Cold Setting
Cold Setting
Hi All!
I just picked up a Ciocc Alelle frame with 126mm rear spacing. I would like to run semi modern (brifters) groupset and hence was wondering if I should have the frame cold set? I just picked up a mid/late 90's campy Veloce groupset with wheels as well. The rear hub is 130mm. When I took off 2mm spacer on non drive side, the hub is able to slide in easily. The LBS close to home can cold set it for $30 and adjust the drops. The owner of the shop did mention that he adjusts it using his hands and uses the tools to measure and correct any adjustments. Wondering if I should leave the bike as is and slide the hub without the 2mm space which sets it at 128mm? Appreciate any feedback and or pointers. Thanks
Quoted: 1079 Post(s)
Liked 1,899 Times
I think if you can run the hub without having to cold set is preferable, but there's nothing wrong with cold setting the rear triangle IMO.
Likes For P!N20:
Quoted: 1372 Post(s)
Liked 1,751 Times
My guess is that you can get away without cold setting the rear triangle. I have done this a few times with no issues, however...
This usually works OK with a bike designed/built to accept a six cog freewheel, not five or less. If the bike starts with a five cog freewheel, the rear drop space will be 120mm. If that is the case, cold set away because, even though a strong person might be able to install the wheel, it will be difficult to do so.
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,525 Times
Ask how many rear triangle cold settings your LBS guy has done. As long as he has some experience and the right alignment tools (it sounds like he has both, but double check), I'd say invest the $30. Two to four millimeters doesn't sound like much, but having the drop outs out of parallel is suboptimal, and putting a 130mm OLD hub in a 126mm spaced triangle puts the dropouts (and the RD hanger) a little bit out of parallel. Is it a big deal? Probably not. But for $30, I'd say go for the cold setting and remove all doubt.
Quoted: 1561 Post(s)
Liked 1,734 Times
A 126mm rear drop out can accomodate a 7 speed HG cassette and 7 speed RSX / Sora brifters. I love the 7 speed drivetrain. The more the speeds the more trimming you have to do.
Quoted: 2363 Post(s)
Liked 1,749 Times
If you're able to re-center the rim after removing that spacer, and there are no driveline issues with the current setup, I'd say go with it.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
If your spacing gets in the way of a Rae Dawn Chong 7 second wheel change,
I'd cold set it to 130mm. $30 is cheap for a shop to do this, but it's a 10 minute job if you do it often and have the right tools to make sure the wheel is centered and the dropouts are parallel.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
I always considered cold setting a hack, I would not do it or want a frame it was done to. Too much room for imperfection, and I'd rather not have bent seat and chain stays anyway.
There's no downside to giving the remove spacer / re-center the rim method a whirl though.
Likes For AlmostTrick:
Quoted: 1872 Post(s)
Liked 692 Times
Ha, that's the most curmudgeon-y thing I've read in a long time. Thank you lol
2019 Salsa Warbird
2019 Salsa Warbird
Liked 1,734 Times
But I re-iterate- there is nothing wrong with that 126mm spacing. Just use a 7 speed HG/UG hub (600-6400, 105-1055, RSX or RX100), 7 speed cassette and RSX, Sora, or Tourney brifters (or Micronew or Microshift). I should know because at this moment I have 4 bikes with 126mm spacing- and 2 of them I have had to re-convert to 126mm hubs because the previous owners (in the case of the Lemond Tourmalet- possibly the factory) stuffed a 130mm hub'ed wheel in there, making it extremely difficult to take the wheel in and out.
Likes For icemilkcoffee:
Likes For shoota:
Quoted: 569 Post(s)
Liked 581 Times
Our local framebuilder uses his Marchetti frame table, cold sets come out perfect. People think custom frames always come out of brazing perfectly, not so, and if minor corrections are needed they are cold set with proper tooling, not 2x4s. How much difference in the two approaches make is unclear but I choose to believe the custom frames will produce sweeter rides.
I've cold set 5 of my frames from 126 to 130. All done on my basement floor with a 2 x 4, a ruler, string, dropout alignment tools and a derailleur hanger alignment tool. Not a single problem with any of them. I say go for it. It's only 2 mm on each side.
Likes For gearbasher:
Hey Rizaa I do know that the dropout are perfectly aligned (I set them with my Park dropout alignment tools) so if you just put a slightly wider hub in there, and do the trigonometry, the out of parallel angle should be very small (I used to be able to do that math, but I am just too lazy now a days!)
I would put that 2 mm spacer back in, and just spread the rear with your thumbs, and Bob's your uncle!
Quoted: 634 Post(s)
Liked 444 Times
Same! I don't think I would do this for a mint Confente Masi, but it's been fine for my riders. I don't have dropout or derailleur hanger alignment tools so I usually end up taking it into the shop to take care of those pieces.
Likes For tricky:
Quoted: 2338 Post(s)
Liked 2,822 Times
Liked 2,822 Times
I have coldset 2 frames with no issues one 126 to 135 usiing the sheldon 2x4
the other 126 to 130
but as alwayts ymmv
I actually ended up buying a 7 speed Shimano tri-color, Suntour sprint and just picked up the 8 speed Veloce groupset hoping to use that on the bike for its brifters.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
If it slides in easily with a 2 mm spacer removed, it should slide in with a bit of effort without the spacer removed. That's an option. In theory, you should redish if you remove the spacer. I'm not sure you'd notice a difference. Your wheel will be 1 mm off-center. Personally, I'd prefer cold setting over redishing the wheel.
My Bikes
My Bikes
If your spacing gets in the way of a Rae Dawn Chong 7 second wheel change, Rae Dawn Chong 7 second wheel change I'd cold set it to 130mm. $30 is cheap for a shop to do this, but it's a 10 minute job if you do it often and have the right tools to make sure the wheel is centered and the dropouts are parallel.
