ISO and for trade thread part 5
#2026
aka: Dr. Cannondale
Quoted: 2151 Post(s)
Liked 3,380 Times
ISO crank arm bolt washer for a Campagnolo Record crankset; triple 10s UD (circa mid-2000s )
See washer in photo.
OD = 20.5 mm
ID = 12.7 mm
Thickness = 1.08 mm
I've been to two large LBS, a chain hardware store, a fantastic large old-school hardware store, and McMaster-Carr with no success.
The closest size to what I need is too thick and with a ID too small for the bolt to fit flush and secure.
OD = 20.5 mm
ID = 12.7 mm
Thickness = 1.08 mm
PM me your address and I'll drop them in the mail.
#2027
Señor Member
Quoted: 1491 Post(s)
Liked 1,072 Times
Found
I have, a fluted, 27.2 seatpost with a single bolt. I believe it is a LaPrade, but seeing no manufacturer marking, it may not be. From bottom to top it measures 160mm. From bottom to the bottom of the fluting, 80mm. There is some zig-zagging below the fluting, but only very little of this would be showing if adequately inserted.
Want - a non-fluted, silver 27.2 seatpost with either one adjustment bolt, or two (I do prefer two, but that's just a "tie-breaker"). I like the idea of fluted seatposts, but the fluting extends into the seat tube when the saddle is set at the proper height for me, which. I'm willing to account for value differential.
pictures:
pictures:
#2028
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
pictures:
pictures:
I should say one bolt seatposts. The seat pin was originally chromed steel with a clamp...
#2029
Señor Member
Liked 1,072 Times
While It's unlikely you'll want it, I have a 27.2 silver Kalloy single bolt seatpost that I'm not likely to use, since I replaced it with a black post. I'm not interested in a direct replacement, though I will be in strong need of a 26.4 seatpost longer than 250mm. Seatposts from the bike's era just weren't made that long...
Thanks...
#2030
The dropped
Liked 1,014 Times
That seems to be the case a lot around here!
#2031
Quoted: 1285 Post(s)
Liked 1,837 Times
So I went to my local Fastenal store today because like many here who need crank bolts and washers for Campy bottom brackets and arms. I was able to source 500 crank bolts that are grade 10 in the 15 mm size for the cap and with 8X1 pitch. The washers they had were sourced from the imperial catalog in a 3/8" inner diameter, with a .810" outer diameter. The washer height is 1/16" or 1.6 mm again I ordered 500. These will be very effective at replacing the lost bolts and washers for many of the BBs I come across. Will they say Campy? no. Will they hold the crank arm on? yes. So by next week, I will have then available to those who need them. HTH smiles, MH
Woo Hoo! Parts came in today! Will have them in my grubby little paws by this afternoon.
A minor glitch from Fastenal, the bolt cap is 13 mm. So they are sending special 8 mm washers that take the bolt cap to 16 mm to equal that of the original Campy bolt cap. appears to be the best solution. And it works!
Looks like I can send these out in pairs with washers for $6 plus shipping through USPS. Smiles, MH
Likes For Mad Honk:
#2032
Quoted: 3331 Post(s)
Liked 3,562 Times
ISO:
Dura-Ace 7700 (9spd) or 7900 (10spd) downtube shifters. Thanks nesteel !
Dura-Ace 7800 9/10 speed rear derailleur
I would prefer the 10 speed shifters, but 9 would work too.
Not looking for NOS, but not trashed either. They would be going on a rider. A nice rider, but a rider nonetheless.
Thanks!
Thanks!
#2033
Quoted: 189 Post(s)
Liked 472 Times
Looking for:
One Dura Ace 7400 single-pivot brake. Could be front or rear. Condition not too important - looking for small bits that go with it.
Campagnolo Super Record rear derailleur Pat. 83
Campagnolo Super Record brake set for 1983 bike
These are for a rider, but hoping to find something not worn down.
#2034
ISO 64-67cm Flexy Frame/Complete
I've got an itch to try out one of those noddley old road bikes some people seem to love. Something with Reynolds 531c, Tange 1, or other standard diameter 8-5-8 or lighter tubed bike. Anyone have something lying around I could snag?
I ride my saddle height at 83.5cm for context, so I'd be looking for somewhere between 64-67cm frames.
If it's all beat up, that's probably better since I'm not sure I want to commit to something fancy. Hoping to find something for around $200ish
Let me know if you have anything or if you see something pop up.
Tim O.
Portland, OR
Tim O.
Portland, OR
#2035
Señor Member
Quoted: 284 Post(s)
Liked 293 Times
I’ve got a Miami Vice Ironman (Tange 1) with a 64cm CTT seat tube in the shed, if that would be of interest. May be on the small side for you.
It’s broken down into a frameset hanging up and complete groupset (Shimano 105) in a box somewhere. Condition is pretty good, as I recall.
Tim O.
Portland, OR
Tim O.
Portland, OR
#2036
That sounds interesting. Can you send me a message or share more details here? Any pictures? What are you asking for it?
I'd send you a message, but I'm new to using this forum so it won't allow me yet.
Thanks,
Tim
Thanks,
Tim
#2037
Quoted: 758 Post(s)
Liked 647 Times
Seeking a 32-tooth 86 BCD chainring, Sugino, SR, Stronglight, or whatever, ideally with minimal wear. I have assorted other 86 BCD rings in various sizes, including a some NOS Stronglights. Other trade goods as well.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
#2038
Quoted: 3788 Post(s)
Liked 6,574 Times
#2039
Quoted: 1924 Post(s)
Liked 1,954 Times
ISO 5 Speed Freewheel 14-24
Looking for a C&V 5 speed 14-24 FW for my 78 Raleigh. Something nice and used little that will match well with my Nuovo Gran Sport bike. I have for trade a cool set of vintage White Industry hubs. These hubs would be perfect for a 90s weight weenie build
#2040
tantum vehi
Quoted: 1166 Post(s)
Liked 966 Times
Ummm, I have a 14-28 Suntour Perfect 5s FW, a 6s 14-24 and a 6s Shimano 6208 13-24 - Any of which you could have for $10 shipped... perhaps save those sick hubs for something of equal value?
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#2041
Liked 1,954 Times
Thanks but I think a nice 5 speed Regina G.S. Corse SICC with a big 24 cog is equal value. I'm intending to keep my Competition G.S. 5 speed. Yes the hubs are real neat but I don't have a bike for them---I didn't think. But now you got me thinking.
#2042
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
Anybody interested in an Altenburger Synchron? I understand these were a very early dual pivot sidepull. Original pads! Found in a bag of bike parts at a g-sale.
#2043
tantum vehi
Liked 966 Times
It wouldn’t be the first time a build started with a set of hubs in search of a frame...
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
#2044
Liked 1,954 Times
Yes. Nice like that but with a 24. Or an earlier GS Corse that goes to 24. I'm hoping to avoid a 14 to 17 jump at the high end also.
#2045
Why, why, why can they be not 170! Are there no 170 black Shimano 105 cranks !!
#2046
Phyllo-buster
Quoted: 2287 Post(s)
Liked 2,031 Times
#2047
Quoted: 784 Post(s)
Liked 515 Times
Tim O.
Portland, OR
Tim O.
Portland, OR
https://portland.craigslist.org/mlt/...065999005.html
#2048
Liked 1,954 Times
#2050
This is local, and would make a great little project.
That does look sweet! Actually, tonight I'm picking up a pristine 1981 trek 710. Thanks for sending this along!
Tim
