My stem is stuck
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
My stem is stuck
When I unscrew the top I can pull the rod all the way out and the wedge piece is stuck and I can’t move the stem at all. It’s crooked and I need to straighten it.
Heres a pic of the offending stem, and below it a pic of the type of wedge it is. How can I loosen it to get it out?
Quoted: 839 Post(s)
Liked 1,061 Times
Screw the bolt all the way into the wedge then loosen the bolt about 1/4". Tap the head of the bolt with a rubber mallet or a steel hammer with a block of wood to protect the bolt. This will push the wedge out. You may need to give it a few good hard whacks to get it to move.
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
Give the bolt a good solid whack, tapping may not work, you need to break the wedge loose from its taper.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
Rubber mallet worked. Took 2 decent whacks and could definitely tell when it popped out. Thanks! Should I put grease around the wedge and inside the stem? Or would that make it slip too much and not hold enough like it should?
Quoted: 148 Post(s)
Liked 119 Times
Anti-seize is your friend. Once you torque it down, most will displace except a little in the micro-valleys in the metal. That'll keep it from seizing (hopefully) but it will stay in place.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
-Kurt
Quoted: 148 Post(s)
Liked 119 Times
To add to that, try to keep the anti-seize on the top of the cone nut so it's not on the stem's mating surface with the steerer tube - but don't leave the stem bare either. I usually put a light coat of grease skimmed over the surface to prevent the steel steerer and aluminum stem from corroding together (once that happens, they're pretty inseparable).
-Kurt
-Kurt
Liked 4,395 Times
Hence, the careful approach when the situation calls for it.
-Kurt
P.S. to the OP: Super envious of that Raleigh Super Tourer. Would really like to find one someday.
Quoted: 839 Post(s)
Liked 1,061 Times
I'm with the grease crowd. Anti-Seize is a little more long lasting but is a big mess to clean off especially when it gets on your hands if you have to do a mid-ride adjustment. Either will work fine though.
Likes For Crankycrank:
Liked 4,395 Times
I consider that silver anti-seize a subliminal middle finger from the mechanics of the shop.*
-Kurt
*My breaking point was when they took off the chain guides on one of the bikes (it was a 7x1 that needed a crankset swap), and threw on another crankset without a bash guard or chain guides. Hey, dum-dum...kids are using these things. Chains WILL pop off.
Liked 1,092 Times
Rather than metallic anti-seize, which is intended primarily for high-temperature service like exhaust system studs and nuts, I use Tef-Gel, which contains PTFE (Teflon), and is specifically intended for use on dissimilar metal joints.
Likes For dsbrantjr:
siberia37
Bicycle Mechanics
7
06-27-12 06:40 PM
westBrooklyn
Bicycle Mechanics
10
06-20-10 08:14 AM
