Ofmega crankset removal - can't get access to the bolt
Bikes: 1994 Cadex CFR3, 2006 Scott CR1 SL, Rossin aero, Bertrand GB 2000, Spec Allez Pro
Quoted: 134 Post(s)
Liked 68 Times
Ignore this if it is a dumb question. I want to remove this crankarm to get access to my BB (which is toast). I removed the drive side without any serious problem, except for the fact that it was dirty and dry. Now my problem with this arm is that it seems like no socket is ever big enough for the crankbolt AND small enough to get inside the arm. I did not have such a problem on the drive side -- the bolt head seemed a bit smaller. Is there anything I can do besides looking for a set of thinner sockets?
(and while we're here : anybody has a magic trick to remove the patina on a crankset like this one?)
I recently had the same issue with an old bike.
You need as specific tool. I bought an XLC TO-S19 (look it up in Google) and it solved the issue.
Another option is to file a socket wrench, but the tool was 9.95€.
Likes For Amt0571:
Quoted: 1140 Post(s)
Liked 1,736 Times
For your patina, if it's not pitted you could try a rubbing compound. For more damaged alloy I've used steel wool, fine grit sandpaper 600 down to 1000, then used polish for final finished product.
Quoted: 836 Post(s)
Liked 1,060 Times
I can't tell what sized bolt head that is but spark plug sockets are thin walled and would probably fit if you have the right size. Sometimes the big auto parts stores have loaner tools that may include them.
Quoted: 1438 Post(s)
Liked 1,092 Times
Higher-quality sockets tend to have thinner walls. Something like Snap-On or pre-Kmart Craftsman might work. Or grind down a cheapie. Hit the bolt with Kano Kroil or PB Blaster beforehand to make it easier to remove.
IIRC, the "standard" for crank bolts used to be 14mm and yes, a thin walled socket is most often required. Some sort of penetrating oil will be helpful too! I do suppose that a "non-standard" bolt i.e. not 14mm, could have been used somewhere in this bike's past.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
While the bolt head size may vary among manufacturers (14, 15, and even 16mm heads were used), the thread was surprisingly consistent at 8mm x 1mm, so once you get the 15mm bolts out, you could replace them with 14mm bolts to get more socket clearance for future maintenance.
Quoted: 134 Post(s)
Liked 68 Times
Campagnolo, Ofmega, and many others used 15mm bolts, and a thin wall socket or dedicated "peanut butter" wrench was needed. As @dsbrantjr noted above, high-end sockets (e.g. Snap-On, Proto, USA Craftsman, etc.) tend to be thinner than low-end sockets and are more likely to fit. If you really don't want to buy the fancy socket or peanut butter wrench, you can grind the OD of a thick socket until it fits, but be aware that the low-end sockets are thick for a reason, and don't go overboard when torquing down the mounting bolts.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3881 Post(s)
Liked 6,475 Times
I bought a thin walled 15mm socket at the hardware store. I think it's an internal 12-sided one. Then I filed the outside, which took some time. It's still a tight fit sometimes, but it has always worked. Never had an issue with a 14mm bolt, where a normal socket always fits.
SE Wis
Quoted: 2744 Post(s)
Liked 3,390 Times
Either you find a thin wall that fits, campy wrench, or buy a cheap socket and grind it down.
https://www.bikeforums.net/classic-v...k-bolts-2.html
https://www.bikeforums.net/classic-v...set-bolts.html
https://www.bikeforums.net/classic-v...-crankset.html
Quoted: 2026 Post(s)
Liked 1,096 Times
Park used to make a multi-size crank bolt wrench, the CCW-2, in the style of the above Campy "Peanut Butter Wrench", that fit 14mm, 15mm and 16mm crank bolts. It's no longer listed but you may be able to find one on ebay or similar or an older bike shop may still have one.
It's quite possible that there isn't a "standard" for the wrench size required to to remove the crank arms from the spindles of bike from different manufacturers. My previously mentioned recollection of a 14mm "standard" was partially vindicated in my situation. I have a parts box with several spindle assemblies and found all of mine to require a 14mm wrench. I will add that all of the assemblies I checked used a nut rather than a bolt to secure the crank to the spindle! I would have to inspect some fully assembled bike's to see if any used bolts and see what size the bolt head was. I did check one bike where the crank was attached and found that my "pre-Kmart" Craftsman 14mm socket fit nicely on the nut !
I'm familiar with "peanut butter" wrenches but I'm unsure if they are designed to be used on the crank nut or bolt. I believe (with the square taper spindles at least) that there are torque specifications that would be difficult to obtain using a "peanut butter" wrench .
SE Wis
Liked 3,390 Times
The standards for square taper cranks are 14,15,16mm, sometimes bolts, sometimes nuts, ISO & JIS tapers, a couple different crank remover threads, and you haven't even gotten to BB yet.
Likes For dedhed:
Old fart
Liked 3,400 Times
