Saddle points down
Quoted: 7348 Post(s)
Liked 2,467 Times
Saddle points down
I can think of three reasons to have a saddle pointing down.
1. You unknowingly raised your saddle too high and need to point it down to effectively lower it. This is the most common reason. You may still be overextending your leg, and since the nose is not supporting your weight on your pubic bone, you might be putting excess weight on the handlebars, causing fatigue to your hands and shoulders.
2. Your handlebar is much lower than your saddle. This might be comfortable and efficient for you. It has become fashionable on road bikes lately but mostly for young and energetic riders.
3. You have unusual anatomy. Perhaps your pubic bone is lower that others' in relation to your sit bones. There are some people who have tried all the various methods of fitting their bikes, starting with the standard ways, and they find that this works for them. You might not experience excess load on your hands and shoulders.
Forgive me for grabbing images from bikeforums. The white bike might fit into the second category but if the owner asked me for advice, I would first check their saddle height.
Likes For noglider:
Passista
Quoted: 866 Post(s)
Liked 721 Times
I couldn't ride with the saddle pointing down that way - one keeps sliding down forward and the arms have to counter that.
Likes For Reynolds:
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I blame it on the you can make a small bike bigger logic. I’m not a French fit is the only fit kinda guy but if you need a mountain bike seat post on you traditional geometry road bike you need a bigger bike
Likes For Germany_chris:
Quoted: 1607 Post(s)
Liked 2,216 Times
So what you are saying is that pointing down is relative statement based on the three given scenarios.
For the second case, if the HB were at the same level as the saddle, it would be pointed up.
Quoted: 3464 Post(s)
Liked 2,829 Times
Wrong saddle. Or-
Low hours on the bike- way back I got sick and was off the bike for almost 6 months. When I resumed riding, my previously comfortable saddle was anything but comfy.
30 minutes was all I could tolerate.
In general, when I see a saddle so set up and I meet up at a stoplight with a rider having a saddle so mis-set, I ask about their lower back. They all complain of discomfort and then ask "how'd you know?"
As they are riding they are constantly attempting to overcome the slide they are on.
Likes For repechage:
Liked 2,467 Times
*Italian style saddles: my term for a plastic shell with a cover glued or stapled on, usually with padding between the shell and cover.
Quoted: 656 Post(s)
Liked 469 Times
I used to ride pointed slightly down and yes, I ride smaller frames than what would be French fit for me. As I've gotten older, slower and less agile, my saddles have leveled.
I see more bikes pictured with saddles pointed upward than I do downward.
Liked 2,467 Times
One might argue that an up-pointing saddle is the sign of an experienced cyclist. There are exceptions, as noted above.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
I never have understood the saddles that point down. I like to be pulling on the bars when I ride, not pushing. Who are these people who are pushing on the bars, and why are they doing this? I just don't get it, never have.
Quoted: 3810 Post(s)
Liked 6,694 Times
Hmm, so where is this one pointing?
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I see many bikes with aero-bars have nose-down saddles. My assumption was that resting ones forearms on the bars required a bit of crotch relief. Personally, I like a level or slightly nose-up position. Each saddle is a bit different.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
One, two, and three are all very good points, and the red Atala is a valid example of any of these three. Granted, I have a hard time understanding why someone would choose a given pair of drop bars if they can't tilt it so it's both comfortable in the drops and the bullhorn position, but that's another story.
However, that white fixie has "doesn't know how to size self to bike, more interested in aping funny bike stance" written all over it. That saddle angle looks as if it'll cause more medical issues than anything else. Plus, let's not forget the "brakeless fixie that's not legal for the track" cliché, which means whoever rides this thing will be using the tops, even though their bar grips are fashionably in denial of that fact. It's a silly build that cannot possibly be comfortable for extended periods of time.
For North Road and other upright riding applications, yes. But not so on the Pro and Swift - at least as designed though. These were designed to be more or less to be level (which makes sense, given the rider is now leaned forward against the bars), while the seating area is cupped to fit the sit bones, rather than the flat area of the B.72/66/67.
Granted, these are by no means hard and fast rules - one might want to nose up a Pro to combat slippage, personal fit, or medical reasons. I'm not sure the same applies for nose down on an upright bar Brooks though - the nose-up angle is significant enough that leveling it out would bring the rear a lot higher up than with most road saddles.
To the marketing department? For the most part, the actual points of contact between the body and the saddle aren't anywhere near the turndown on that saddle nose.
Looks like a great way to chafe the inner leg if you knee in.
-Kurt
-Kurt
Quoted: 656 Post(s)
Liked 469 Times
When I was in better cycling shape, a slight downward angle put me in a more aggressive, aero position. I wasn't pushing on the bars. just resting on them almost like a time trial setup. Use to lead packs for a lot of miles this way.
Quoted: 3811 Post(s)
Liked 3,338 Times
...hmmmmm have long wondered as the the saddle's possible utility as a dowsing rod
...then there are the "droop snooters" which seem to be made that way...
Quoted: 4806 Post(s)
Liked 3,928 Times
I consider the exact amount of downward tip critical and run 2-bolt seatposts on 4 of my 5 bikes. (5th is my workhorse city fix gear. Old Trek with a -22 degree 175mm stem. Post is a scratched up Campy Chorus 1-bolt. No detents and getting the tip right was easy. 10 years later, every time I get on that bike it is so right on perfect! Oh. that seat too is pointed down a bit.)
Ben
Liked 2,467 Times
Most of the Brooks Pro and B17 saddles I see have their noses up a bit. That's how mine always is. Maybe my pubic bone is high? Hmm, this reminds me that I made a phony blog about this in 2013. Maybe I'm obsessed with crotches.
@cudak888, what is illegal about that white bike for track use? The handlebars look legal.
Liked 2,467 Times
@79pmooney, you have special dispensation as a highly experienced rider.
Liked 4,395 Times
-Kurt
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
- Your bike doesn't fit
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
-Kurt
-Kurt
Junk orientation is unique I suppose but I’ve never had a Brooks that was comfortable any other way than nose up whether it be my Colnago, Serotta, or this Bruce Gordon
That particular one is angled down. For an SMP saddle, you place a level on it from nose to tail, and go from there. With the saddle level, there's a slight valley that you sit in. That's actually a fairly extreme down-angle for an SMP. Most are setup with the nose 2-3mm lower than the tail.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
Saddle angle is always funny to me.
I ride what is a flat saddle(at least I think it is). Tilting forward means I slide forward and why would I want that? Tilting back means pressure where it shouldnt be and why would I want that?
My BIL rides with saddles tilting down and I still shake my head when I see his bikes(multiple times a week for decades) because it makes no sense to me.
And I see obviously talented cyclists with the nose down a few degrees, so what do I know?
I used to have a couple of B17 saddles and accept that those need to be nose up a bit for the hammock effect as thats where you are supposed to be positioned. Ok fine. I see a lot of B17(or similar) saddles on here that are pointed so far up, I am confident in saying multiple posters have (un)intentionally checked their prostate on a ride.
But just like handlebar angle and brake lever angle- to each their own. Those two things, along with saddle, scream 'poorly set up bike' to me, but if its what the user needs to make the bike comfortable, then so be it.
Comfort = use and that is whats most important.
Likes For mstateglfr:
Senior Guest
Bikes: Jamis Endura, Cannondale CAAD, Raleigh Cross, Fausto Coppi.
Quoted: 80 Post(s)
Liked 47 Times
Professional riders can get away with saddle pointing down. They produce way more power on a given ride than we humans. Pros barely sit on the saddles, most of their weight is supported by their feet. Plus they are also more fit, ride more, younger, etc....They also have different priorities than us. Most modern races are relatively short up to 5 hours. Pros have more issues with foot pain than butt or hand pain. Tilted down saddle with straight seat post will let you have a more aggressive position allowing you to produce more power for a given time. It also creates other problems though...
Pros in the past had their saddles level and has set back seat posts for more comfort since the races were longer.
Novice rides have the saddles tiled down because their sit bones are not accustomed to riding yet. The longer the ride is the more problems tilted down saddles will cause. Riders will slide forward towards the handlebars, will lock elbows to prevent sliding causing neck pain, shoulder pain and handlebar palsy.
Personally I think for longer rides saddle has to be level with the setback seat post with less weight on the rider hands, elbows bent, otherwise pain will set in eventually
Likes For Andrey:
Quoted: 1163 Post(s)
Liked 442 Times
I have read recent article in Road Bike Action about modern assumptions about saddle design and saddle tilt. The stubby saddle trend which started more with triathaletes has now found quite a few proponents among regular road riders as well. Same with (slight) downward tilt. Road Bike Review talked about the saddle to bar drop and acted like a slight downward slope can in some instances be more comfortable when seeking to maintain the most aero position and when one rides the drops more.
The white fixie (photo # 2) reminds me of the type of photos you see when looking for used bikes on Craig's list. It looks like the person who set that seatpost and saddle up had no clue at all about what they were doing
I have developed a painful nodule in my perineum that causes me to rotate my pelvis all kinds of ways to relieve the discomfort while riding my favorite saddle - a Selle Italia Turbomatic Team Carbon. I have always kept the saddle flat. This practice always worked in the past but I’m beginning to realize that my 58 year old body might need a very slight downward tilt with more ab work and longer pulls in the drops along with standing climbing intervals just to keep all the pressure points decompressed.
Likes For masi61:
