older sakae cranks
older sakae cranks
Old 12-15-20, 08:34 AM
trail_monkey
trail_monkey's Avatar
Bikes: Soma B Side, Soma Wolverine, Salsa Fargo
Quoted: 335 Post(s)
Liked 21 Times in 15 Posts
older sakae cranks
I have a couple sets from '80s road bikes that are in really nice shape. Are they comparable in quality to modern cranks such as Sram rival or other manufacturers?
trail_monkey is offline
Old 12-15-20, 09:44 AM
phobus
Quoted: 155 Post(s)
Liked 55 Times in 31 Posts
They can be. Some of the old forged cranks are really nice quality pieces.
On the other hand, and not to open a can of worms, but even some big-name modern cranks have questionable build quality and engineering. So just like you shouldn't automatically assume anything old is junk, don't assume everything new is great.
phobus is offline
Likes For phobus:
Old 12-15-20, 03:07 PM
trail_monkey
Quoted: 335 Post(s)
I I doubt these are forged. From what I've read online and seen and compared it looks like they're probably cast aluminum. But maybe my Sram cranks are also cast? I don't know. is one bottom bracket better than the other between square taper and external threaded? I know solid spindles with an external bearing are stiffer on mountain bikes but I'm referring to road and gravel bikes
Likes For trail_monkey:
Old 12-15-20, 03:18 PM
Moisture
Drip, Drip.
Moisture's Avatar
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times in 163 Posts
The question would be whether the new cranks are comparable in quality, not the other way around.
Moisture is offline
Old 12-15-20, 03:30 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,390 Times in 1,927 Posts
Sakae Ringyo made a whole range of cranks, from low-end cast (aka "melt-forged") units to high-end cold forged, polished and anodized comparable to the best of anything out there. They offered a bewildering number of models, sometimes cranks seemingly sharing the same model name (e.g. "Custom") being available with several different bolt-circle diameters and arm styles. That makes it difficult to definitively answer your question without knowing more about your specific crank.
JohnDThompson is offline
Old 12-15-20, 04:33 PM
TugaDude
TugaDude's Avatar
Quoted: 586 Post(s)
Liked 612 Times in 447 Posts
Velobase.com is a great resource for helping pin down year of manufacture and specific model. And I concur about "older" cranks. I own several vintage bikes that have some beautiful and durable cranksets on them.
TugaDude is offline
Old 12-15-20, 06:18 PM
dmark
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times in 142 Posts
SR Apex small BCD (86?) versatile triple and very high quality.
Last new bike 1991
dmark is offline
Old 12-15-20, 08:21 PM
veganbikes
Clark W. Griswold
Quoted: 4322 Post(s)
Liked 3,943 Times in 2,636 Posts
I haven't been able to get on VeloBase for a bit...apparently they are moving servers but I keep checking and it keeps being down. Hopefully things turn out well.
veganbikes is offline
Old 12-16-20, 01:51 PM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 644 Post(s)
Liked 1,044 Times in 667 Posts
I’m using a set of Sakae cranks on my SS vintage MTB. I can’t speak to comparisons with new cranks, but they seem unphased by SS duty on this bike, which involves the usual large amount of standing and hard pedaling. The arms are single piece construction and holding up fine under that workload.
I like Ike to keep the tread factor down, so using old road cranks like these and just the right length of BB to let the arms clear the chain stays helps.
The only downside is that it has the obsolete 118 mm BCD, so about the only chainring compatibility is old stock SR rings, mainly 40 and 52 teeth plus a handful of others in 42, and maybe 45. I’m glad to have found a NOS 42t ring.
Otto
ofajen is offline
Old 12-16-20, 06:58 PM
trail_monkey
Quoted: 335 Post(s)
Otto
Interesting. I have 2 sets. One use 110 BCD and the other is 144. I've never heard of 118
Old 12-16-20, 08:49 PM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 644 Post(s)
Exactly.
Otto
ofajen is offline
Old 12-17-20, 01:46 PM
veganbikes
Clark W. Griswold
Yeah people love to use odd BCDs for whatever reason. Campy did it on their Triomphe and Victory gruppos with the 116 BCD, Sakae did it for Apex with 118. Shimano did it a bunch I have some whacky XTR cranks that piss me off daily every time I see them as the BB works perfectly the crank arms are in decent shape but I need a new out chainring which is a spider for other chainrings and I can't deal.
58, 74, 104, 110 (5 bolt), 130, 144 is really all we need and if we could standardize down to those probably everyone would be mighty happy
Likes For veganbikes:
Old 12-17-20, 04:09 PM
JohnDThompson
Old fart
With Sakae Ringyo, it seems the name on the arm designates how the arm was made and may be found with different bolt-circle diameters; e.g. "Custom" and "Signature" arms are melt-forged and tumble-polished, and can have 86mm, 110mm, or 118mm BCDs. "Apex" arms are cold-forged, polished, and anodized, and can be found with 86mm or 118mm BCD. "Royal" arms are also cold-forged, polished, and anodized, but AFAIK only came in 144mm BCD. There could even be other variants I haven't encountered or can't recall.
Likes For JohnDThompson:
