Davinci cablesplitter
Bikes: Pocket Llama
Quoted: 30 Post(s)
Hi guys need help
I just got S&S coupling on my bike I use to have Magura HS 11 brakes and now I upgrade to Avid v Brakes and I bought the davince splitter,can some one tell me how to install them,my bike.My bike dont have any cables holders like on the pictures ,so I really dont know what to do?It s possible to have the cable on the housing or I need to cut the housing run the cable and add the splitter? Thank you very much in advance!!!![ATTACH=CONFIG]481144
Quoted: 5787 Post(s)
Liked 2,579 Times
The cable splitter is for gear or bake wires (not enclosed cables), and requires wires that run bare. If you have continuous housing, the cable splitter simply can't help you.
Here's a link to the daVinci site and a photo that should explain it all.
FB
Chain-L site
FB
Chain-L site
An S&S coupled frame without cable stops? Shame on the framebuilder who added the couplers for not addressing this with you! I had a frame built with S&S couplers and the framebuilder forgot to add a cable stop for the rear brake cable as requested (the un-coupled frame is intended to have full-length brake housing). The builder took the frame back and added the stop at his expense. Now, this was a new frame, not a retrofit, but still....
Bikes: Pocket Llama
Quoted: 30 Post(s)
Yes I know this really sucks,also the paint was not good I am really dissapointed it!!! and now I need a solution theres must be something for frames with out cable stop???
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I have a high tolerance for ugly, and those problem solvers are ugly in the extreme. How about something like this?
https://www.google.com.mx/search?q=c...on+cable+stops
Here is a page with various alternatives if you're frame can accommodate them:
Bicycle Bike Cable Stops, Guides, Pulleys Online | BikeParts.com
Bikes: Pocket Llama
Quoted: 30 Post(s)
The frame builder.say"or I.am.sorry that you are not happy" I told him.he should pay me the cable clam stop,waiting for the answer
