Campagnolo Super Record 11 (ca. 2009/2010) compatibility
Old 08-17-18, 07:04 PM
Mysticmiri
I need new shifters on a used bike that has an earlier version of Campy’s Super Record 11 on it. I am guessing 2009-ish, based on the pictures I found online. Is any of the new stuff even compatible? What is the best route to go? eBay? Thanks in advance for any help.
Mysticmiri is offline
Old 08-17-18, 07:06 PM
Mysticmiri
Doesn’t have to be Super Record...
...if there are other (less expensive) options. I have looked at compatibility charts, and it is still confusing to me.
Old 08-17-18, 08:15 PM
ingo
Bikes: Cervelo S3, Ridley Helium, Cannondale Topstone Carbon, Giant Trance
Quoted: 43 Post(s)
Liked 51 Times in 24 Posts
You can still get new Pre-2014 Record and Super record shifters and parts with a little searching. My 2010 Record shifter broke a tiny spring and the entire shifter body had to be replaced last year. I understand the difference is the spring strength in the derailleurs, and then the compensating spring in the shifter, so the newer versions are not compatible.
ingo is offline
Old 08-17-18, 08:57 PM
Mysticmiri
Thank you. Do you know, if Record is compatible with SR, if from the right ‘era’?
Old 08-17-18, 09:18 PM
ingo
Quoted: 43 Post(s)
Yes the Super Record, Record, and Chorus 11 speed are all compatible from the same vintage when interchanging components, but not necessarily with sub parts for each component. For instance I don't know if you can put SR brake levers on a Chorus shifter body.
ingo is offline
Old 08-17-18, 09:28 PM
Mysticmiri
Thank you again. This is exactly what I was looking for.
Old 01-22-21, 03:52 PM
jonny7
Bikes: 1994 Cadex CFR3, 2006 Scott CR1 SL, Rossin aero, Bertrand GB 2000, Spec Allez Pro
Quoted: 134 Post(s)
Liked 68 Times in 52 Posts
Sorry for reviving this thread but anybody knows if any of the "new" campy stuff that's not high-end is compatible with ca. 2010 SR shifters/derailleurs? I'm in need of a cassette and a crankset and I'm wondering whether or not i'm allowed to look at Potenza, Centaur, etc. 11 speed.
jonny7 is offline
Old 01-22-21, 07:48 PM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 550 Post(s)
Liked 325 Times in 226 Posts
Cassettes and cranks are compatible.
Derailleurs and shifters are not because actuation ratios changed in 2015.
Drew Eckhardt is offline
Likes For Drew Eckhardt:
Old 01-24-21, 12:12 PM
eugkim
Along the same lines, I am wondering if any parts are interchangeable. I have a Super Record 11 rear derailleur from about 2010 that I'd love to convert to a medium cage to accommodate a 30 or 32 rear. I saw that there is a medium cage part available for a later model
https://www.modernbike.com/product-2...AaAn00EALw_wcB
Will this fit or is there another good option? Or would it be possible to keep the short cage to use up to a 30 with 52/39?
eugkim is offline
WGB
4
11-06-17 09:34 AM
Dawes-man
Classic & Vintage
48
11-14-16 08:27 PM
qestsesq
Classic & Vintage
23
08-29-13 06:02 AM
iab
Classic & Vintage
28
06-26-12 03:08 PM
collegeboymike
Road Cycling
33
04-29-10 07:51 AM
