Suggestions for handlebar bag to hold binocs and DSLR
I commute to work along a path where I can see some interesting wildlife sometimes. I've carried my binoculars with me before, in a pannier. My binocs are Nikon Action EX roof prism models, so they're kinda large and heavy. My DSLR is a Nikon D50 which I would probably be carrying with my 70-300mm lens. I don't want to carry this stuff in a pannier because I already carry too much junk back there on the back of the bike, also I'd like to get some of that weight up front. So, what is a good, large, waterproof handlebar bag that can support these two items? Also, I'd like something that could disconnect easily and that won't interfere with lights and such on my bar. I have the ability to add a second stem and short bar below my main bar, for accessories which I plan on doing sometime in the near future if that helps any with suggestions. I also have bar end shifters on my drop bar and I wonder if the low-running cables will interfere as well.
Ive been shopping for a handlebar bag and looking online and so far the best i have found available for sale (other than the very expensive ones from Rivendell are from Arkel. If you google "arkel handlebar bag" you can see.
I just bought a very large handlebar bag from Walmart made by Schwinn (in China) for $10. Its not well constructed-- the material is flimsy but it is large and will do the job until it breaks/tears. You might be able to find it on walmart.com. I have seen it for sale in various Wal Mart stores, sometimes it is out of stock. I got it because i needed a handlebar bag on a trip and i happened to be in a walmart and it meets my immediate needs, knowing it wont last so long. One option is to just get new ones of these each time it breaks. WalMart also sells a much smaller handlebar bag made by Bell for $10 that i use also, i have used about 4 of those on vairous bikes so far, and have worn out 2 of them. They dont hold up so long to heavy use but they are very cheap.
The 2 bags i mention from Wal Mart do not have have quick disconnects. The Arkel bags do. What i do is use a few zip ties so that the cheap handlebar bags are not easy stolen (they would have to be cut off.) Also i dont leave anything of value in them. (I may leave extra tubes, a $10 compact air pump, sunscreen, cliff bar etc,, but certainly nothing like a camera.
+1 on the large Arkel handlebar bag. I use the small one to carry a GF1 and some accessories. It is built well and I like the quick release mount system. The unfortunate part is that you have to buy the waterproof cover separately for about $20.
Hi
I would suggest checking out an Ortlieb Ultimate5 Plus handlebar bag but using a Rixen and Kaul Klickfix mount.
Andrew
Andrew
The Brevet riders have a front rack over the wheel, to support 1 big bag,
mounted on a stem mounted sub frame
Berthoud is very Un Wally world in quality and price, Hand made in France..
see via Wall bike,and peter white cycles. or buy and import direct.
Velo Orange tries to get similar stuff made at a bit less prestige price.
If you do travel with your camera, I would suggest putting in some close-cell foam or something, vibrations are not good for cameras in general, any sort of foam will help immensely. Ive seen screws come loose on all sorts of cameras from commercial use from car vibrations etc, a bit of foam is an easy way to reduce vibrations a lot.
There is also a Chest mounted bag and harness from Ortlieb,
put the camera in one bag the binocs in the other
they make a tapered bag for zooms and SLR cameras,
4 D rings the snap hooks engage keeps it in front of you.
Quoted: 2599 Post(s)
Liked 1,924 Times
I second the Ortlieb recommendation, but with a caveat. It'll interfere with bar-mounted lights. If you can get a second stem (see, for instance, https://www.sjscycles.co.uk/thorn-acc...deg-prod11041/) and hang the Ortlieb on that, you'll be set. Works well with bar-ends, BTW.
Quoted: 19 Post(s)
Liked 7 Times
Rixen and Kaul (and Ortleib) mounts are best because they support the weight using a plastic wrapped steel cable wrapped around the stem. The small bar clamp is there to prevent rotation but does little else. Most other mounts have to use massive clamps to support the weight.
I have used R&K on a Carradice bar bag, fully loaded, down mountain trails and they are totally reliable but have instant quick release.
You can get spare mounts for other bikes and extended length mounts.
I mount my light on the fork crown.
Ugh... I appreciate the alternative suggestion, but I use bags on the bike to keep from carrying things on my body when riding. I hate having anything strapped on like a backpack when I'm riding. I rode enough like that in college to know that I don't like it. Heck, I don't even think I could wear a Camelback anymore if it came to that.
I have a Monocular, that takes up little space. new post film era cameras
compete with each other, over most features in the smallest space,
so consider: get a reasonable volume bag, shrink the size of the contents.
I'm still looking around, but I'm not finding anything that appears like it would hold the weight of the camera and binoculars let alone accommodate the size of both items. I need something that measures roughly 9"Wx8"Dx8"H and there are very few bags that fit those measurements. I'm kinda surprised but the only bag that appears to be even remotely aerodynamic is the Topeak Handlebar Dry Bag https://www.topeak.com/products/Bags/HandleBar_DryBag I haven't found any reliable reviews on this bag though. Only a couple reviews from people claiming it instantly fell apart on them. I've always gotten the impression that Topeak made some pretty decent stuff so I have to wonder about those reviews - just a couple faulty bags maybe? The other bags that have been suggested - Arkel and Ortlieb, well, bloody expensive but I guess that's what you get for quality. Still, I guess the majority of bags are not aerodynamic in any way. I guess if you're hanging bags all over your bike, you're going to catch so much wind anyway I guess it doesn't matter.
When using the bracket rather than the rack I completed the TA (73 days) with a DSLR and a couple lenses, but it was sagging pretty well by the end. At first I added a metal plate to stiffen the back of the bag, but later decided I liked the little rack better.
I've used an Ortlieb Ultimate handlebar bag with the padded camera insert to carry my Nikon D70 and 70-300 lens. If I'm doing photography on the trip, I'll pack an extra lens or two in a padded rack trunk. I wouldn't suggest carrying a DSLR + longer lens + a big set of binocs in a handlebar bag, even if you can find a bag big enough to fit them all. That's a lot of weight hanging off the front up high. Maybe consider getting a smaller set of compact binocs for bike travel? They make some really nice ones now that almost rival full-size ones.
You gonna eat that?
A local blogger did a nice writeup about using military surplus bags for bicycle use. There are lots of different sizes to look at.
I've used such a bag both as a saddle bag and a handlebar bag.
As in #9, ... 3 parts for a premier kit.
https://www.wallbike.com/berthoud/han...rontbags-basic
https://www.wallbike.com/berthoud/rac...hreadless-stem https://www.wallbike.com/berthoud/rac...oud-front-rack
You gonna eat that?
That's why I suggested military surplus: It's dirt cheap, comparatively speaking. The black bag pictured above was about $20.
Slow Rider
Erick L, a member of BikeForums who has great photos ( https://www.borealphoto.com ) has this page showing how he transports photo equipment:
https://blog-en.borealphoto.com/2008/...ike.html#links
Quoted: 19 Post(s)
Liked 7 Times
The construction of Carradice bag is a correx box with a canvas outer covering. The box can be constructed using nylon bolts or rivets. You can buy the R&K handlebar mount and a retro fit plate for a basket.
Given the low cost and easy assembly, why not build you own barbag to your own design. You can test it to destruction for ease of mind.
