Bearings on 27" wheel
Old 05-22-20, 10:17 PM
johnspack
Bikes: 2012 Giant Trance, 1979 Dawes Echelon, Late 80s Walmart MTB
Quoted: 19 Post(s)
Liked 5 Times in 5 Posts
I'm restoring a '79 Dawes Echelon racer, and just repacked the bearings on the front wheel. I noticed it only had 9 bearings per side, and looked like it could hold 12 at least. Is there a reason for only 9, and could I put more bearings in?
I'm slowing learning how to work on bikes, but sometimes the reason for the way it's put together eludes me.... I think the bearings are the little 3/16ths... should there be more than 9 per side?
johnspack is offline
Old 05-22-20, 10:21 PM
base2
I am potato.
base2's Avatar
Quoted: 1789 Post(s)
Liked 1,629 Times in 933 Posts
9 is pretty standard. It just is.
Car dependency is a tax.
base2 is offline
Old 05-22-20, 10:36 PM
Oneder
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times in 46 Posts
You need to have some space for them to move around, usually about 2 less than whatever can be held.
Oneder is offline
Likes For Oneder:
Old 05-23-20, 02:10 AM
100bikes
Industry guy
Bikes: To many to name - I ride a custom built steel frame.
Quoted: 115 Post(s)
Liked 80 Times in 48 Posts
Bearing counts in C&V :
10 balls per side front wheel
11 balls per side crank
9 balls per side rear wheel.
This refers to loose ball design, not retainer styles.
There are exceptions, but not many.
rusty
100bikes is offline
Likes For 100bikes:
Old 05-23-20, 08:56 AM
mrrabbit
mrrabbit's Avatar
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times in 30 Posts
If the hubs are pure french....there's a slight possibility they might be 13 balls rear (Maillard Helicomatic), much smaller (3/16 or 5/32) than the ball bearings we see for the typically 10 front and 9 rear.
Again, slight possiblility.
Put enough bearing of the right size in, such that when grouped up, there's still a 2-3mm gap on the non-grouped side. Do a cone test, see how high the bearings ride. Somewhere in the middle to 2/3 up is good.
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
mrrabbit is offline
Likes For mrrabbit:
Old 05-23-20, 09:35 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
If you don't have a caliper to measure your bearings, line them up along a ruler.
If 3/16"-
16 = 3".
8 = 1-1/2".......
I have ran into Huffy's with 9 1/4" balls/side in the front.
Bill Kapaun is offline
Old 05-23-20, 06:03 PM
johnspack
Quoted: 19 Post(s)
Thanks for all the input guys. Feeling kinda dumb right now. Decided to search the floor area where I had worked on my wheel. Found 2 bearings. Measured them, 1/4". So the answer for front late 70s Mavic rims is 10, 10 bearings per side!
Likes For johnspack:
Old 05-23-20, 07:15 PM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
I was going to say that if you were able to get 12 bearings into the hub, it would mean that the bearings were the wrong size.
I used to have a Park ruler that measured spoke lengths, cotter pin sizes and ball bearing sizes. Now if I need to check a ball bearing size I use my drill bit sizing guide. Those are available at nearly every hardware store.
Cheers
Miele Man is offline
Old 05-23-20, 07:51 PM
Bill Kapaun
Rims are moot.
It's the hubs that matter.
Never seen a hub that took 10 1/4"balls/side.
Old 05-23-20, 07:57 PM
johnspack
Quoted: 19 Post(s)
Read my caliper wrong. Pretty sure they are 3/16". It's a Shimano hub.
I'm almost blind in one eye, and forgot to use my magnifying glass.
Did I mention I'm almost 60 with a few medical problems?
