Did I do damage overtightening my cassette
Bikes: Trek Domane, Surly Disc Trucker
Quoted: 170 Post(s)
Liked 103 Times
Apologies if this appears twice. Didn't see it show up after I first submitted so trying again.
I tried changing the cassette on my 2014 Surly Disc Trucker. Got the old one off fine and installed the new one. I used the Park Tools TW6.2 torque wrench set to 40nm to tighten. First time I used it and I think I messed up. As I tightened, I heard loud clicking sounds like I heard when first removing the cassette so I kept going, thinking I'd hear the distinctive torque click (I've used the lower pressure Park Tools torque wrench to tighten the handlebar/stem bolt and hear that clear 'click' when the torque was reached.
In any event, I kept putting pressure on the torque wrench until it wouldn't turn anymore. This is where I realized I may have overtightened. So .... I tried un-tightening (using a different wrench and chain whip) but couldn't get it to budge. I put (for me) quite a bit of pressure and finally stopped since I didn't want to do any further damage. I put a new chain on and took it for a light spin around my neighborhood, shifting through all the gears and it seems to shift fine.
Should I be worried about it being over-tightened? It'll be years until I'll need a new cassette given the miles I ride this bike but I don't want to risk a serious failure when I'm out on a rural gravel road (that's generally how I use my Surly, don't do any touring now).
Do you think I may have damaged the torque wrench by over-tightening?
Thanks for any insights ... I really want to learn bike maintenance but I really am awful at it :-(
Mad bike riding scientist
Quoted: 6243 Post(s)
Liked 4,260 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Habitual User
Quoted: 5039 Post(s)
Liked 8,267 Times
Agreed. If things are working fine, just roll with it. IMO, it's pretty hard to damage the cassette itself doing what the OP described. The chance of sudden explosion - or any other kind of catastrophic failure - is not very likely.
Likes For Eric F:
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 286 Post(s)
Liked 74 Times
Can't say I've ever heard "loud clicking sounds" removing or installing a cassette, so not sure what's going on there. 40 Nm is a long way from "putting pressure on the torque wrench until it wouldn't turn anymore". If you have a bench vise you might want to clamp your wrench and test it at some different settings to get a feel for when it should click.
As far as what to do, I wouldn't think anything is going to fail but I would be inclined to remove the lock ring and start over PROVIDED that your lock ring tool (I use Park FR-5.2g with the "pin") is making good engagement with the ring.
scott s.
scott s.
Likes For scott967:
Quoted: 170 Post(s)
Liked 103 Times
Thanks, guys, for the quick responses. Letting it go was the answer I was hoping for (it'll be a long time before I'll wear out the cassette on this bike). So, if there's little risk to just carrying on, that's what I'll do.
Scott, good suggestion on testing out the torque wrench - I'm not very experienced and I do want to change the cassette on my Trek Domane so I'd like to be more confident of what 40nm feels like. btw, my first instinct, too, was to try removing/loosening the lock ring but was unable to do it and got worried about doing more harm than good trying to undo it all. And, I think I wasn't very accurate describing the sound - maybe more of a creaking sound than clicking ... kind of had to be there
Thanks again, really appreciate you all sharing your knowledge and experience!
Habitual User
Liked 8,267 Times
Likes For Eric F:
Quoted: 170 Post(s)
Liked 103 Times
Thanks again
Likes For dennis336:
Expired Member
Quoted: 3716 Post(s)
Liked 5,578 Times
I always went by feel, let it click/pop a few times and call it good. Never had a problem. But...tried it with the torque wrench after reading here. 40nm was substantially more than my guess of good enough. I still don't normally use a torque wrench but I crank it down a good bit more than previously. I doubt you've damaged anything.
Quoted: 443 Post(s)
Liked 474 Times
I've definitely damaged at least one freehub body (stripped threads) before by following the 40Nm torque spec. Now I just go by feel (I know, not best practice🤷♂️).
Likes For tFUnK:
Habitual User
Liked 8,267 Times
Wow. That's a real "Oh, ****!" moment, right there.
Likes For Eric F:
Quoted: 170 Post(s)
Liked 103 Times
Yikes! Of course, following best practice got you stripped threads! But, yeah, I was completely worried I'd strip the threads either when I over-tightened or when I made my attempts to un-tighten. I really need to stop following recommended best practices
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1300 Post(s)
Liked 742 Times
i always just use a 15" Crescent Wrench, or 18" breaker bar/socket, and feel when tightening the Cassette lockrings.
Likes For maddog34:
Quoted: 1284 Post(s)
Liked 1,405 Times
Likes For mschwett:
Habitual User
Liked 8,267 Times
That makes the most sense to me. Knurled lock ring + knurled interface surface on the small cog = clicky noises when tightened against each other. It also means less likelihood of things coming loose by themselves.
Likes For Eric F:
Quoted: 2026 Post(s)
Liked 1,096 Times
Most cassettes have radial grooves on inside face on the lockring and similar grooves on the outside of the smallest cog. These grooves ride over each other as you tighten the lockring and make a prominent clicking sound. It would be easy to miss the setting click of a "clicker" type torque wrench when tightening one of these.
Likes For HillRider:
Liked 1,405 Times
Likes For mschwett:
Quoted: 1256 Post(s)
Liked 1,341 Times
O don’t quite understand the need for such high torque numbers for cassette lock rings. I just make it tight and feel the indents give a few times and call it a day. Have never had one come loose and the impact of that happening is minimal.
Likes For Atlas Shrugged:
Quoted: 170 Post(s)
Liked 103 Times
Quoted: 7069 Post(s)
Liked 11,141 Times
OP, if you really want to remove the lockring, just put on your chainwhip and use a longer wrench on the cassette removal tool. Leverage is your friend. But I do agree (with other posters) that you're probably good-to-go. But in a few years, when you want to replace the cassette again, just remember that a longer wrench is the key.
Likes For Koyote:
don't try this at home.
Quoted: 986 Post(s)
Liked 522 Times
I always used a long Sears torque wrench. I guess it's click was louder than the lockring noises! Not a whole lot louder, but I went slowly, and could hear the difference. tick, tick, tick, ... Click.
Now I use the cool Abbey Tool cassette tool, with it's built-in 9 inch handle. (It's a "souvenir" from some years ago, just a cool, satisfying tool, and doesn't even need to have the quick release skewer removed. nice!)
After comparing to a torque tightened cassette: I use a "three finger pull" on the handle, with a reasonable instead of max effort. I get a burst of clicks from the lockring. Cassettes torque isn't too critical.
Torque wrenches are great for us amateur mechanics. Getting a feel for the correct torque for stem or seatpost bolts, or for lockrings, isn't obvious the first time. Now I know to tighten the seatpost correctly with my "Y" wrench and two fingers.
Likes For rm -rf:
Habitual User
Liked 8,267 Times
Same. I use a torque wrench on small bolts that clamp carbon parts so I don’t over-tighten and do damage. The higher-torque stuff goes by “pretty darn tight” feel.
With a mighty wind
Quoted: 1111 Post(s)
Liked 906 Times
If you had some super light 190g rear hub, maybe it’s a concern.
If it’s the type of hub that pairs nicely with a Surly, I bet it’s fine.
Keeping the chain whip in place while applying a whole bunch of force might be the crux. I’ve definitely gotten some cassette shaped scabs on my hands from this.
Likes For rosefarts:
Old guy & bikes
I’m experienced, and I have had cassette retainers come loose when not using a torque wrench. Use the torque wrench - there is no downside, engineers have figured it out.
I don’t use a torque wrench for most fasteners, just the critical ones. If they took the time to mark it, I use the spec. When I install a threadless headset, if I don’t torque it, it gets loose. If I use the torque wrench, I get it right the first time.
BTW, most of us are over-tightening pedals.
In this thread, I have seen various justifications for not using a torque wrench. The real reasons might be not owning one, laziness, impatience, habit or pride. None of these are good reasons.
Where OP ran into trouble was the inherent clicking of this fastener, and is quite understandable. One trick I use is this: I wrap a bare hand around the head of the torque wrench, so I can feel when the tool clicks, rather than the retaining nut clicking. And note, recommended procedures are still the best way. Your blanket statement against correct procedures was meant as a joke, but it’s not a good idea.
Also, if you’re not sure if the wrench has clicked, loosen and restart the operation.
i think the advice to just use the wheel as it is, is good advice in most situations. But if I were about to start a major tour, I’d remove and replace it now, rather than risking a failure on the road. Worst case is you’d have to replace the cassette too.
Likes For canalligators:
Liked 4,260 Times
When using a torque wrench don’t just depend on the “sound”. The wrench moves in your hand as well. Pay more attention to that movement than to the sound it makes.
Stuart Black
Stuart Black
