Yet another Nexus Slipping [but only in 5th] Thread
Quoted: 20 Post(s)
After looking over so many threads about Nexus 7/8 hubs slipping/skipping gears, I still don't really have a good sense of what's going on with mine or if it can be improved! I've got a Breezer Downtown with Nexus 8 hub and matching twist shifter, got about 500 miles on it. At about 100 or 200 miles, I noticed it slipping but only in 5th gear, and it's only been getting worse since then. It's not skipping to another gear, just popping out of gear entirely for 1/4 rotation then catching again. Happens even when I'm applying only moderate pressure, and sometimes it happens every couple of minutes that I'm in 5th. No odd bends in the cable; yellow adjustment marks are perfectly aligned (when in 4th). At about 300 miles I gave the hub a dip in 90 weight gear oil. Is there something about the design of this hub that would cause this problem to happen only in 5th? Any fixes to try? And is the hub mechanism at risk of becoming more damaged over time from all of this hard slipping?
Quoted: 20 Post(s)
From an old thread,
and Does this mean that in 5th, with no pawls involved, the roller clutches have to hold more force than in other gears? I wonder if my gear oil is too viscous, or if it has washed away the grease that I put on the outer bearing rings, thereby becoming even more viscous, and messing up the roller clutch operation?
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
I have a Nexus 8 in my 2013 Norco that I bought several months ago. I normally ride it in 6th gear, but drop to 5th to start out at some standing starts.
I did do a hub service back in April this year with materials I already had in my garage. I flushed the hub with ATF, let that drain, greased the bearings with automotive bearing grease, and filled the hub repeatedly with 85W140 gear oil. You can read some of my trials and tribulations here. https://www.bikeforums.net/bicycle-m...e-arrrrgh.html
In my case, my Nexus 8 works the same as before. Which means if I don't do a few degrees of backpedal during a rolling shift, the hub may make popping noises as if a pawl is skipping. It will also make very slight whirring noises which I can make go away by another slight backpedal to "find another spot" in the bearing clutch engagement (I'm guessing here).
So far, 5th gear works fine in my hub. Even if I stand up to pedal to from a standing start, which I don't think we're supposed to do with Nexus 8s.
Last edited by FiftySix; 08-15-19 at 06:27 AM. Reason: changed "after" to "during"
Senior member
Quoted: 943 Post(s)
Liked 659 Times
From an old thread, and
Whenever any of the three sun gears are engaged, power is transmitted to the high speed roller clutch, and the direct drive clutch is simply over run.
Quoted: 20 Post(s)
No. In 1st and 5th, it is the outer roller clutch on the left side that drives the hub. This is because none of the sun gears in the planetary carrier are engaged, so no power is transmitted to the high speed roller clutch.
Senior member
Quoted: 943 Post(s)
Liked 659 Times
If the shifter adjustment is off even slightly, the clutch could get hung up on the ramps preventing full engagement.Once the shifter is moved to the 6th gear position, the clutch tabs are well clear of the ramps permitting full engagement.
Likes For Dan Burkhart:
Lifelong wheel gazer ...
Bikes: All garage sale finds...
Quoted: 72 Post(s)
Liked 36 Times
Interesting reading, this. And perhaps fortuitous for me.
The only reason I've not pulled the trigger on a Motobecane Elite with the Nexus hub is that I've been so busy lately with work that being settled for a delivery is a problem.
How commonplace is the type of issue that I'm reading about in this discussion?
Current bikes: Unknown year Specialized (rigid F & R) Hardrock, '80's era Cannondale police bike; '03 Schwinn mongrel MTB; '03 Specialized Hard Rock (the wife's)
Gone away: '97 Diamondback Topanga SE, '97 Giant ATX 840 project bike; '01 Giant TCR1 SL; and a truckload of miscellaneous bikes used up by the kids and grand-kids
Status quo is the mental bastion of the intellectually lethargic...
I'm the anecdote.
Liked 1,176 Times
Between 4th and 5th gear the clutch transitions from being disengaged from the planet carrier, to engaged which bypasses the low range reduction unit. At the 9:40 point in the attached video is an explanation and demonstration of how the clutch engages.
https://www.youtube.com/watch?v=_Q5iEywX3yM
Likes For FiftySix:
Quoted: 20 Post(s)
Interesting reading, this. And perhaps fortuitous for me. The only reason I've not pulled the trigger on a Motobecane Elite with the Nexus hub is that I've been so busy lately with work that being settled for a delivery is a problem. How commonplace is the type of issue that I'm reading about in this discussion?
Quoted: 20 Post(s)
Senior member
Quoted: 943 Post(s)
Liked 659 Times
If the problem persists, an oil bath lube job may help.
Quoted: 20 Post(s)
I would not advise mis-adjusting the alignment marks in an attempt to get the clutch to engage, because it could cause worse problems. The adjustment is most critical to ensure the pawls that couple the sun gears to the axle are fully extended in each gear position.
Thank you for the sage advice, Dan; I really appreciate all the effort that you put into helping cyclists understand and fix their bikes.
Senior member
Quoted: 943 Post(s)
Liked 659 Times
Well, shoot; I guess there's very little that I can do to try to solve this. I will definitely give it another oil bath and keep my fingers crossed, but I'm feeling like I'm probably going to end up replacing this bike a lot earlier than I had anticipated
Quoted: 20 Post(s)
Quick update. I pulled the guts out, found that the oil had mixed with the grease (that I had applied on the ball bearings) and created a uniform sludge over everything. After cleaning and relubing (90 weight gear oil bath, grease on bearings), it's now back together and no longer slipping in 5th , so I'm going to put the whole problem down to improper lubrication that was apparently preventing the clutches from properly engaging. I didn't think of it until after reassembling, but next time I'm going to not put grease on the large bearing race, since that one should get sufficiently lubricated by oil. And if I still find that the grease is getting washed off the small bearing race, I'll conclude that that one also is sufficiently lubricated by oil and I'll leave the grease off that one as well.
Likes For mc510:
Quoted: 981 Post(s)
Liked 584 Times
Skipping the grease probably will be OK if the oil dip is done with some frequency, but I'd recommend being careful if the bike is ridden in wet weather. The only water-related problems I've had were on a Nexus 7 speed hub which had water incursion on the drive side, resulting in some (fortunately) superficial rusting of the race. I think grease provides better protection against water than the oil does.
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 509 Times
I’ve got two bikes with Shimano 8 speed hubs. Both have different part numbers marked on the outside of the hub. The Shimano repair manual specs different lubricants for each.
SG-8R31 on my Biria needs special grease. No dipping in oil.
SG-C6001-8R on my Linus specs dipping in LU8408 WB lubricant.
The 8R31 hub is on it’s 5th year of almost daily riding. I’ve lubed it once, due for a second. No problems. The C6001-8R hub has not been serviced yet. I intend to use the Shimano lube to avoid problems that have been described. Products are available from Universal Cycles.
Fiddling with the adjustments is a good way to frustrate yourself as you make things worse. I know. Set it properly and ride.
everytime this topic comes up it starts off negative. Like this one did. I don’t understand it. My experience is adjust it properly, use the right lube and follow the procedures and these hubs will ride beautifully for a long time. Thanks.
Quoted: 981 Post(s)
Liked 584 Times
My first Nexus-8 had the black "Nexus grease" (same as on two Nexus-7 hubs) when I first opened it, so I was surprised when I opened the newer ("red-band") Nexus-8 and found it covered in a white lithium-type grease. I've been dipping both hubs annually in a synthetic gear oil and greasing the bearings with the Nexus grease. The hubs have been working fine for at least 10 years. The gear oil is Royal Purple 75W-140, which I've been using in my Alfine-11 for the last 7,000 miles.
Quoted: 981 Post(s)
Liked 584 Times
There's not a lot of oil running around in the hub, since the hub gears are allowed to drain for a few minutes after dipping. The gear oil (75W-140) has some viscosity and coats the gears pretty well. Still, after a year some of the grease does get mingled with the gear oil. This doesn't hurt the gears, and the bearing races remain un-worn except for a polished ring where the balls contact them.
As far as I can tell, the "Nexus grease" (the black kind) is some kind of moly lube. I wouldn't hesitate to use a good wheel bearing grease (maybe "marine grade") if I didn't have the "official" stuff.
