650c tubes in 650b tires?
ambulatory senior
Quoted: 1953 Post(s)
Liked 3,634 Times
Anyone tried this? All i could find was either huge 650bs or 650cs in smaller widths. I used the 650cs and the were fine in town but after some fairly rough, loaded touring i was getting flats where i couldnt find any tire puncture or much of a hole in the tube. They seemed to last longer the lower they were inflated so i believe i have just over stretched the tube. Gonna find some 650b by 1.5
I’ve been using these.
Likes For natterberry:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4669 Post(s)
Liked 5,768 Times
26" tubes are what you're looking for. Even Compass Rene Herse (ground zero for 650b wheels and tires) sells Schwalbe tubes labelled as 26" for 650b use.
Likes For gugie:
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
I've been really impressed by those Schwalbe tubes. Pump them up outside of a tire and they expand very evenly, unlike some cheap tubes. Just make sure the valve core is tight before using them.
ambulatory senior
Liked 3,634 Times
Ty everyone!
Quoted: 500 Post(s)
Liked 464 Times
https://www.jensonusa.com/Park-Tool-...alve-Core-Tool
Likes For Dfrost:
ambulatory senior
Liked 3,634 Times
+1 on that! I spent a long time looking for a leak in a Schwalbe tube one night under a streetlight, until I finally realized that the core wasn’t fully tight. Now there’s a Park valve tool in each patch kit.
Liked 2,560 Times
It can be frustrating the first time it happens, but it's not a big deal to tighten down the valve cores (I don't even use a tool, just two pairs of pliers) right when you get brand-new tubes. It's my habit regardless of brand now.
Likes For ThermionicScott:
Liked 5,768 Times
Thanks Dave! And ThermionicScott for the idea of tightening down all your cores before installing. I just got through patching about 20 tires, and inflated them all for an overnight leak test. 3 didn't make it, water test showed 2 had leaky valves.
Likes For gugie:
Quoted: 3449 Post(s)
Liked 2,800 Times
Reading this , ya do know that 650c 571mm ERD and 650b is like 584mm ?
Liked 5,768 Times
Good point, interchangeable.
Liked 2,800 Times
while the original poster mentioned tubes... but complained about flats... just wanted to confirm there was not the anticipation that 650 c and b are the same rim diameter.... I have watched customers storm into a shop demanding there must be something wrong...
ambulatory senior
Liked 3,634 Times
Tubes folded dont last that well either. I eventually found the size i needed and the shop i work at will begin stocking them. Most new 27.5 bikes have much wider than 38mm or 1.5" tires.
Liked 5,768 Times
BITD I witnessed customers coming back months after purchasing a bike complaining that their tires were going flat, not believing that air molecules leaks very slowly through the tube rubber itself.
Likes For gugie:
Quoted: 3788 Post(s)
Liked 6,574 Times
Liked 5,768 Times
I probably shouldn't tell you about this one, then.
Damn good thing I stopped at 8.
Likes For gugie:
Señor Member
Quoted: 1491 Post(s)
Liked 1,071 Times
Some companies call 650B's 27.5's. I think that's stupid MTB terminology.
ambulatory senior
Liked 3,634 Times
Liked 5,768 Times
Russell, that's the size I typically buy for 650b x 42's.
Likes For gugie:
Liked 2,800 Times
Likes For repechage:
ambulatory senior
Liked 3,634 Times
Liked 6,574 Times
One problem with using tubes for 590mm applications is that they’re usually Schrader valve while all of my 650b wheels are Presta. And I don’t plan on drilling them out.
Then again, I seem to be mostly setting up wheels tubeless these days.
Likes For nlerner:
Bikes: Yes
Quoted: 3228 Post(s)
Liked 3,854 Times
It's simple, really. 27" > 29" == 28" > 27.5" > 26"
My Bikes
My Bikes
