Gunnar Hyper XF - new bike day!
Old 04-22-19, 08:55 AM
KeatonR
Bikes: Gunnar Hyper XF, Jamis Dragon Race, Surly LHT
Quoted: 24 Post(s)
Liked 19 Times in 9 Posts
Turning 50, and so for the occasion went all in on this (or I should say, my wife did — I am lucky).
Ultegra drivetrain, Mavic Allroad Pro wheels.
KeatonR is offline
Old 04-22-19, 09:22 AM
Secret Squirrel
Quoted: 93 Post(s)
Liked 35 Times in 21 Posts
Nice bike. I just got my 50 bike in August. Same wheels and tires
Secret Squirrel is offline
Old 04-22-19, 09:43 AM
Hondo Gravel
Life Feeds On Life
Hondo Gravel's Avatar
Bikes: Too many Motobecanes
Quoted: 4405 Post(s)
Liked 4,520 Times in 3,022 Posts
Awesome bike! Tell us about some of first rides.
Hondo Gravel is offline
Old 04-22-19, 09:50 AM
shoota
shoota's Avatar
Quoted: 1872 Post(s)
Liked 692 Times in 468 Posts
Sick color dude. Turn the front tire around.
2019 Salsa Warbird
shoota is offline
Old 04-22-19, 09:51 AM
KeatonR
Quoted: 24 Post(s)
Will report back this weekend. Can’t wait to log some miles on this thing.
KeatonR is offline
Old 04-22-19, 09:54 AM
KeatonR
Quoted: 24 Post(s)
It looks wrong, I agree, but that’s how Mavic says to run the front one.
KeatonR is offline
Old 04-22-19, 09:55 AM
shoota
shoota's Avatar
Ok well that's bizarre. I'd love to hear why.
2019 Salsa Warbird
shoota is offline
Old 04-22-19, 10:04 AM
KeatonR
Quoted: 24 Post(s)
this thread sheds some light on the matter:
Gravel Cycling Forum | Riding Gravel
one commenter there said he was going to reverse it to avoid further comments about it being backwards, ha. In the end it probably doesn’t matter too much, since it’s a not very aggressive tread pattern anyway.
KeatonR is offline
Old 04-22-19, 10:07 AM
shoota
shoota's Avatar
HA! Now that is funny. I'd probably install them the same way too, my OCD wouldn't allow two different directions.
2019 Salsa Warbird
shoota is offline
Old 04-22-19, 10:23 AM
riverdrifter
riverdrifter's Avatar
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 170 Post(s)
Liked 277 Times in 108 Posts
Beautiful bike! Congratulations!
riverdrifter is offline
Old 04-22-19, 10:27 AM
Secret Squirrel
Quoted: 93 Post(s)
I ran this tire with the Mavic recommended direction for about 100 miles and then turned it around for another hundred (mixed road conditions). I did not notice any difference. The tread pattern is really tight. Running Gravel King slicks for a change.
Old 04-22-19, 10:38 AM
LeFreakyBone
Bikes: BMX – FBM Gypsy; Gravel/Adventure – Rodeo Labs Flaanimal 4.1; Mountain – Santa Cruz Bronson CC X01
Quoted: 17 Post(s)
Liked 18 Times in 6 Posts
I have pretty aggressive dual sport tires on my motorcycle and the front is installed in the "reverse" direction like this. I hear it has to do with better braking performance. Besides the obviously different amount of force required for braking, I am wondering if it is the same concept here.
LeFreakyBone is offline
Old 04-22-19, 11:20 AM
gus6464
Quoted: 353 Post(s)
Liked 92 Times in 67 Posts
That is common in motocross. Same tire front and rear mounted in different direction.
gus6464 is offline
Old 04-22-19, 11:58 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10943 Post(s)
Liked 7,469 Times in 4,179 Posts
Really nice looking bike. Its a rare day that I see NBD threads and immediately click into them, but this is one time where I did because of the title. Funny to see the tread like that, as others mentioned- that was one of the first things I saw since the opening pic has the tread in the foreground. Wild.
What is the 303 sticker?...is that what they call their own mix of tubing?
Also- those are 40mm tires, right? how much clearance on the rear?
mstateglfr is offline
Old 04-22-19, 12:49 PM
Chi_Z
Chi_Z's Avatar
Bikes: Niner RLT 9 RDO
Quoted: 263 Post(s)
Liked 69 Times in 50 Posts
should have spend the extra $300 for made to measure, the frame stack is clearly too low for you
Chi_Z is offline
Old 04-22-19, 02:11 PM
KeatonR
Quoted: 24 Post(s)
The 303 sticker is from the local shop that built it up for me, Vecchio's in Boulder.
Those are 40mm tires, yes. And there's still plenty of room left in the back. I'll take a pic.
KeatonR is offline
Old 04-22-19, 02:13 PM
KeatonR
Quoted: 24 Post(s)
No, that's just a starting point for me. The shop set it up based on the dimensions of my previous bike, but I'm aiming to flip the stem over at the very least. I just want to get some miles in on it first.
On the other hand, I am turning 50, so ultimately I'll go with comfort over aesthetics.
KeatonR is offline
Likes For KeatonR:
Old 04-22-19, 02:20 PM
mstateglfr
Sunshine
mstateglfr's Avatar
makes sense- 303 area code. i thought that for a second before remembering the area code for Waterford WI. Then figured it might be what Gunnar calls the tubing since from afar it looks similar to a Reynolds tubing # sticker.
thanks for the pic in back- i think Richard Schwinn said a 42mm tire is the max, but wasnt sure if thats really conservative or what.
Old 04-22-19, 02:23 PM
Chi_Z
Chi_Z's Avatar
Quoted: 263 Post(s)
that was my point, with higher stack frame you can move the bar even higher, currently you are already at the 40mm spacer limit for Enve fork, going higher you risk snapping the carbon steer
Chi_Z is offline
Old 04-22-19, 02:30 PM
KeatonR
Quoted: 24 Post(s)
My point is that if anything I'll go lower.
I looked around at a lot of steel frames, and this one already has one of the tallest head tubes, so I didn't really think I needed to go any taller there. But you're right, at the moment I'm at the limit.
KeatonR is offline
Old 04-22-19, 03:20 PM
KeatonR
Quoted: 24 Post(s)
Here’s how the fit looks. The tires are 40s, as I said, but they’re on rims with a 22mm internal width (pretty wide), so inflated width might be wider than 40. Either way, there’s room.
KeatonR is offline
Old 04-22-19, 05:18 PM
gus6464
Quoted: 353 Post(s)
I'd say you can comfortably fit a 45 Riddler in there.
gus6464 is offline
Old 04-22-19, 10:06 PM
GailT
Quoted: 107 Post(s)
Liked 22 Times in 14 Posts
Beautiful bike, love that colour. I bought a Waterford at Vecchio's a year ago - it was a custom frame, but it still has about same number of spacers as your bike. They built it with the handlebars near the top of the spacers, and I've gradually moved it almost to the bottom of the stack. It is nice to have the ability to move higher in the future, in case I have less flexibility when I'm older. So I think you did the right thing with the number of spacers.
My point is that if anything I'll go lower. I looked around at a lot of steel frames, and this one already has one of the tallest head tubes, so I didn't really think I needed to go any taller there. But you're right, at the moment I'm at the limit.
GailT is offline
Old 04-23-19, 05:31 AM
Koyote
Quoted: 6926 Post(s)
Liked 10,926 Times in 4,667 Posts
Nice bike -- I've got the same model (complete with the same Enve fork) on order right now. How long did yours take to arrive?
Also, you bought it from a great shop - Vecchio's is great.
Enjoy your birthday gift!
Koyote is offline
Old 04-23-19, 09:40 AM
gravelED
Quoted: 32 Post(s)
Liked 8 Times in 6 Posts
Beautiful bike. How do you like the Mavic wheels? I was looking at getting a set
gravelED is offline
