Maximum lumens of flashlights using AA or AAA batteries?
Old 12-20-12, 01:01 AM
vol
Liked 18 Times in 12 Posts
Does anyone have idea about the maximum lumens a flashlight is capable of, which uses several AA or AAA batteries? I have one that claims to be 800lm but obviously much less in reality, however I have no idea how many lumens it actually has. If I know the maximum lumens, I'll know all those claiming more than that are lies, and that if I want brighter ones, I can't expect to use AA/AAA's.
vol is offline
Old 12-20-12, 07:16 AM
bud16415
bud16415's Avatar
Quoted: 37 Post(s)
Liked 3 Times in 2 Posts
I don’t think it works that way. It will depend somewhat on how many batteries are used and at how fast of a discharge rate they will be used up at.
Someone might know the light output of some of the common lights that use those size batteries though. Seems like most things today plaster specs all over the package hoping to have you pick one that’s a little higher.
bud16415 is offline
Old 12-20-12, 08:57 AM
Looigi
Looigi's Avatar
Quoted: 14 Post(s)
Liked 13 Times in 12 Posts
Yes. bud16415 is right. There are other variables as well. Check out these sites that have beam comparison photos:
https://www.modernbike.com/light-comp...singleshotplus
https://reviews.mtbr.com/2011-bike-lights-shootout
https://reviews.mtbr.com/2013-bike-li...rd-beam-photos
https://www.performancebike.com/bikes...ghtBuyersGuide
https://road.cc/content/news/46538-bi...ghts-test-data
Looigi is offline
Old 12-20-12, 09:05 AM
cplager
The Recumbent Quant
cplager's Avatar
Bikes: 2012 Cruzbike Sofrider, 2013 Cruzigami Mantis, 2016 Folding CruziTandem
Quoted: 28 Post(s)
Liked 8 Times in 6 Posts
Just to add to the above answers, AA or AAA are effectively telling you how much stored power you have. If you put three AAA batteries in series, then you have 4.5V which can power some pretty bright lights. Just probably for not very long. Putting three in parallel means you have the same 1.5V as a single battery, but it will last longer (than a single battery).
cplager is offline
Old 12-20-12, 10:44 AM
cycle_maven
Collector of Useless Info
Volts is different from stored energy. Nowadays, a buck-boost power supply used to supply a modern LED light takes in watts (more current at lower voltage and less current at higher voltage) and puts out watts. There are many types of LED's that you can drive with different wattage, but the common high-efficiency single LED's can be driven at 3-5 watts typically and put out different lumens for that power input.
Alkaline AA batteries have about 1.5 watt-hour of storage capacity each. Lithium have more for the same size.
cycle_maven is offline
Old 12-20-12, 02:55 PM
Looigi
Looigi's Avatar
Quoted: 14 Post(s)
Don't forget the effect of the equivalent series resistance (ESR) of different types of batteries. The higher the current the more power is wasted in battery. There is a wide variation between types of batteries. Carbon zinc are very bad, alkaline are better, NiCd and NiMH are much better, and LiPo and Li Ion are way better in the max currents they can delivery.
Looigi is offline
Old 12-20-12, 03:13 PM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
https://www.intl-outdoor.com/cyclone-...ght-p-349.html
https://www.intl-outdoor.com/jetbeam-...ght-p-272.html
https://www.intl-outdoor.com/nitecore...ght-p-650.html
https://www.intl-outdoor.com/sunwayma...ght-p-199.html
davidad is offline
Old 12-20-12, 04:24 PM
vol
Thanks for the replies. Thanks for all the links. From the pictures, it seems my "800LM" is only around 300LM. It's good to know, from the links by davidad, that 3xAA can achieve >900LM (I did notice this note: "Alkaline batteries should be used on Low and Medium modes only, due to high internal resistance."). They are also based in China, so wonder how reliable their lumen claims are.
vol is offline
Old 12-21-12, 11:49 AM
ks1g
Because I thought I could
ks1g's Avatar
Bikes: November, Trek OCLV, Bianchi Castro Valley commuter
More complicated than that - beam pattern determines where the lumens (technically, photons) the LED is emitting wind up, and if they are doing you any good. Hence a "300L" light may be more useful than an "800L" model. At least across different vendors. Within a single source (at least those that want to be in business for a while), bigger may actually be better. Also possible to be too big (turn night into high noon on technical singletrack probably >> for use on suburban bike paths). Re: "based in China" and "reliable claims" do not belong in the same sentence unless modified with "not", "un", or equivalent negation.
ks1g is offline
Old 12-21-12, 12:56 PM
Looigi
Looigi's Avatar
Quoted: 14 Post(s)
Originally Posted by ks1g
lumens (technically, photons) .
Nope. Units are different.
Looigi is offline
Old 12-22-12, 07:26 AM
Don in Austin
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
I have had it with AA or AAA batteries for my bike lights. USB rechargeable is the way to go.
Don in Austin
Don in Austin is offline
Old 12-22-12, 09:58 AM
Burton
Certified Bike Brat
Burton's Avatar
Quoted: 5 Post(s)
Liked 6 Times in 6 Posts
I think you'd have better luck just sticking with reputable sellers. The maximum lumen output is determined by the LED model and BIN designation and the level to which its driven. The suitability of using AAs or AAAs is dependent on how the light engine is designed - not the LED itself.
My situation is a little unusual in that the light engines in my 10W lights are designed to accept a 12V input, but that was one reason I picked them. Higher voltage requires fewer amps to produce the same wattage and AA cell have no issue keeping up with the amperage requirement needed to supply less than 1amp at 12V.
And since I still keep about 50 rechargable AA cells kicking around for other uses - I can drop 10 of them in a plastic battery pack case designed for a radio and use it to power a 10W headlamp for 4 hours. Actually it'll power two for a while, and thats over 1,600 lumens. So better not to use batteries to decide if lumen output is exaggerated or not.
Burton is offline
Old 12-22-12, 10:44 AM
wirespot
Bikes: MTB commuter
And just to cover all bases, I'd like to point out cooling as well. Some lights are better designed in this regard than others. LED's which are properly cooled run more efficiently.
wirespot is offline
Old 12-22-12, 01:53 PM
davidad
Quoted: 582 Post(s)
Intl-outdoor seems to be trusted by the folks on Budget light forum.
Some of the figures are at the LED and some are out-the-front. You need to research Cree to find out which the manufacturer is using.
1200 to 1800 lumens from a single XM-L is not possible.
davidad is offline
Old 12-22-12, 11:32 PM
vol
Seems most of you don't mind having to recharge the batteries frequently? I don't feel like having to remember to charge batteries before a ride. It takes hours to recharge, and you have to take care not to overcharge. Do you guys just plug in batteries into your computers every day as a habit?
vol is offline
Old 12-23-12, 08:52 AM
Burton
Certified Bike Brat
Burton's Avatar
Quoted: 5 Post(s)
Personally I hate wondering if I have enough tuntime so deal with battery capacities that mean I might have to charge once or twice a week max. Not only do I get more piece of mind - the batteries will last longer too. So USB devices with a run time of two hours or less aren't something I like myself.
Burton is offline
Old 12-23-12, 09:25 AM
I6pwr
I have one of these and 215 lumens is extremely bright. There are many models that are brigher.
Fenix
I6pwr is offline
Old 12-24-12, 07:31 PM
hhnngg1
Quoted: 50 Post(s)
Complicated physics and optics aside, I'd love to see a 2 x AA flashlight brighter than the Fenix L2D
hhnngg1 is offline
Old 01-02-13, 03:43 AM
smasha
Vegan on a bicycle
smasha's Avatar
Quoted: 114 Post(s)
Liked 22 Times in 22 Posts
https://en.wikipedia.org/wiki/Luminous_efficacy
anything that claims to produce more than 683 lm/W is science fiction. as a point of reference, an XML T6 is about 40% efficient, producing about 270 lm/W.
the battery type and number of batteries (chemistry, voltage, Ah, etc) will dictate how much power is available to the light, and how long that power will last.
then there are losses on the optics, the electronics, the batteries, the LED, the contacts...
smasha is offline
Old 01-02-13, 06:38 AM
Burton
Certified Bike Brat
Burton's Avatar
Quoted: 5 Post(s)
The references in that Wikipedia link are already 3 years old, but regardless - I'd jump on any 10W light that was producing 683 lm/W - or even 270 lm/W!
Burton is offline
Old 01-02-13, 07:37 AM
smasha
Vegan on a bicycle
smasha's Avatar
Quoted: 114 Post(s)
don't worry about the date... it's still a physical fact that 1W of electrical energy at 100% efficiency can produce, at most, 683 lm.
generally, as power and heat increases, LED efficiency decreases. that's why the 10W LEDs will be less efficient than 2-3W LEDs.
smasha is offline
Old 01-02-13, 09:49 AM
vol
So, does it mean alkaline AA/AAA are less powerful in producing lumens?
vol is offline
Old 01-02-13, 11:53 AM
smasha
Vegan on a bicycle
smasha's Avatar
Quoted: 114 Post(s)
numbers from wikipedia...
AA - Alkaline batteries - 1.5V from 1700 - 3000 mAh (up to 4.5Wh)
AAA - Alkaline batteries - 1.5V from 250 – 1200 mAh (up to 1.8Wh)
18650 - li-ion - 3.7V from 2200–3400 mAh (up to 12.58Wh)
in other words, an 18650 can hold a lot more energy (and produce more light, for longer) than AA or AAA batteries.
smasha is offline
Old 01-02-13, 12:05 PM
Burton
Certified Bike Brat
Burton's Avatar
Quoted: 5 Post(s)
I was trying to pull your leg a bit. AFAIK we still haven't reached the theoretical limit for LED output which is quoted in that article as being only 260 to 300 lumens per watt, which is quite a bit less than the numbers you posted. So if you know where I can get any of those super emitters you've referred to - I'm in!
Burton is offline
Old 01-02-13, 12:11 PM
Burton
Certified Bike Brat
Burton's Avatar
Quoted: 5 Post(s)
Thats a bit like saying since a quart is smaller than a gallon - a gallon is better. AAs and AAAs are physically smaller than 18650 batteries - of course they hold less energy! It takes more of them to do the same job, but it still breaks down to total watt hours, and I have no problem running 10W LEDs off AA cells. More batteries to charge, and heavier than lithium, but no other issues.
Burton is offline
