How Do I Remove Old Zeus Crankset?
Bikes: '72 Paramount 15-9, '74 Schwinn Paramount P10-9, '73 Schwinn Super Sport, 1983 Schwinn Voyageur SP,17 Motobecane Cafe Noir, 1970 Raleigh Competition Tourist, 1999 Rans V-Rex
Quoted: 220 Post(s)
Liked 83 Times
Picked up a '72 Raleigh Competition at an estate sale. Mostly Zeus . I'm guessing I'm going to have to grind down a socket? 16mm?
Any other ideas?
Any other ideas?
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
How's it different than other cranks ?
I use an old Park wrench with 14, 15, 16 mm sizes for crank bolts.
Old fart
Quoted: 3615 Post(s)
Liked 3,446 Times
High-end sockets from e.g. Snap-On, old USA-made Craftsman, etc. tend to be thinner than inexpensive sockets and will fit in the arm. 16mm "peanut-butter" wrenches from Zeus and Park were also available BITD and turn up on eBay (but the 14-15-16 Park crank wrench does not fit the Zeus arm). Otherwise, yeah, you'll need to grind down a socket to fit.
Old fart
Liked 3,446 Times
Zeus uses a 16mm bolt in a 22mm extractor hole. This leaves minimal clearance for a socket to fit in the hole. Stronglight also used a 16mm bolt, but their extractor hole was 23.35mm wide.
While the 16mm socket on the Park 14-15-16mm wrench fits into a Stronglight am, it is too thick to fit into the Zeus arm. Park did make a 16mm thin-wall peanut-butter wrench to fit Zeus cranks (the CCW-16).
verktyg
Quoted: 1038 Post(s)
Liked 1,240 Times
16mm 12 Point sockets
12 point sockets usually have thinner walls than 6 point sockets. As John mentioned above older Craftsman sockets had thin walls. 3/8" drive sockets are usually thinner than 1/2" drive sockets.
There are several Craftsman 16mm 12 Point 3/8" Drive Sockets #44311 listed on eBay for ~$4.00 plus free shipping.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
Nah, whatcha really need here is...
A spark plug socket.
Bikes: old ones
Quoted: 26475 Post(s)
Liked 10,434 Times
...the one time, on the one bike I had to do this, it turned out to be easier (because I have a bench grinder) to just take an odd 16 mm socket and thin the wall. i still have it in the tool box somewhere, and will probably never use it again, because of course when you reassemble the thing, you want to use a crank bolt with a smaller, 15mm head. Or one of those socket headed ones that precludes the need for a dust cap.
Bikes: old ones
Liked 10,434 Times
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,303 Times
I found that a surplus 5/8" socket was perfectly sized for a 16mm bolt head, so I spun it against my grinder wheel until it fit into the threaded crankarm bore.
Quoted: 220 Post(s)
Liked 83 Times
Thanks all. I found a beat out 16mm 12-pt. socket and ground it down. It did the trick to pull the bolts. A Park CCP-22 pulled off the arms. My Campy puller and and an off-brand puller wouldn't fit the Zeus threads.
Were there dust caps that went with this set or was the bolt designed with the wide top to preclude the use of a dust cap?
Quoted: 3843 Post(s)
Liked 3,398 Times
The Zeus Gran Sport, Competition, Criterium & early 2000 model chainsets came without a dustcap. Their fixing bolts are chrome plated.
Some of the later model Zeus chainsets did come with dustcaps.
Old fart
Liked 3,446 Times
The Zeus extractor thread is standard 22mm x 1mm, so the Park crank puller works fine for that part of the job. But the mounting bolts are 16mm, rather than the more typical 15 or 14mm, and need a thin-wall socket for removal. Many people simply replaced the 16mm Zeus bolts with 15 or 14mm bolts to simplify removal with more common tools.
Old fart
Liked 3,446 Times
Quoted: 220 Post(s)
Liked 83 Times
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 268 Post(s)
Liked 338 Times
Liked 3,398 Times
Quoted: 268 Post(s)
Liked 338 Times
Old fart
Liked 3,446 Times
