Clincher Fitting Tips
Bikes: Giant TCR Advanced Pro 0 Disc
Quoted: 105 Post(s)
Liked 69 Times
Last night I spent literally about two hours fitting new Vittoria Corsa G2 (clincher) tires on a pair of HED Ardennes+ wheelset. I have never had this much difficulty putting tires on a wheel in my life. My hands are wrecked.
I squeezed the tires as much as can towards the middle of the rim but without much improvement. Finally, I gave up and used a plastic tire lever but the idea of getting a flat and having to spend half an hour on the side of the road is truly scary.
Maybe tires sitting in the cool basement past week added to my struggles. Should I have left it outside under the sun a little?
What are other tips that I can use? I put a bit of some soap around the rim but it got a bit messy. Maybe it wasn't enough. I also started fitting the tire near the valve then moved up. Should I have started the other way?
Anyways, tips and tricks are welcome. thank you!
Quoted: 871 Post(s)
Liked 726 Times
Use a different set of tires that are an easier fit on your rims.
Get a Koolstop bead jack. Carry it with you on rides or hope the tires stretch out.
I do start opposite the valve because you can squeeze more of the tire from there, but for my hands' sake and sanity I just use the Koolstop unless the tire is well-stretched.
Likes For surak:
Quoted: 105 Post(s)
Liked 69 Times
Likes For rower2cyclist:
Klaatu..Verata..Necktie?
Quoted: 10421 Post(s)
Liked 11,882 Times
I've had such problems mounting Conti tires onto the Fulcrum rims on my Bianchi that I ended up mounting the Contis on other bikes that have Velocity rims first, riding them for a few rides, and THEN moving them to the Fulcrums. Right out of the box, I've never been able to do them without levers, but once they're stretched out a bit, I can even take them off the rim without levers.
Likes For genejockey:
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 61 Post(s)
Liked 76 Times
HED Ardennes+ are a pain to get tyres onto. I've found most tubeless-ready clinchers rims I've fitted tyres to require at least two levers...though my hands aren't the strongest. Warmimg up tyres on the radiator at home does ease the fitting a little. The tyres fit slightly quicker the second time around after being on the bike for a while under pressure, just that little bit of 'give' with usage.
Likes For Bob the Mech:
Should Be More Popular
Quoted: 22590 Post(s)
Liked 8,924 Times
BTW some tire/rim combo's are notoriously difficult to mount, so in the future you may want to ask around.
Likes For datlas:
Quoted: 105 Post(s)
Liked 69 Times
Will def do my friend next time. I guess I got pretty lucky with my SLR1 and Rovals (before) I had no idea some combos could be problematic. That lool looks quite promising!
Quoted: 61 Post(s)
Liked 76 Times
Thanks all I need is that extra few milimeters. Hopefully they are stretching just a little on the wheels now.
Yes, will def warm up the tires beforehand next time. Although we down't have radiators in our house. Such foreign concept in the US. I miss living in a house with radiators way better than air heating!
Quoted: 105 Post(s)
Liked 69 Times
Yes, will try that. Re radiators, what I really miss is to sit down next to one or better put my back against one on a cold winter day and read a book or just chill. Air heating is so useless.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,531 Times
Uninstalled and put on the Hunts. I think you'll find that now you've got the tires on... inflate them to close to max and let them sit (or ride them).. In a day or so, or if you get a flat sometime in the future, those same tires will go on quite a bit easier than they do out of the box.
In a number of ways, this is the unfortunate truth. I'll wager the manufacturers to save some $$, will only offer TL-ready wheels soon enough, and getting tires on them will require having a database of compatibility handy to know which tires fit with which rims. From most of what I've heard, it seems generally the case that TL-ready rims are harder to get a nonTL tire on than a non-TL rim. It's probably helping the LBS though... bringing in some incremental flat-fixing revenue because the customers can't get the tires on/off.
Likes For Sy Reene:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4383 Post(s)
Liked 3,015 Times
What size tires? I have a set of wheels for which mounting a 23 mm tire is an ever-loving pain, but the 25s go on without too much trouble. Another reason to go to 25s.
Also, for combos that are a challenge and I'm gonna use a tire lever, I finish right at the valve, with the valve screw tight to keep the tube out of the way. Cuts way down on accidental tube punctures from tire lever pinch.
I'm not one of those heroes who can mount any tire with my hands. Not me. That koolstop tire jack can help, but it's not magic. If the fit is really tight, you can just end up breaking the jack. Ask me how I know.
Likes For MinnMan:
Quoted: 1163 Post(s)
Liked 442 Times
I’ll just add 2 minor tricks that have worked for me: 1) use flat tire levers such as Schwalbe’s and use all 3, levering 2 in close proximity with the back of your hand then wedging the 3rd in where you can. The middle of the 3 always falls to the floor then which is OK but not dropping the other 2 without having them snap back or pinch a tube takes practice but is entirely doable.
2) Save your thumbs and hands by wearing snug fitting work gloves to roll that last bit of stubborn unmounted bead up and over.
Likes For masi61:
Quoted: 325 Post(s)
Liked 109 Times
I've also heard a lot of people swear by bead jacks, but I have never tried one. I've never seen a bead jack that looked like it could be effective AND fit conveniently in a saddle bag or jersey pocket, so I will probably never buy one either.
Likes For BoraxKid:
Quoted: 105 Post(s)
Liked 69 Times
They are 25mm but still they were super tight, like not a millimeter space available like tight. Jack is something to have in the toolbox I guess. I'll see how it works next time I try to fit new tires.
I’ll just add 2 minor tricks that have worked for me: 1) use flat tire levers such as Schwalbe’s and use all 3, levering 2 in close proximity with the back of your hand the wedging the 3rd in where you can. The middle of the 3 always falls to the floor then which is OK but not dropping the other 2 without having them snap back or pinch a tube takes practice but is entirely doable.
Yes, you should have started fitting the tire from directly opposite the valve, and then finished at the valve. The way I was taught, and what has worked for me for years, is to finish at the valve. That way, you can use the valve to manipulate the tube and make sure it is not under the tire bead, nor will it be dragged over the sidewall should you need to use a tire lever. It also helps to make absolutely sure that the first tire bead is seated in the direct center of the rim before you install the tube.
Re where to start fitting the tire, I think you may be right. There's def more room around the valve area and pulling the valve while fitting the last section to avid pinch flats is the safer approach.
Thanks all!
Advocatus Diaboli
Liked 1,531 Times
Bead jack is just plan B, or maybe plan A if it makes the whol3 process even a few mins faster. But you are right that thing is super bulky for saddle bag or jersey pocket. Maybe I should just tape it on the tip tube haha.
Quoted: 550 Post(s)
Liked 325 Times
https://www.quora.com/Lately-I-have-.../Drew-Eckhardt
Understand rim construction, use two wraps of 1 mil Kapton rim tape, and apply proper technique. That will let you comfortably install and remove tires using your bare hands that had you cussing at tire levers.
Quoted: 325 Post(s)
Liked 109 Times
If you pull down on the valve, then there is a chance that the tire bead will land on top of the tube. If that happens, you'll see a big "tube tumor" form as you try to air up the tire. If you see it happening, you can always deflate and re-seat, but if you are on the side of the road using CO2, you will end up destroying the tube and/or wasting your CO2. This is why I use a mini-pump to check that the tire & tube are correctly seated before I deploy the CO2.
Quoted: 33 Post(s)
Liked 21 Times
Lezyne extra long tire levers
I have broken a bead jack trying to install a tire, but often does the job. I have old hands and arthritic thumbs so anything that can help install or remove I welcome. These extra long levers are long and strong and really accentuate your leverage. I was putting Conti 4000 tires on Roval carbon wheels and thought I'd die and kill my hands before I succeeded. These tire levers eventually did the trick.
https://ride.lezyne.com/products/1-tl-powrxl-v1nl04
just saw these, maybe even better:
https://ride.lezyne.com/products/tub...e79605db&_ss=r
I got several in the 80's .. the tire iron part breaks off so I file it smooth and add more separate levers..
Advocatus Diaboli
Liked 1,531 Times
Thinking about it.. especially maybe with CF rims now, you probably want a bead jack that will break at some point before your rim does. Maybe why they're not made out of steel?
Quoted: 4559 Post(s)
Liked 2,802 Times
Ditto, that Kool Stop bead jack. I stick it in my jersey pocket every ride until I'm sure the tires I'm riding can be mounted without the bead jack. It's lighter in weight than my mini pump, not really a hassle to carry. Sometimes I'll use a Velcro strap or bungee to attach it to the outside of my saddle bag.
Tire mounting varies a lot with ease or difficulty, and repeated mounting/removing can *sometimes* loosen the fit. But not always.
My trick is to mount the valve stem side first, then pinch it up into the tire casing (to move the fatter base of the valve stem out of the way), gradually pinching the tire together to center it along the rim into the recess. Often that makes the difference between needing a bead jack or using my hands. And avoid using rim tape that reaches too far up the rim wall -- it can hinder seating the tire into the bead hooks on some rims. I usually use Velox or other cloth tape around 10-14mm wide at most, just enough to cover the spoke holes. As long as the rim is clean and the tape has some tack, it'll hold in place.
With Continental Ultra Sport II, I need the bead jack every time. Those things never get any easier. Wire or folding bead, they're by far the tightest fitting tires I've used.
Schwalbe One V-Guards were very difficult to mount the first couple of times. They gradually got a bit easier, probably due to excess tire mold nibs rubbing off the bead.
Continental Grand Prix Classics were difficult the first time but since then I've been able to use my hands to mount 'em, despite arthritis. These have become my go-to tires because they ride well, don't cost much and are easy to mount/remove. And they look good if you like skinwalls.
Vredestein Tricomp Fortezza were about like the Conti GP Classics, pretty easy to mount after the first time. Ditto, an old 700x20 Michelin TT/triathlon tire, don't recall the model.
Vittoria Zaffiro wire beads are pretty easy to mount but terrible tires so they collect dust in the closet. Harsh ride at full pressure, sluggish at lower pressure, skid easily and the tread cuts easily. Worst road bike tire I've ridden. For the same money, about $10-$15 per tire, the Conti Ultra Sport II is far superior, despite the PITA tight fit and needing a bead jack.
I have used wide, smooth edged Bontrager tire levers instead of the bead jack, but half the time it'll nick the tube and I'm back to square one. Not worth the hassle.
Advocatus Diaboli
Liked 1,531 Times
So.. this ole wives tale about heating up tires has evidently been a bunch of hooey?! Maybe it made sense when wire bead tires were more a thing?
Likes For Sy Reene:
I just put some Corsas on my bike, the first time I have installed foldable tires. I found these difficult to install compared to old school tires in the past. I installed these two ways. the first by trying to place the slightly inflated tube in the tire, then slipping both beads over the tire. The second time, I did as the instructions said. I first installed one bead, then placed the slightly inflated tube in place, then worked the second bead over. MUCH simpler and easier.
Danny
Danny
Likes For kaiserschmarrn:
Quoted: 105 Post(s)
Liked 69 Times
G
Got this bad boy in the mail yesterday. Planning to try this a few times today. It arrived right after my big ride yesterday. Luckily didn’t get any flats. Hopefully 85mi & 9000ft climbing relaxed the tires a little . I think the size is good to carry in my jersey pocket.
