DIY Tools for your bike work
Quoted: 1607 Post(s)
Liked 2,216 Times
There are a number of threads that show tools you didn't buy but did make at home. RJ the bike guy has several videos with making your own tools.
A new thread was started asking what unusual items do you have in your tool box that are not typically bike tool related.
This one is what tools do you have that you made. I only have two that I can think of. The first is the RD hanger adjustment tool. The other is a tool for removing the Drum of an Arai drum brake found on tandems.
Quoted: 4510 Post(s)
Liked 6,377 Times
Gonna put these here just because, part home made, part repurpose , AND the fixed cup always come off, everytime, period.
Likes For oneclick:
Quoted: 964 Post(s)
Liked 1,451 Times
French crank extractor, because I can't afford a JA Stein, but I do have access to a lathe and was doing some Stronglight crank threads for those dustcaps anyway. Since this photo was taken, I made a second fitting, slightly smaller for TA.
I bought a spoke rolling head, but then realized I should have bought the whole threading machine. So I made one instead.
That's how the spoke is held in place: v-groove and a slotted brass bolt. Wing nut from a hi-hat cymbal. Look at that fiiine machining!
Also found this wrench while exploring the abandoned equipment storage yard of a defunct excavation company. It is a very high quality Proto brand forged steel wrench, ground down to work on cones. Strong! The other end is ground into a shape approximating that of a tire lever. I pocketed it in a hurry!
Likes For scarlson:
And this used to be my DIY headset press. I never worked well, so I eventually bought a real one.
Likes For southpawboston:
Likes For Reynolds:
Liked 2,216 Times
I forgot about he HS tool. Pretty straight forward. I also have crown race PVC installation tool and the typical copper HS removal tool.
Unique assembly of normal tools for accomplishing a task is acceptable! I had a bent crank on a Tern. Used a couple of wood block, Hi Lift jack and a break in the foundation between garages to straighten it out!
Passista
Quoted: 866 Post(s)
Liked 721 Times
Chain checker, tips are 12" apart
Right tip of chain checker, teeth are at 12" / 12 1/16" / 12 1/8"
Likes For Reynolds:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
Those two are practically professional quality! Well done.
I've thought of making a dishing tool myself, I think yours will be my inspiration.
Liked 5,795 Times
This was used once. I highly doubt I'll use it again. For fun, guess what it is.
Likes For gugie:
Quoted: 964 Post(s)
Liked 1,451 Times
Likes For scarlson:
Quoted: 321 Post(s)
Liked 263 Times
Bizarre! I'm going to guess some kind of spoke tension measuring device? You put a wheel in and shove some kind of probe through those holes that twangs on the spokes in some way that is meant to be informative of something?
Quoted: 765 Post(s)
Liked 660 Times
Here's my on-the-road freewheel remover, which is basically a functional and reliable version of the Pocket Pro from the 70's.
I think I have about a dozen of them. It makes me feel a little like Henry Thoreau, who had his first book, A Week on the Concord and Merrimack Rivers, published at his own expense. Most of the copies went unsold and ended up in his attic. He supposedly observed "I have a library of 1,000 volumes, nearly 750 of which I wrote myself."
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Quoted: 469 Post(s)
Liked 2,443 Times
I built this stand 10-12 years ago. I didn't have a workstand, but had a bunch of old copper pipe and fittings from plumbing and heating remodels. I've been meaning to put a coupling in the middle of it(for breaking it down), but laziness has won over.
I have a couple of proper workstands now, but this is what I always use for washing dirty bikes. I find it much easier to throw the bikes on the hooks, than to use clamps on on other stands, for simple tasks.
fwiw, it was a lot shinier ten years ago...
Likes For Roger M:
If I own it, I ride it
Quoted: 591 Post(s)
Liked 662 Times
Section of PVC pipe used to install crown races o fork.
Likes For woodcraft:
Friendship is Magic
Bikes: old ones
Quoted: 26402 Post(s)
Liked 10,374 Times
Likes For 3alarmer:
I bodged together this frame alignment gauge from aluminum u-channel, 1/4-20 t-bolts and knobs, and a plexiglass pointer.
DIY frame alignment gauge
Likes For ManekiNico:
Liked 6,377 Times
@southpawboston
Here's some more including the right angle pick that I scribe the threads clean with before using the chaser and anti-seize.
The pipe brush was a very welcome addition to get the threads clean before scribing.
And one of three actual sets that have saved my azz many times.
Bikes: Schwinn Continental, Schwinn Paramount, Schwinn High Plains, Schwinn World Sport, Trek 420, Trek 930,Trek 660, Novara X-R, Giant Iguana. Fuji Sagres mixte.
Quoted: 35 Post(s)
Liked 22 Times
My first bike repair stand from 2012, made to be installed in the end vise of my woodworking bench. I built up a bunch of bikes on it before getting a Park PCS-10.
Likes For Paramount1973:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
I made a locknut removal tool by notching a 3/8 pipe nipple when I took apart an Bendix yellow band recently. I didn't feel good about trying to properly adjust and tighten it when going back together so I had this one made from a 1/2-13 coupling nut that I can hold with a wrench instead of vice grips.
Likes For Chuck M:
Liked 5,795 Times
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
WOW, This is a great thread, I have made a list of tools that I will be making shortly....keep the hits coming!
Best, Ben
Best, Ben
Voltaire
Voltaire
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Quick 'n' dirty headset cup remover for the charity shop. Plenty of donor 25.4mm steel seat posts to sacrifice.
Likes For JohnDThompson:
