Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
what do you want to see tested? (wind tunnel)
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 09-02-19, 05:02 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
Starting to put together my next trip to the tunnel. I've got a fairly extensive list of things I'm going to test (mostly clothes/helmets) but depending on the how fast we get through things (should be pretty fast as I will not be testing at many yaw sweeps) I might have some time to get some other stuff in, if anyone has a good idea I'll try to fit it in!
Some thoughts / info before you make requests
The majority will be tested in pursuit setup (aerobars) but I'm hoping if time allows to test a few runs with drop bars
- Wheels - I've got maybe two wheels I'm going to test (front) a 5 spoke and a disc, and the reason for that is I tested the 5 spoke last time I was at the tunnel, but didn't have a "real" (we taped up a spoked wheel as a proxy) disc, so I'd like that data point to compare... that said, testing wheels takes a long time (lots of work to change them out on the rig) so I probably will not test any more after the disc goes on.
- Helmets - Plan is to test a few "top end" helmets against my aerohead ultimate (I'll also be testing the aerohead without the visor) - currently planning on the POC tempor, Lazer Wasp/Victor, Kask Mistral. I've tested a lot of helmets in the past, can't think of any other high end one's I've not tested.
- Clothes - I plan on going through about 5 higher end skinsuits, two pair of shoes, and a pair or two of socks/shoe covers. The shoes/covers/socks will be towards the very end because it's lower impact most likely, so as time allows.
- Position - I pretty well like where my position is at currently, but I may try a few different things towards the beginning of my runs just to see if there is a different avenue I could go down.
I *might* also have access to an on track aero sensor to play with the same few days... may be able to get some verification data rl vs. tunnel. (and might have time to test more out there)
Anyone have any suggestions/requests?
Morelock is offline
Old 09-02-19, 05:07 AM
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 365 Post(s)
Liked 87 Times in 58 Posts
What 5 spoke is it? Might be interesting to do a Zipp 808 to satisfy Carleton.
Baby Puke is offline
Old 09-02-19, 05:24 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
unfortunately not an iO but an iO clone.
fwiw if anyone wants to make comparisons, the difference between it and a HED3 was .0019 (in favor of the H3) plenty of comparisons between H3's and 808's out there. (both 3 and 5 spoke with 19mm tires)
Morelock is offline
Old 09-02-19, 06:14 AM
Baby Puke
Quoted: 365 Post(s)
I'm curious to see what the real advantage of a front disc is.
Old 09-02-19, 06:25 AM
Dalai
Quoted: 89 Post(s)
Liked 8 Times in 6 Posts
Around 1 second per km...
Dalai is offline
Old 09-02-19, 08:19 AM
700wheel
Quoted: 144 Post(s)
Liked 14 Times in 11 Posts
Are you planning to vary your cadence - especially during wheel testing?
You might consider using Design of Experiments (DOE) so you can have two are more variables tested at the same time.
700wheel is offline
Old 09-02-19, 08:34 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Cadence will just be steady. It's possible that on longer runs (you basically just take readings for 2-4 runs, but alltogether) I could vary cadence... but more than anything it's a matter of sunken cost and would be the last run of the day most likely. (just to eat the final few minutes and, more importantly, to verify that I'm not moving/squirming and tainting the results)
Every run is going to cost roughly $25-$30 (small changes with a runner from tunnel to control room) and so it's easy to see how you just have to remove as many variables as you can and go with it.
Anything that takes any extra time starts eating into your $$$, so clothing changes (because I have to get out of the tunnel, change into a skinsuit and then get back in) cost more... doing something like testing 1 cadence vs. another cadence would basically mean testing 1 thing would cost $50-60. Testing wheels (because the tunnel operator is the only person who can touch the "rig" / change the wheel) costs more like triple anything else, which is why I'm reluctant to do more than one or possibly 2 changes.
Morelock is offline
Old 09-02-19, 04:46 PM
Baby Puke
Quoted: 365 Post(s)
Jeez I hope not. I rode one for a kilo *once* and the difference seemed much more marginal than that. I'm hoping this tests justifies my inability to afford to buy a front disc!
Old 09-02-19, 10:58 PM
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
Roughly about 1s per km, but that's at a sustained speed. For a SS race, like the kilo or 500, it will be less, as you spend a considerable part of the race getting up to speed, where the aero benefit will be lower. In a Kilo, it will be finding the balance between weight and cda with a front wheel.
If you can find a front disc that is as light as a spoked deep dish or a foil wheel, and is stiff ENOUGH, that would be your holy grail.
My personal opitnion for a front wheel would be a trispoke if it's sufficiently stiff for your needs. Barring that, a deep dish wheel with lower spoke count, although it would probably be just as fast as the trispoke. For a heavier guy like me, I would steer clear from the original trispoke (HED, Specialized) as i found them flexy, especially on steeper tracks.
taras0000 is offline
Old 09-03-19, 12:18 AM
Baby Puke
Quoted: 365 Post(s)
Dang. At this point one second off my kilo would put me in "ok now I can quit" territory as far as goal times achieved!
Old 09-03-19, 03:11 AM
Dalai
Quoted: 89 Post(s)
Sorry, steady state gains Babypuke... Time gain was posted years ago by Alex Simmons compared to old Shamal /808's and not from my testing.
When I went into my local tunnel it was with the TT bike. Dabbled with some curiosity tests at the end of my session. Bottle position, clothing (skins was a quick pull on to test full legging material if aero benefit) and a few others just to use up my last minutes.
Dalai is offline
Old 09-03-19, 01:33 PM
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Yes.
Unfortunately, I don’t have my 808’s anymore. Sold them to a fixie kid (my world has come full circle).
I have some 33cm Alpina and 34cm Nitto bars if you want to test those.
I’m on my mobile phone now and haven’t read the entire thread.
I’m happy to send a few bucks to help offset the expenses.
carleton is offline
Old 09-04-19, 06:44 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Originally Posted by carleton
Yes.
A2 does have a number of wheels to test (although I'm not sure on specifics. An 808 is likely though. I do know they don't have any track specific wheels like an iO)
Some things to think of (for everyone, not just @carleton) is say I test 33cm Alpina's and 34cm Nittos. How would you want them tested? Rider off the bike? Rider on bike? How would we feasibly account for the difference in reach and drop between two sets of bars? If you don't account for it, then the 1cm difference will be swallowed up in the rider's position changing.
Lets say I borrow an iO and an 808. What tyres will make the test fair? An iO (besides the Rio) wants a narrow tyre, like 19mm... but that won't match the profile on a Firecrest or newer 808. What if the wheel I borrow already has a tyre glued to it, but not the optimal one? Or the 808 I borrow is a clincher?
Just some things to consider.
Thank you for the offer as well @carleton. I'm not sure if the interest is there as a whole... but it's not unprecedented to have a sort of crowdfunded tunnel session. link
The problem (morally at least, to me) is that if I took anyone's money, it would have to be a bigger *scope* project than just tacking it on to the end of my own personal testing. To control so many variables would take a bigger team than just me, the tunnel operator and my handler/eyes/runner.
Triathlon world there is that kind of interest to support a project like that, not sure about the track world though.
Morelock is offline
Old 09-05-19, 03:13 AM
carleton
Elitist
carleton's Avatar
Well, since this isn't a proper scientific study that's gonna be peer-reviewed, I think if you designed a basic test for every scenario you want to consider, I think the audience will be pleased. Hell, designing a test is a significant exercise in and of itself.
Basically:
- Don't overthink it.
- Don't make work for yourself.
- It's your time, money, and energy do what you think is best...and feasible.
Also, if you did design a series of tests in order to be peer reviewed and accepted, you should get paid in either cash or college credit. I've always wondered why this hasn't been tackled by some Masters or Ph.D. candidate.
When Lee Childers, Ph.D. was still a candidate at Georgia Tech and a regular at DLV, he gave this presentation that I attended:
https://math.gatech.edu/seminars-col...lders-20100120
The Biomechanics of Cycling for Bike-Geeks - Going from Zero to Hero with a Turn of a Hex Key
Cycling represents an integration of man and machine. Optimizing this integration through changes in rider position or bicycle component selection may enhance performance of the total bicycle/rider system. Increasing bicycle/rider performance via mathematical modeling was accomplished during the US Olympic Superbike program in preparation for the 1996 Atlanta Olympic Games. The purpose of this presentation is to provide an overview on the science of cycling with an emphasis on biomechanics using the track pursuit as an example. The presentation will discuss integration and interaction between the bicycle and human physiological systems, how performance may be measured in a laboratory as well as factors affecting performance with an emphasis on biomechanics. Then reviewing how people pedal a bicycle with attention focused on forces at the pedal and the effect of position variables on performance. Concluding with how scientists working on the US Olympic Superbike program incorporated biomechanics and aerodynamic test data into a mathematical model to optimize team pursuit performance during the 1996 Atlanta Olympic Games.
Not sure if it was his thesis or not (not sure how that works). It was a great presentation, though.
Ha...just found the PDF of the presentation.
carleton is offline
Old 09-05-19, 05:06 AM
100bikes
Industry guy
Bikes: To many to name - I ride a custom built steel frame.
Quoted: 115 Post(s)
Liked 80 Times in 48 Posts
I would really be interested in noting the wind resistance and aero effects in the difference
of riding in "street " apparel vs a cycling kit.
Generally see a lot of riders with high end equipment, weight conscious and aero, wearing
non-form fitting , floppy clothing for cycling.
Disc wheels and carbon bits......
Have been curious for many years on this one.
rusty
100bikes is offline
Old 09-06-19, 07:23 AM
burnthesheep
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times in 974 Posts
I hate making suggestions on stuff like this as the person probably knows 10000x what I do about it.
But, I'm genuinely curious in the balance of CRR and aero between a 23mm on front versus a 19mm.
I'm not in a budget to afford the newer stuff and wonder what I throw away in CRR and practically applying power comfortably on a 19 versus what I could with a 23.
Not sure how you'd objectively do that though given your swap on the disc wheel and wheel swaps being a limiting factor.
Just a curiosity I've always had.
In terms of something easier to test? I've also wondered whether stacked hands is only a "high hands" trick or could also work out with lower hands.
Even if I think I ride with higher hands, it's not even close to what the modern fits are doing. If the road is smooth for a while I'll stack em. But wonder if it is worth it or not since I'm not "that high".
burnthesheep is offline
Old 09-08-19, 01:47 PM
RChung
Perceptual Dullard
Quoted: 915 Post(s)
Liked 1,143 Times in 490 Posts
If that happens, give a shout out. I have a few ideas.
RChung is offline
Old 09-09-19, 08:25 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
rusty
quite a few tunnel tests / info on clothing comparing "standard kit" to skinsuits. From normal cut bibs/jersey to a good skinsuit you're looking at 90-150sec / 40k. Sort of depends and ebb/flows, as regular "kit" has gotten more "racy/aero" over the last few years... but also the top end skinsuits have gotten faster.
Morelock is offline
Old 09-09-19, 08:38 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
On a super smooth track there isn't a ton of balance between 19 and 23. It's heavily in favor of the narrowest tyre that reasonably fits your rim, since you want pressure to be insanely high anyways. On less ideal conditions it just really depends. Follow Josh's (Silca) advice for the most part and it should land you at least in good shape.
As for hands... I've tested it in the past (twice) in different trips and different positions. Stacking hands was never best in any of my positions. Possibly you need to almost stack the forearm on top of each other as well... or maybe it just looked cool when Zabriskie/Wiggo did it and we all assumed it was fast.
It's something I will probably look at (again) if I've got time.
Morelock is offline
Divebrian
5
12-22-16 07:04 AM
Banchad
27
02-22-16 12:39 PM
Cantrackie
20
05-04-15 11:45 AM
sakkakth
24
02-26-12 06:22 PM
Hammonjj
"The 33"-Road Bike Racing
13
04-27-11 08:19 AM
