WTB: Small Parts
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 642 Times
WTB: Small Parts
EDIT/UPDATE: Adding and subtracting from list. Looking for a bunch of small stuff to finish a project, hopefully someone has a big stash of stuff and has it all, avoiding a bunch of purchases where I am asking members to ship tiny amounts. Regardless, I could use:
(A) A set of top tube cable clamps w/screws. Bike is a mix of Campy and Other, can be flexible on brand. LOCATED
(B) A pair of tensioning springs for the QR skewers for Campy hubs (uh, I don’t know if it matters what brand of springs!) LOCATED
(C) ONE Campy Record crank dust cap. LOCATED
(D) One or more of the nice bolts with 8mm head and a shoulder behind the head used on Campagnolo downtube mounts, like DT shifters, DT cable guides, DT stops.
(E) One of those nice, sturdily-built, rear brake center pull housing stops that hangs off the seat post bolt (Die-compe? Other?) LOCATED
(F) Two Weinmann (Is Die-Compe the same?) Ny-Lock center mounting bolts for the brakes for attaching to frame. I have a pair here but the LyLock part is about worn out.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
I’ve got most of what you’re looking for. A couple choices on the rear cable hanger, as shown.
Check out www.djcatnap.com for articles on vintage Japanese & French bicycle restorations, components and history.
Likes For Catnap:
Quoted: 835 Post(s)
Liked 2,141 Times
Quoted: 1106 Post(s)
Liked 1,328 Times
Springs are available in bags of a dozen for very little money on the auction site.
For the brake housing clamps there are some made in stainless, unfortunately I think by a large asian concern but as your machine is already a mésalliance it can be justified as function over form.
Quoted: 987 Post(s)
Liked 642 Times
Volute Springs Matter! https://www.bikeforums.net/classic-v...springs-3.html
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Likes For JohnDThompson:
Liked 1,328 Times
Somewhere I have a mandrel for winding them, it was made & used several decades ago and the "somewhere" is likely very deep in a bin somewhere.....
Quoted: 1609 Post(s)
Liked 2,216 Times
The hanger you would prefer is used often with center pull brakes which do not have a release on the lever or the calipers.
Likes For SJX426:
Quoted: 987 Post(s)
Liked 642 Times
Updated, got some of what I need, plus I added an item in post #1, so still looking for:
Quoted: 835 Post(s)
Liked 2,141 Times
Just to be clear, my earlier post was tongue-in-cheek. I did not mean to imply you should make any extra effort to obtain the proper OEM springs for your hubs. I was curious about (volute) skewer springs when I started the linked thread, but I also recognize there's practically no functional difference. I have noticed some slight differences between these springs (mainly thickness, color), and have had some skinny ones get mangled or stuck between the skewer and axle hole. There may be some curmudgeonly judge at some concourse somewhere in the world who might notice, but I don't obsess about it and confess I have robbed volute springs from other wheels wheels needed.
Quoted: 804 Post(s)
Liked 2,987 Times
Quoted: 987 Post(s)
Liked 642 Times
Quoted: 804 Post(s)
Liked 2,987 Times
- M6 X 0.8T, uses a 10mm wrench, 7.78mm tall (for BMX calipers) RIGHT in picture
- M6 X 0.6T, uses a 10mm wrench, 5.93mm tall (for FIXIE calipers) LEFT in picture
Made by Dia-Compe
Quoted: 987 Post(s)
Liked 642 Times
Thanks, and that sent me back to measuring. Turns out I do have a metric thread pitch gauge, not sure I have ever used it. On the Weinmann, neither 0.6mm pitch nor 0.8mm work... but 1.0mm does. Then I took a micrometer to bolt outdiamter: 5.8mm. Does this sound like a M6 x 1.0mm bolt? If so, a pack of those in Nylock, from Amazon, is cheap. Otherwise, I might use the existing worn nuts and a drop of LocTite. EDIT/UPDATE: Spending time doing online searches, seeing a few mentions suggesting M6x1.0mm Including this description of the center bolt: "Size: M6x57.45mm; Thread Diameter (d): M6; Pitch (p): 1mm; Length: 57.45mm; Shoulder Diameter: 6.4mm; Shoulder Length: 7.4mm; Diameter: 5.95mm; Thread Length: 22.65mm; Head Diameter: 15.85mm; Head Height: 3.55mm; Drive Size (s): 14mm; Format: Modified Shoulder Bolt; Standard: Proprietory Weinmann Fastener". So, unless someone has Weinmann nuts just sitting around, I'll buy a pack of that size and hope for the best.
Still hoping for item "D" in post #1
Two sizes available (choose in the drop down menu below):
