Disc Rotor Sometimes Centered, Sometimes Not
Do you know why sometimes when I do up my rear thru axle the disc sometimes is perfectly centered and sometimes is more to one side? I can't seem to figure out what I need to do to get it centered again. I only touched the thru axle bolts.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I thought through-axles would help eliminate this kind of thing. I have conventional quick-releases, and this is a frequent occurrence. There seems to be quite a bit of potential slop when using drop-outs. The only suggestion I have is to use a torque-wrench and make sure you get the same (preferably recommended) torque setting each time you put the wheel on.
If it really bugs you, push the pistons all the way back into the calipers before mounting a wheel, and let them reset to the rotor after a few squeezes. If you make sure the slot of the caliper itself is centered on the rotor, I find it makes it more reproducible.
Likes For Cyclist0108:
Yes, after some trial and error I found that most times it's perfect, sometimes not. I'm not sure what exactly happens in the case where it's sometimes out of whack and what is causing that. I'm now using a hex key like this: https://images-na.ssl-images-amazon....AC_SL1000_.jpg
I go as tight as it will go without getting aggressive. This is getting me a good result. I have a maxle thru axle with a low max torque specification, so basically if I can't undo it with a mini tool then it's over-torqued.
Occam's Rotor
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
Quoted: 1572 Post(s)
Liked 642 Times
My bet is that you're flipping your bicycle upside down to install your front wheel. When you do that, sometimes you don't get the axle bottomed on both sides.
Occam's Rotor
Liked 2,331 Times
Liked 642 Times
So you're ASSUMING that it's seated and I'm GUESSING that it's not. Neither one of us can see what's really going on. The bottom line is that the OP isn't satisfied with how it's working right now.
Quoted: 6100 Post(s)
Liked 4,732 Times
Getting the disc centered on what? The pads? How much off?
Don't the pads float and center themselves to where the disc is once you actuate the levers a few times?
It's the rear wheel. Why would the bike being upside down make it more difficult to install the wheel correctly?
Likes For RowdyTI:
Likes For trailangel:
Liked 4,732 Times
Otherwise, I think it was some people trying to sell bike stands that started the rumor.<grin>
Likes For Iride01:
Occam's Rotor
Liked 2,331 Times
Some people are horrified if you turn a bike upside down. Don't know why. There were a few early hydraulic brake systems that it maybe played heck with air bubbles getting in the lines, but only one or two early ones.
Taking it in to a shop to see what they say. To the one who said the brake pads would adjust anyway, but then the gearing will be slightly out of whack if the wheel is mounted slightly different, and anyway I don't want to ride the bike if the wheel isn't perfectly mounted.
No my max nm is only 11, and that's probably with dry threads. That means about 7 nm with lubricated threads should be ideal.
Occam's Rotor
Liked 2,331 Times
I think the problem might be your pads, not the wheel, assuming you are replacing the wheel and torqueing the thru axle the same each time. If the caliper isn't centered about the disc, then the pads will retract asymmetrically, and less reproducibly.
To fix this, take the wheel off, pull out the brake pads, push the pistons all the way back into the caliper, put the wheel back on, tighten to exactly 11 Nxm with a torque wrench, then center the slot of the caliper, front and back, over the disc. Only then replace the pads, then pump the brakes to reset them.
When you next take the wheel off, just put it back in and torque it to 11. I think you will find the pads don't rub.
Take the wheel off, pull out the brake pads, push the pistons all the way back into the caliper, put the wheel back on, tighten to exactly 11 Nxm with a torque wrench, then center the slot of the caliper, front and back, over the disc. Only then replace the pads, then pump the brakes to reset them.
And you don't think the axle should be torqued less if the threads are well-lubricated?
Guys working on their cars had tissue with over torque after using anti-seize. The anti-seize they were using gave them 40% more torque at the same torque value.
Expired Member
Quoted: 3638 Post(s)
Liked 5,317 Times
Likes For shelbyfv:
Liked 4,732 Times
Sometimes the manufacturer in their installation instructions or other maintenance doc's will state whether to grease, not grease or even use anti-sieze (which is another form of grease for non-moving parts)
Occam's Rotor
Liked 2,331 Times
Wipe off the excess grease and torque it to the torque spec. if a greased thread were likely an issue, how probable is it that you are the first person to discover this potential problem, and that your irreproducibility has nothing to do with your decision to deliberately under-torque the thru-axle. You don't tighten it to spec, and the wheel positioning is problematic. The paralysis is striking.
But I agree, maybe you should take it to a bike shop.
What I found is that the disc is too far to one side of the frame when I don't push on the part of the frame at the drive train side. Every time I do up the thru axle without pushing the frame in on that side, it's not centered. It's centered every time, however, when I make sure to push on that part of the frame when I am doing it up. Since the bike was initially set up by a good shop, I'm guessing I should do up the thru axle that way versus adjusting the brake calipers to be centered when doing it up without pushing in that part of the frame.
Have you heard of anything like this?
I've also read:
If I do that without pushing in the part of the frame at my drive side, I'll not get a centered disc, same as if I do it up like that with the bike upside down. In my case the key point is pushing in the frame at the drive side.
Just wondering if this is normal or if I should adjust the disc rotor to be centered without this manoeuvre. Could this be the reason why I get some disc rub when I am cornering when going down hills?
I've also read:
I always put the wheel on the ground and compress the fork straight down loading the axle as I finish tightening it. This insures that the normal direction of force has already been applied and the wheel is completely seated. I've had the best luck with this method getting the wheel back exactly into its normal location.
