Running 27x1” tires on 27x1 1/4” wheels
Quoted: 6178 Post(s)
Liked 4,796 Times
Are you saying your wheel inside width is about 32mm wide? Or do you have a wheel that has a 27x1¼ tire on it and mistakenly think that means anything for the question you ask?
Without knowing the inside width of your rim, preferably in millimeters, then we'd really be guessing. Sometimes that is on your wheel rim somewhere or maybe with the model number of your rim and some searching we'd know.
mmm no im saying the tires i want to throw on these old 27x 1 1/4” rims are slightly more narrow because they are 27x1” tires. The inside rim width is more like 17mm
[Q
UOTE=Iride01;21711349]Are you saying your wheel inside width is about 32mm wide? Or do you have a wheel that has a 27x1¼ tire on it and mistakenly think that means anything for the question you ask?
Without knowing the inside width of your rim, preferably in millimeters, then we'd really be guessing. Sometimes that is on your wheel rim somewhere or maybe with the model number of your rim and some searching we'd know.[/QUOTE]
[Q
Really Old Senior Member
I can't imagine any problem.
ASSUMING hooked rims, because you will have to run higher pressure to avoid pinch flats.
Harsher ride.
Harsher ride.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Sure. If they're steel rims without bead hooks, I would be wary of trying to achieve the maximum pressure that a 1" tire would have on its sidewall, but apart from that you should be fine.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4336 Post(s)
Liked 2,977 Times
The only way to know for sure is to put 'em on, and press 'em up until the bead blows off with a load explosion. Then remount with a new tube and use a little less pressure.
Liked 2,563 Times
Yep! I recommend earplugs.
Quoted: 581 Post(s)
Liked 921 Times
I would be worried of problems if the rim is wider than the tire when mounted, but that is unlikely. As long as the tires are at least as wide as the rims (preferably a bit wider) then you are good to go.
