New crank set and cassette help
Old 07-06-20, 08:31 PM
Jbrichar
Stripped down a trek 930 frame and going to get it powder coated. I want to rebuild it into a nice hybrid with Deore parts. Obviously the 3 x 7 original configuration is no longer and thinking of going to a 2 X 10 instead with corresponding derailleurs and shifters.
What issues will I run into? Bottom Bracket conversion? Enough space on the rear wheel to go to 10?
Thanks....
Jbrichar is offline
Old 07-07-20, 04:24 PM
DOS
DOS's Avatar
Quoted: 253 Post(s)
Liked 69 Times in 56 Posts
BB depends on what cranks you want to use but shouldn’t be an issue as long as you match up BB and cranks. As for rear spacing, all depends on what the current spacing of the dropouts is. But steel frames are pretty friendly to cold setting.
DOS is offline
Likes For DOS:
Old 07-07-20, 08:19 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,836 Times in 2,294 Posts
One issue recently in a thread here is the chain stay clearance with a double's inner ring. Do your homework and confirm any new purchase can be returned if you do the install. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 07-10-20, 04:14 AM
The_Joe
Quoted: 110 Post(s)
Liked 44 Times in 25 Posts
All good info mentioned above. You'll likely (definitely?) need a new rear wheel as your 7 speed freehub will be a bit too short for a 10 speed cassette.
The_Joe is offline
