Dang, 32c tires are slow
Old 04-20-20, 09:37 PM
adlai
Quoted: 274 Post(s)
Liked 54 Times in 34 Posts
Is it the weight or the rolling resistance?
adlai is offline
Old 04-20-20, 09:47 PM
SalsaShark
SalsaShark's Avatar
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times in 166 Posts
You need to pedal faster
SalsaShark is offline
Old 04-20-20, 11:37 PM
aclinjury
Quoted: 497 Post(s)
Liked 170 Times in 128 Posts
lol it's both
aclinjury is offline
Old 04-21-20, 12:56 AM
Ross520
Quoted: 174 Post(s)
Liked 177 Times in 99 Posts
32mm tires have less rolling resistance than 25s or 28s, however, they are heavier, and less aerodynamic, so in the real-word, they're slower.
Ross520 is offline
Likes For Ross520:
Old 04-21-20, 01:53 AM
SethAZ
SethAZ's Avatar
Bikes: 2018 Lynskey R260, 2005 Diamondback 29er, 2003 Trek 2300
Quoted: 564 Post(s)
Liked 334 Times in 182 Posts
My 32mm tires are barely heavier than a GP5K 28mm. I can't argue the aero thing. I don't think I lost any speed going to them. They are uncommonly good 32mm tires, though, not cheap, heavy, and stiff.
SethAZ is offline
Likes For SethAZ:
Old 04-21-20, 03:12 AM
Ross520
Quoted: 174 Post(s)
I'm sure they're faster on bad surfaces, so maybe it cancels out the slower performance on well-paved roads if you ride a mixture of surfaces?
I, personally, don't have the opinion that 32s are "slow", just that in good surfaces a 28, or 25 would be a little quicker.
I've noticed that OP has some, uh, interesting takes on various topics.
Ross520 is offline
Old 04-21-20, 03:50 AM
subgrade
Bikes: Focus Crater Lake
Quoted: 391 Post(s)
Liked 337 Times in 204 Posts
Does really a 4-7 mm change in tire width make a real difference in aerodynamic drag unless the rest of the bike+rider is as aero as it gets? (I doubt that can be said about any rider who isn't attempting a world record)
subgrade is offline
Likes For subgrade:
Old 04-21-20, 05:25 AM
Ross520
Quoted: 174 Post(s)
I’m not sure what that would have to do with the tires. The improvement should be the same regardless of the aerodynamics of the rider and rest of the bike.
And when you factor-in the decrease in weight and rolling resistance, a 25 or 28 will likely be noticeably faster, as long as the surface is smooth.Whereas a 32 will shine on rough surfaces.
It really depends on where you ride. If your routes are silky smooth, it would make no sense to run the larger tire, and vice-versa for a rough surface.
Ross520 is offline
Likes For Ross520:
Old 04-21-20, 06:23 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Liked 880 Times in 527 Posts
I'm curious about what metric you used to determine your loss of speed. A few years ago I did a comparison between 2 bikes on which I commuted to work. One was a 33 pounder with 32mm heavy tires and the other was a vintage steel light weight road bike with 25 mm light tires. Over the course of a few months of recording I saw no significant difference in average speed between the two bikes even thoughthe heavy bike felt slow in comparison. The effect of rolling resistance is much dependent on road surface but any advantage of an easier rolling tire quickly disappears as you go faster and wind resistance grows. Lighter tires certainly accelerate faster; however once up to speed the advantage may go to the heavier tire because it maintains momentum longer.
Tires always come with trade-offs. It's really up to you to determine what qualities (objective or subjective) are important to you.
Moe Zhoost is offline
Likes For Moe Zhoost:
hillyman
WALSTIB
hillyman's Avatar
Quoted: 280 Post(s)
Liked 384 Times in 183 Posts
Throw away the speedometer. Life is not a race unless your in a race. Just enjoy the ride
www.bikeleague.org
hillyman is offline
Old 04-21-20, 06:32 AM
freeranger
freeranger's Avatar
Quoted: 427 Post(s)
Liked 699 Times in 436 Posts
Are you airing them up to the max? If you are, trying running them a little lower, maybe 10-15psi lower, should be faster than running the max.
freeranger is offline
Old 04-21-20, 06:36 AM
fishboat
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times in 471 Posts
Gee..here's a topic that hasn't been flogged to death in the last day or so...though flogged endlessly, countless times before.
Gotta call "troll" on this one.
fishboat is offline
Likes For fishboat:
subgrade
Quoted: 391 Post(s)
Sure, the 0.001% of added drag would be there no matter what. My point was that the difference in air drag from the added few mm in tire width is likely so minuscule that it's negligible in the real world, and the other factors like weight, pressure, casing etc. far outweigh that.
subgrade is offline
Old 04-21-20, 07:05 AM
Koyote
Quoted: 6963 Post(s)
Liked 10,961 Times in 4,687 Posts
OP needs to drope the hamer.
Koyote is offline
Likes For Koyote:
Old 04-21-20, 11:32 AM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 550 Post(s)
Liked 325 Times in 226 Posts
No, they're faster because they have lower rolling resistance.
You are slow because you chose tires that have stiff carcasses with high rolling resistance, and/or you're out of shape.
Try the Continental GP5000. Unfortunately, there aren't a lot of low rolling resistance tires available in that width.
Drew Eckhardt is offline
Likes For Drew Eckhardt:
Old 04-21-20, 12:21 PM
ABQIan
Bikes: Lynskey R230, Bianchi Vigorelli, Jamis Dragonslayer, Surly Cross Check, EAI Bareknuckle
Liked 3 Times in 3 Posts
I run 32 Gatorskins at around 60psi on my Cross Check. They definitely seem slower to me but I find at that width light gravel and dirt are fairly easy going even though they're slicks.
ABQIan is offline
Old 04-21-20, 12:25 PM
epnnf
epnnf's Avatar
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times in 55 Posts
how does lower psi make you faster? I thought it slower
epnnf is offline
Old 04-21-20, 12:33 PM
HTupolev
Quoted: 1974 Post(s)
Liked 1,298 Times in 630 Posts
It can be faster when it allows the tire to conform around surface irregularities rather than transmit them to the bike and rider. Vibrating the bike+rider can cost quite a lot of energy. The rougher the surface, and the lighter the rider, the lower the optimal pressure for best performance is. Even on smooth roads, the optimal pressure for most people is usually well before the tire's maximum.
Relevant:
https://blog.silca.cc/part-4b-rollin...-and-impedance
HTupolev is offline
Likes For HTupolev:
Old 04-21-20, 12:43 PM
JayKay3000
JayKay3000's Avatar
Quoted: 46 Post(s)
Liked 78 Times in 50 Posts
Anecdotally remembering studies and opinion is because a 23c tire will be faster on a smooth surface, but most roads are not smooth. As you ride the bumps in the road push against the hard tire and slow you down. A cattle grid with the spaced metal slats shows off this quite well too. A lower PSI tire is able to absorb these small bumps and roll over them rather than being deflected by them. You can try this yourself when you find a patched bit of road that super smooth compared to an older bit of road that's slightly worn and then add in some that's starting to crack up and your momentum is sapped and you have to work a lot harder for the speed.
However, you need to be careful that you don't air your tires too low else you'll get snakebites where the rim and the inner tube are squished together causing a tear, thus a puncture.
The poor surface can slow you down by making you less efficient riding and thus slower. It's hard to pedal efficiently when the bicycle is juddering and bouncing all over the place.
However, tire width is different from how well the tire rolls. You still need to have a slick or fast rolling compound if you want your bigger tire to be anywhere near as good as a thin tire.
Remember that there is also a bigger contact patch on the surface of the road which should give you a bit more grip. It's a bit like how disk brakes weigh heavier, but for the average rider they'll have more confidence to brake later in adverse conditions so will end up being faster. Disk brakes just work better in the wet - not massively better some would argue, but enough to give a rider a lot more confidence.
I run my 23C tires at 80PSI. (I've had my rear go down as low as 60psi without any issue (also without noticing!) But then if I weigh up the bike a lot I might put more air in them.
JayKay3000 is offline
Old 04-21-20, 12:47 PM
SethAZ
SethAZ's Avatar
Quoted: 564 Post(s)
I've noticed that OP has some, uh, interesting takes on various topics.​​​​​
Well, I'm not riding in a velodrome, so I'm dealing with a variety of typical road surface quality, ranging from absolutely horrific on some short stretches (gaps in the road due to cracks that measure in inches), short segments where the road surface has essentially disintegrated and is all bumpy and cracked, all the way through the gamut to stretches of brand new, baby-bum-smooth asphalt, and everything in between. I'm not going to spend too much time out-thinking myself about whether my 32mm tires cost me some speed when I've been riding them for over 2000 miles and haven't seen any different big enough to show up as a blip in my own riding data. If it's there, it's below the threshold of visibility, and therefore below my own personal threshold of "something I should be concerned about." The ride quality improvements, on the other hand, were immediately apparent, and substantial. In short: going from 28mm tires on this bike to my current 32mm tires resulted in no apparent cost in performance, and a very noticeable improvement in ride quality. How this would translate to other people who aren't clydesdale riders like me, or people using crappy 32mm tires, or whatever isn't something I can have any input on.
SethAZ is offline
Old 04-21-20, 12:59 PM
BCDrums
Recreational Road Cyclist
BCDrums's Avatar
Quoted: 257 Post(s)
Liked 252 Times in 134 Posts
Neither. It's your pants caught in the chain.
Is this another troll fest?
BCDrums is offline
Likes For BCDrums:
Old 04-21-20, 01:00 PM
SethAZ
SethAZ's Avatar
Quoted: 564 Post(s)
My experience with Gatorskins was that I didn't know there was a problem with them until I rode something else, in my case going from Gatorskins in 25mm size to GP4K in 25mm size. Then I knew there was a problem with Gatorskins, and now you could rhetorically not pay me to ride them again. I say rhetorically because in the real world it would depend on how much you offered. Everyone's got a price.
SethAZ is offline
Likes For SethAZ:
Old 04-21-20, 01:19 PM
Rides4Beer
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times in 414 Posts
Depends on the tire/pressure. My 32mm GP5Ks are just as fast as 25s or 28s, but much more comfortable and more grip. 25's would be faster for a TT scenario, especially on my wheels since they match the rim width better, but for regular fast rides, I'll take the comfort of the 32s, especially on our crappy roads.
Rides4Beer is offline
Old 04-21-20, 01:39 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
The OP is right, wider tires are crazy slow. I have a 31 mile loop (with ~1,300ft of elevation) that I ride a couple of times a week. Takes about an hour and forty on my Cervelo (on tubeless 23s) but with wide tires? Woof, it takes forever. Could be as much as 6, even 8 minutes more. Just rode it a few days ago on 700x35s and it took 1h48m... oh, that bike also only has one gear.
...and just in case anyone missed it, this was <sarcasm>
DrIsotope is offline
Old 04-21-20, 02:01 PM
livedarklions
Tragically Ignorant
livedarklions's Avatar
Quoted: 8186 Post(s)
Liked 9,098 Times in 5,054 Posts
I noticed that the difference was much smaller when I stopped filling the bigger tires with Jello instead of air. Who knew such a small change could make such a difference?
Mind you, I was using red Jello. If it had been green or yellow, I think it would have been even slower.
livedarklions is offline
