes when going from 6 to 7 you get a big of chain rub and you have to put a 1 mm spacer to deal with that.
Quoted: 1627 Post(s)
Liked 630 Times
I hated that ugly thing too. Couldn't wait to get rid of it. Worst $15 I ever spent.
Quoted: 4788 Post(s)
Liked 3,914 Times
If modern indexing is something you can go without, this does not have to be prohibitively expensive.
Ben
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,184 Times
I'm going to throw an uncertain curve ball at this conversation:
I believe looking at the second picture of the back view of the rear sprockets, the OP might have a UniGlide Cassette and not a freewheel. Noticed the "twisted teeth" (so Shimano UniGlide and not a Suntour, Regina, or Atom, etc. freewheel). But also notice there does not appear to be any room for a removal tool for a freewheel (now I could be wrong on this because the angle of the photo is not great).
If the OP is dealing with a freehub and a UG cassette, our guidance for lower gearing needs to be adapted a bit.
What do others think about the 2nd picture? Is there enough of a gap to slip a removal tool in there or are we talking two chain whips and possibly modifying a HG cassette?
Bob
Bob
aka: Dr. Cannondale
Liked 3,401 Times
Good point, Bob.
Appears to be an FH-105 rear hub, which is a 126OLD freehub. Makes fitting rear cogs easier to customize (either find the UG cogs you want or slightly modify HG cogs).
Still, that part aside, to get where the OP wants to go will require some derailleur and/or crank replacement.
Liked 2,512 Times
VeloBase.com - View Group
Liked 2,512 Times
Counting the teeth in the picture, it appears the big cog is either a 26 or a 28. If that's the case, maybe only change the crank to 110 or 110/74 with a compact setup. He might get lucky and can use the same BB spindle. Velobase says that crank takes a 116mm spindle. Find a 110 or 110/74 crank that takes a 116mm. Simple swap. Or find a crank. There are plenty of cheap BB spindles out there.
Liked 2,512 Times
Quoted: 286 Post(s)
Liked 100 Times
When I looked at the 105 golden arrow group on Velobase, the rear hub is listed as a cassette.
Phyllo-buster
Liked 2,043 Times
aka: Dr. Cannondale
Liked 3,401 Times
Hub body can't be swappedwith a later HG one as they are an entirely different design.
However, HG cogs can be easily modified ro fit a UG freehub by filing/Dremeling the small slot slightly larger.
Takes maybe 40 seconds per cog. Very easily done.
Or you can get one of these Corsa Vuelta triple cranksets for less than a used vintage set; as I did. https://www.amazon.com/gp/r.html?C=1...3920290_dpLink
climber has-been
Quoted: 3405 Post(s)
Liked 3,535 Times
Is there any reason why swapping out this bike's cranks for a super compact crankset wouldn't work?
IRD makes a crankset with 46-30 chainrings, and it fits on a square taper bottom bracket spindle (which this bike seems to have).
IRD Defiant Super Compact Crankset
FSA also makes the Tempo Adventure crankset, with 46-36 rings and a square taper:
FSA Tempo Adventure Crankset
Ride, Rest, Repeat. ROUVY: terrymorse
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 694 Times
IMO, the best bet is a triple crankset. The Shimano 600 triple crank is one of the best of the era (and, also IMO, any era) but they can be hard to find:
VeloBase.com - Component: Shimano FC-6206 Biopace, 600EX (Triple version of FC-6207)
It accepts 110mm/74mm BCD chainrings so it's possible to install a 24-tooth granny. That's a low enough granny gear for most people.
Here's one on Ebay:
https://www.ebay.com/itm/Vintage-Shi...8/254243285892
Jeff Wills
Jeff Wills
Quoted: 195 Post(s)
Liked 207 Times
Hi everyone!
Freewheel Medic
Liked 2,184 Times
Short answer, yes. It won't make a sport bike into a LHT but you can do it. Some triples push all the gears out from the BB rather then put a granny to your inboard side too close to the frame. Your present spindle may work and that derailleur may have the range to get all three gears or one or both may need to be replaced. If you go for a very low granny, you will probably need a mid or long rd. If you don't go too low you'll find it more useful, easier to shift and use. Stay with your 6 speed. A 7 speed freewheel will probably fit but not be as easy to shift and you may need a new chain....so, yes!
As has been mentioned, it is easy to adapt and modify a current HyperGlide compatible cassette to work with an old UG freehub body. This is especially useful on the original UG body which cannot be swapped for a new HG body. It is suspected this body is one of the non-compatible models. However, it is difficult to be certain by just the pictures.
If dubesor is up to it, my preference is to work with a 9 speed HG cassette. A 9 speed opens up the possibility of moving from a 6 speed to a 7 speed by utilizing the 9 speed spacers. Of course friction shifting will need to be used. The cassette needs to be one where all the sprockets are either held together by a long screw or rivet.
- Assuming the UG cassette has been removed, clean and keep the 13T threaded UG sprocket and clean and keep the original UG spacers.
- Remove the screw or grind off the head of the rivet. Separate the sprockets and spacers.
- Select the 5 or 6 sprockets for the new hybrid cassette.
- Using a Dremel or other small grinder, shorten the long tab to the size of the small tabs. Check to make certain the HG sprockets fit on the UG freehub body.
- Paying attention to line up all the modified tabs in the same freehub grove, add sprockets and spacers, first trying to 9 speed spacers to make a HG-UG hybrid 7 speed cassette. Secure with the original threaded UG 13T.
- If all the threads of the13T do not engage on the body, remove and remount with the original UG spacers for a HG-UG hybrid 6 speed cassette.
- My preference is to use a 8 or 9 speed SRAM or KMC chain with a quick link.
Bob
Bob
