Need suggestions to find maillard hub cones for a Voyageur
Old 12-15-09, 11:27 AM
badger_biker
badger_biker's Avatar
Bikes: 10 vintage touring machines
Quoted: 112 Post(s)
Liked 126 Times in 66 Posts
I'm going through a 1987 Voyageur and the front and rear hub cones are a bit pitted and I'm wondering if anyone knows of a source for replacements. The hub races are still good. They hubs have dust caps that have a channel in them that a disk pressed onto the cone fits into. It is an early version of a "sealed" bearing I guess. Since these are 36 and 40 spoked wheels I would like to keep them for the old tourer.
I don't know if Schwinn used much of a variety of maillard hubs or if the same ones were used for LeTours, etc. of the same vintage.
Any info would be appreciated.
Nothing compares to the simple pleasure of a bike ride - JFK
badger_biker is offline
Old 11-14-20, 08:29 PM
drewfio
Bikes: Mostly 80's Japanese built road and touring bikes
Quoted: 63 Post(s)
Liked 78 Times in 26 Posts
Resurrecting this...
did you ever find a good replacement for the hub cones? Rebuilding an ‘88 Voyageur, and in the same situation.
drewfio is offline
Likes For drewfio:
Old 11-14-20, 08:35 PM
polymorphself
Quoted: 837 Post(s)
Liked 1,080 Times in 521 Posts
I can’t help but post a pic of your Voyageur in the meantime
polymorphself is offline
Old 11-14-20, 09:19 PM
badger_biker
Quoted: 112 Post(s)
I checked at a couple old time Schwinn LBS and happened to find one at each. I’ve since sold that Voyageur but I may have a couple of used cones around. I’ll check and see what shape they are in and let you know.
Old 11-14-20, 09:22 PM
drewfio
Quoted: 63 Post(s)
Ha, sure. Here is where I'm at so far with the bike:
And said pitted cone:
drewfio is offline
Likes For drewfio:
Old 11-14-20, 09:24 PM
drewfio
Quoted: 63 Post(s)
Thanks for reply! If you've got a replacement, I'd certainly be interested.
drewfio is offline
Old 11-15-20, 02:05 PM
badger_biker
Quoted: 112 Post(s)
I found this envelope with an old beat up Malliard cone but I think I found that the Alivio cones were a perfect match for at least the front cones. Maybe that will be something you can use to track something down.
Likes For badger_biker:
Old 11-16-20, 09:30 AM
drewfio
Quoted: 63 Post(s)
Thanks for looking! I'll see if I can track some down to compare.
drewfio is offline
Old 11-16-20, 09:35 AM
drewfio
Quoted: 63 Post(s)
I also found some axles which include cones on eBay after some roundabout keyword searching, that I'm wondering if the cones would be a suitable replacement. They are pricey, so I'm hoping to get a better sense before I buy. Here is the description:
THIS IS A VERY RARE ITEM TO COME BY IN MINT NEVER USED CONDITION. IT IS A VINTAGE AUTHENTIC SCHWINN FRONT HUB AXLE. YOU WILL GET 1 HUB ONLY. IT'S A FRONT QUICK RELEASE TYPE USED ON SCHWINN ROAD BIKES, RACING BIKES AND OTHERS. IT'S STAMPED SEALED ETANCHE, I TAKE SINGLE OF THEM OUT SCHWINN MAILLARD PACKET TO SELL. THE PACKAGE SAYS MAILLARD "SCHWINN" MADE IN FRANCE, THE FRONT HUB IS 4 1/4" LONG. THIS GENUINE SCHWINN MADE HUB IS IN MINT NEVER USED CONDITION.
And here are some more photos of what I'm hoping to replace, for reference:
Last edited by drewfio; 11-16-20 at 09:38 AM. Reason: added photos of what I'm replacing
drewfio is offline
Old 11-16-20, 11:12 AM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1560 Post(s)
Liked 1,282 Times in 853 Posts
I've said it before, but I always keep my bid prices on Schwinns of this era in check because of my full expectation that the hub cones will have left the factory sufficiently over-tight so as to almost guarantee one or more of them are pitted.
So easy to fix before the bike has miles on it, and such a pain after!
I would have thought that this type of cone would be one that Wheels Mfg would offer faithfully duplicated(?).
dddd is offline
Old 11-16-20, 12:14 PM
drewfio
Quoted: 63 Post(s)
I took a look, and didn't see anything that looked to my amateur eyes like a clear match. If one of those works, I'd love to know which one!
drewfio is offline
Old 11-17-20, 07:59 AM
Headpost
Bikes: I've stopped at seven.
Quoted: 275 Post(s)
Liked 302 Times in 185 Posts
I'm not sure if your cones are too far gone, but you could also try this method--assuming you have some time and a drill you don't mind putting some mileage on.
https://www.bikeforums.net/classic-v...sandpaper.html
Headpost is offline
Old 11-17-20, 08:18 AM
drewfio
Quoted: 63 Post(s)
I read that thread, and a bunch of others about the method. Seriously considering it. I'd certainly feel more confident in riding appropriate replacement cones, but it seems others have had success and gotten many miles from the resurfaced cones. I have access to a lathe, so I would not have to wear out a drill. From the photo of my cone above, looking at the depth of the pitting, do you think it might be a good candidate for this?
drewfio is offline
Old 11-17-20, 08:42 AM
SJX426
SJX426's Avatar
Quoted: 1606 Post(s)
Liked 2,211 Times in 1,102 Posts
I needed one of these and gave up. It is off a Trek 610 with the 3/16 balled rear hub.
P1000288 on Flickr
SJX426 is offline
Old 11-17-20, 12:33 PM
Headpost
Quoted: 275 Post(s)
Definitely. Did you read the article I attached to the other thread? The cones I did were about as bad as the one pictured, and if you have a lathe the job might even be enjoyable.
https://bicycleobsession.wordpress.c...ted-hub-cones/
Headpost is offline
Old 11-18-20, 07:21 AM
oneclick
Quoted: 1105 Post(s)
Liked 1,324 Times in 781 Posts
Consider this:
Balls are graded for quality. Years ago, G100 was ok, G25 was expensive, now G25 is common. G25 balls have a size tolerance of plus-or-minus one ten-thousandth of an inch.
I've measured pit depth and race concentricity. A good quality race is better than I can measure for concentricity; and small but visible pits are on the order of a few tenths of thousandths of an inch. Bad pits (as above) break through the case layer, which is likely between ten and forty thousandths.
Ball and race wear are related to contact pressure. This is not an analog function; at least not a smooth one, but stepped. If one of 11 balls loses contact as it drops into a pit the pressure on the others (assuming they all *are* in contact) goes up by 9%. Grind the cone out of true by two one-thousandths and you could be running the bearing most of the time on three balls.
So those are some hard numbers to hit, and most bad cones are a long way away. Some people are sure they can essentially hold tolerances of a thousandth of an inch by hand. With a good lathe and toolpost grinder setup or a dedicated grinder you have a chance.
oneclick is offline
SJX426
Classic & Vintage
8
08-11-18 07:32 AM
Eles
Bicycle Mechanics
7
06-27-18 09:34 AM
seedsbelize
Classic & Vintage
12
02-15-16 08:25 PM
ebgbz
Bicycle Mechanics
25
02-08-13 06:09 AM
boulderroad
Road Cycling
7
02-20-11 08:55 PM
