Flipping the cogs on a uniglide cassette
Old 09-10-20, 03:40 PM
robertj298
robertj298's Avatar
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times in 182 Posts
I flipped the cogs the uniglide cassette on my 83 Super Strada and wondering if that
could affect shifting.The bike was new to me and I never had the chance to ride it
before I refurbished it and flipped the cogs.The Dura Ace AX rear derailleur doesn't
seem to shift as it should so I don't know if flipping the cogs could be the problem
or the derailleur itself which isn't the same as any other derailleur I've seen.
robertj298 is offline
Old 09-10-20, 03:47 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Not on the cassettes, the shifting aide engineered features may only work in one orientation..
buy a new cassette & chain..
S-A 3 speed 13,14,15 are flat, Rohloff cog can be flipped too & Surly stainless steel chainrings..
fietsbob is offline
Old 09-10-20, 03:56 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2747 Post(s)
Liked 3,395 Times in 2,056 Posts
https://www.bikeforums.net/classic-v...-has-done.html
https://www.bikeforums.net/classic-v...geability.html
https://www.bikeforums.net/classic-v...lide-cogs.html
dedhed is offline
Old 09-10-20, 04:37 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
Flip them back.
Takes 5 minutes and you answer your own question better than we can.
Bill Kapaun is offline
Old 09-10-20, 05:56 PM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
Originally Posted by Bill Kapaun
Flip them back.
Yep I'll give it a try. I don't think very many people have any experience with this derailleur
Old 09-10-20, 06:20 PM
Bill Kapaun
Or there may be a lot of people and you just don't realize it.
Of course, you fail to provide any model# so we know what RDER we don't know about.
Old 09-10-20, 06:42 PM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
Maybe because there was only one Dura Ace AX rear derailleur AX 7300
Likes For robertj298:
Old 09-12-20, 07:05 AM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
Did you change the chain? A worn chain on a flipped cog might not work very well
alcjphil is online now
Old 09-12-20, 08:35 AM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
Yesi put in a new chain
Old 09-13-20, 09:05 AM
rosefarts
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times in 490 Posts
It's supposed to work just fine. Mine are dead symmetrical, so I can't envision it changing anything I I do flip them. I have the fortune of a very lightly used bike from the UG era, that I only put vanity miles on, so this won't be a problem for me for a long while.
After your flip, it's probably time to consider the future.
1. Sell to a vintage lover if that's not you.
2. Scour eBay for replacements, beware that Dura Ace isn't compatible with eh rest of the Uniglide line.
3. Change your rear hub to a freewheel, since 6 speed freewheels are readily available and dirt cheap. This feels like going backwards though.
4. Convert the whole bike to HG. New hub, new shifters, new cassette, new chain. Maybe more new stuff depending on your mood. 8 speed cassettes are going to be available for quite some time, or if you're worried, buy 4 today since they're cheap and stick them on a shelf.
5. I've heard tales of taking single HG cogs and grinding the wide tab narrow, probably with a Dremel. As long as the threaded last ring isn't worn out, this could work. Of course you need to find a cassette that is totally disassemble-able.
rosefarts is offline
Old 09-13-20, 09:10 AM
rosefarts
With a mighty wind
I wish I could help you with the 7300. I would love to have an AX group on a bike but haven't come across one yet.
My 7400 stuff adjusts just like any modern non electric. From pics, that AX stuff is different. Still, it's got to be pretty much the same, high and low stops and something like a b-screw. Just maybe in a different place. Have you tried turning screws to see what happens?
Old 09-13-20, 10:04 AM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
It's not that the AX shifts badly it just shifts differently. In my opinion the in derailleur index system doesn't work well. Downshifting it will work sometimes upshifting
not at all. The in derailleur index system isn't a click it's almost like hitting a flat spot when you shift so when you go through the gears its like sometimes feeling
that flat spot and sometimes it's just a friction shift. I may try picking up a Suntour Superbe Pro rear derailleur which I heard works well on this system
Old 09-13-20, 10:31 AM
rosefarts
With a mighty wind
The deraileur is indexed? Not the shifter? That's like the coolest thing I've heard in a while.
Too bad it doesn't work super well. Out of the box thinking for sure.
Does it have a switch like all indexing shifters, to switch it to friction?
Old 09-13-20, 11:14 AM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
Yes the derailleur is somewhat indexed and there is no switch to go to friction.
I believe the system was called positron. I really can't find anyone that can give
me their experience with this shifter to compare my experience Here is a write up
on it.Shimano Dura-Ace AX derailleur (7300)
