TREK Emonda crank arm clearance
Bought a 2021 TREK Emonda SLR 7 with Shimano Ultegra Di2 for my 18-year old son who is a development athlete. But I was disappointed by the, practically non-existing, clearance between the right crank arm and the chain that has caused the chipping of the crank arm. When the chain is on the big front disc (52 teeth) and on the lower (heaviest) gear (11 teeth) there's barely any space between the crank and the lower part of the chain (there is a 1mm gap when the bike is on the stand but when my son rides the bike and presses hard on the pedals the gap is zero). The seller says that that's the way the bike was when it was unboxed and suggested to use a washer between crank and frame. But is this right? Has anyone had any similar experience? Because other that this setback the bike is beautiful and powerful. If I made this post in the wrong place please let me know. You can also see a relevant video on YouTube if you enter this ZW2vcDd61bQ in the search box. Thanks.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
A washer between crank and frame won't do much because the chain is exiting the crank. How often is he putting out a lot of power in that gear combo?
Are the scratches down the inside face of the crank arm too or just on the edge?
Likes For znomit:
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
Video assist
Likes For Sy Reene:
Advocatus Diaboli
Liked 1,531 Times
Doesn't sound like you bought the bike from an authorized LBS? Definitely should be a warranteable fix/replacement. Even if you are not the original buyer from a LBS, since this is a 2021 model, this seems would apply in Trek warranty terms, but you really want to get a copy of the original owner's receipt.
Subsequent Ownership
Subsequent owners (second or later) are entitled to a three-year warranty from the date of original purchase from the retailer. Proof of original purchase is required to validate the coverage period.
Otherwise a few things I can think of to check:
Rear wheel dishing off
Jockey wheel cage bent outward
Frame misalignment -- if you walk your bike down and along a straight line, are both wheels on that line?
Misaligned bottom bracket, maybe Hambini could look at for you?
Likes For Sy Reene:
Quoted: 741 Post(s)
Liked 412 Times
Could this be a crank issue? Possibly the crank arm is not within spec? Do you have another crank to use to test and see? Trek is usually pretty good about repairing/replacing Project One issues.
Likes For colnago62:
Likes For Reflector Guy:
Quoted: 9653 Post(s)
Liked 6,365 Times
You are not the first:
Chain touching crank arm. This only happens with big ring in front and in the 11t. All the shifting is fine and the cassette is lined up with the jockey wheel. Thoughts? Bike is new and not wrecked. : bikewrench (******.com)
I'd push Trek to fix it. In my experience, they are good about standing behind their product.
Edit: site won't let the link to the Red site show or work. But, someone with a 2019 Emonda SLR7 had the same issue. Trek replaced the frame and everything was hunky dory after that.
Likes For Mojo31:
Please see the video in my original post and also my latest comment on the thread.
OK, so here's an update on this issue. The local TREK representative received a proprietary 1mm-thick washer from TREK. He inserted it into the right part of the crank arm and (obviously) we now have a reasonable clearance between the crank armand the chain, about 2mm. Having ridden the bike for many many kms, the problem of the crank scratching the chain never surfaced again. The question though is why should this happen in the first place and also if by slightly changing the symmetry of the left and right distances of the cranks to the centerline of the bottom bracket, we create another problem.
Likes For Solarch:
Quoted: 551 Post(s)
Liked 722 Times
I think those scratches are from hitting the crank arm on the kerb.
Likes For znomit:
Expired Member
Quoted: 3658 Post(s)
Liked 5,404 Times
Good to hear this has been satisfactorily resolved. Your son will not notice the 1mm change.
Likes For shelbyfv:
