Replacing wheel ebike to non-ebike
Hi i have a folding ebike and it has tiny 14" wheels that need new wheels anyway. How hard is it for me to get a wide hub ? The bike mechanic said 122-126mm for the rear...where the motor is or will not be once i take the wheel off. Its is a single speed bike. I spotted these wheels https://www.ebay.com.au/itm/14-inch-...53.m1438.l2649 on ebay and havent got an answer back yet about the spacing. Its a bike that i got for free and i will use where the terrain is flat. There are other things i will repair/replace or fix on this too
Quoted: 340 Post(s)
Liked 275 Times
Your ebay link shows the rear at 85mm, which is too narrow for the 126mm axle spacing measured by your mechanic.
You can probably find a comparable used folding bike for what it will cost to change over the above bike to an unpowered bike, if you have to pay someone to do it for you.
Bikes: Brompton, Time, Bianchi, Jan Janssen, Peugeot
Quoted: 598 Post(s)
Liked 5 Times
Have you looked here: https://www.bikeexchange.com.au/s/folding-bikes
These wheels look good https://www.aliexpress.com/item/Newest-SPOMANN-16-inch-Folding-bike-alloy-V-brake-BMX-bicycle-clincher-rim-wheelset-MTB-16er/32824655409.html?spm=2114.search0604.3.80.4dc5397aYNhV2j&ws_ab_test=searchweb0_0,searchweb201602_1_1 0065_10068_10130_10547_319_317_10548_10696_453_10084_454_10083_10618_10307_537_536_10131_10132_10133 _10059_10884_10887_100031_321_322_10103,searchweb201603_1,ppcSwitch_0&algo_expid=3cfb7cdf-7db8-4840-be05-fdfe602e8a9d-11&algo_pvid=3cfb7cdf-7db8-4840-be05-fdfe602e8a9d
Is there anyway that i can create some type of spacer and put in a longer rod for the rear wheel?
so managed to find a wheel for this bike from a childs bike but the cassette doesnt freewheel if thats the right term. The old wheel had what i think should be on here. Is there a way i can get it off to use on the newer wheel?
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,194 Times
Your bicycle mechanic should be able to remove the old single speed freewheel and order a new one for you. They have a special tool which fits into the four notches.
However, I also notice that the hub seems to be missing a spacer. When you tighten up the wheel in the dropout, does the dropout press against the freewheel? That alone could be your issue. Your mechanic might be able to provide a spacer as well.
Bob
Bob
Quoted: 340 Post(s)
Liked 275 Times
If a spacer were missing, I think the wheel wouldn't turn. You can try spinning the gear backwards when the wheel is off the bike. Maybe a shot of penetrating oil will loosen it.
Oh ok the wheel turns fine. i dont think this is meant to go backwards. Because it is froma childs bike. Seems to be very different from the part thats on the old wheel i took off
Oh i just remember the reason it doesn't go backwards is because thats how it brakes as a childs bike. Thats how all bikes were when i was a child. So might have to bring the old wheel with me to the workshop tonight. There is a community workshop that i go to sometimes and they might help me on the spot
Quoted: 340 Post(s)
Liked 275 Times
I have two tiny bikes out rusting outside, probably 12" and 16" wheels, and their gears freewheel, . Realizing that some day I might want the wheels has kept me from putting them out for the garage collector.
Oh cool. Yes the original wheel was like that but its moved to the side. Wish i knew how to take that part off to put it on the new bike. A youtube video would be handy. I dont have gears on this bike though. Oh hope you find a use for your tiny bikes
