Best, Cheap Chains? How about them?
Quoted: 58 Post(s)
I busted a chain, and I don't know that this one that's on now from a parts bike will go the long haul. It's best to keep a spare there for the quick fix.
Are $10 chains worth it? $20 chains probably where real chains begin, eh. What's your experience?
Thanks
Thanks
Quoted: 18391 Post(s)
Liked 15,465 Times
Logic would dictate that going cheap on a chain is foolish.
Quoted: 169 Post(s)
Liked 84 Times
A well maintained chain should last a few thousand miles.
With my chains, the weakest link is going to be the quick link so I keep a quick link or 2 in my seat bag.
Quoted: 1221 Post(s)
Liked 626 Times
I just threw on some kmc 8 speed chain from my LBS bulk supply for $8, good enough for my 8 speed bike. On the mtb I did buy the fancy XT/Ultegra 11 speed chain for $30ish. Figured the extra coatings would help with the harsh environment my mtb is subjected to.
Liked 15,465 Times
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 335 Post(s)
Liked 220 Times
Ok, I'll bite. My experience is that all chains, if they're maintained are mechanically functional. The difference comes in weight savings as you move up in price.
If you're hard railing curbs (whatever that is), you'd probably be better off with a cheap basic chain over something designed for a higher groupset.
I could just imagine the post after you bust a 40 buck or more high end hollow pin chain.
Expired Member
Quoted: 3646 Post(s)
Liked 5,377 Times
DA, XTR, Record. You need the best for all that railin' and crackin' ....
Quoted: 1002 Post(s)
Liked 237 Times
Non omnino gravis
I have two bikes with 11-speed drivetrains, and exclusively use the SRAM PC-1110 chain, which is the cheapest 11-speed chain on the market. On Amazon they are typically $14-15.
I wax dip my chains, so I buy two at a time (so it's roughly the same cost as buying a single 11-speed chain of "higher quality," and rotate the chains throughout their lives. Pairs last 5,800-6,500 miles depending on conditions.
In the past for 11-speed I have tried: SRAM PC-1130, SRAM PC-1150, SRAM PC-X1, Shimano HG-CN701, KMC X11-93
Interesting to note that Bike Rumor posted a test where the Connex/Wipperman 11SX lasted over 3x as long as the PC-1110 in their tests. Would be neat to find out, but for the price of one 11SX, I can get five PC-1110s.
I somehow doubt a 11SX would last 15,000+ miles under even the best conditions.
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
I roll with mid grade KMC chains. I like their quick link design for ease of use. Even as a Clyde it's not a problem for me to get upwards of 5k miles out of one. I regularly get about 5k miles out of one of these. (regularly lubed with Finish Line Dry, checked with this Park chain wear tool.)
Works for me.
-Kedosto
Works for me.
-Kedosto
Likes For Kedosto:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Keeping a spare chain for a "quick fix" is fine but it is better to replace a chain at the end of its useful life before it breaks.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,095 Times
No chains. Buy local.
Ooops, wrong troll thread.
Likes For fietsbob:
Quoted: 942 Post(s)
Liked 526 Times
Non omnino gravis
I've used two Connex chains, a 10SB and an 11S0. They performed as a chain should, but did not shift any better or last appreciably longer than any other chain I've used.
I do a two chain rotation: I wax the first and install it, then drop the second chain in the wax and turn off the crockpot. Later, when it's time to rewax, I turn on the pot, and after the wax is melted, swap the chains. Chain maintenance is less than 5 minutes per month.
Two PC-1110s is under $30. Two of any other chain is going to be $60+. If there was a reason to spend more, I would.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), 90's Giant Innova (now with drop bars), Yess World Cup race BMX, Redline Proline Pro24 race BMX Cruiser
Quoted: 345 Post(s)
Liked 185 Times
KMC chains are great - the $10-15 chains for 6, 7 & 8 speed are plenty durable. Chains get far more expensive as they get narrower (ie. more 'speeds') with $80+ 12 speed chains.
Likes For Viich:
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
I've never broke a chain in 30 years of riding, so not sure how others are doing that. Anyway if you want a decent reliable lower costing chain go with the chain that has the brand of the components you use, those chains, like Shimano work really well, of course the expensive Connex chain is probably the best chain but how much longer will last over a OEM Shimano? maybe 20% longer? for a chain that cost twice as much? hardly seems worth it to me.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
Stick with brand name chains and you'll be fine. The big difference in price (once you get away from cheap department store or off brands) is in weight and finish. Shimano, SRAM, KMC, I've used them all over the years with about equal results. If you are looking to save bucks, go with the unplated, solid pin chains. They work fine and are plenty durable if you don't mind sacrificing a few grams and are vigilant about keeping your chain properly lubricated. There is really no purpose in putting a high-end chain on a mid-level bike and groupset.
Yep, you are about right. $20+ is where quality chains for 9sp and up start.
If you are really strapped for bucks, a bargain chain will get you by, but they don't save money in the long run compared to an entry level chain from a quality manufacturer. Your best savings is in proper maintenance and adjustment to maximize the life of a good chain.
Of all the places to save $10, a chain is not the first place I would choose. Brown bag it for two days instead.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Also, usually happens where you've 'broken' and fastened the chain by driving the pin with a chain tool (old-school style) and didn't get it set evenly. One side-plate gets loose, and that's all she wrote.
I've done it MTB'ing a few times, giving it a really hard, out-of-the-saddle full-weight slam to get some extra power to get over something, or get started after 'stalling out', always though, trying to muscle a too-big gear.
It has been a long time since i've broken one, though. I'm stronger and faster than i was 20 years ago, but i'm also smoother, and make better use of my gears. My bikes also all have quick-link chains on them, so driving pins is an emergency repair only.
Quoted: 324 Post(s)
Liked 81 Times
Stomping on a big gear will do it. Think about trying to make a fast 'track start' in your big gear.
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
depends on your drive train , i have all 10 speed , so i use sram red 11 speed chains or ultegra 10 or 11 speed chains , both about 35 bucks !!!
Quoted: 741 Post(s)
Liked 818 Times
I've been happy with KMC 8 speed chains on my 5 and 6 speed vintage. It improved shifting on one bike, but for some reason, seems to get hung between gears going from second big to big rear gear on my Peugeot. As a fluke, I picked up a couple of Sram 8 speed chains for $5 ea at a Performance "out of business" sale. If you're really cheap, watch the sales, but don't skimp on quality, unless you enjoy walking as much as riding. In 50+ years of cycling, I've never experienced a chain break, but I had a re-used link pin pull out during a ride. Used a rock to push it back in. When I got home, there was a new KMC in the mailbox, but I just couldn't wait to get the bike on the road.
I pay about 11,5€ for these kmc chains. My cassettes are also between 11,5 and 15€. last for about 3500km.
for 10 and 11 and 12sp i would get some middle of the road shimano chains since i have seen tests where these last a bit longer than the rest. these are lab tests though so they might only last as long as the rest in the real world.
