Chinook SunCR16 26"...Suntour XC hubs w/Panaracer tires
Quoted: 1199 Post(s)
Liked 1,354 Times
Chinook SunCR16 26" wheelset with Suntour XC Comp hubs. No skewers included. Cassette has been removed due to high usage and teeth are shark finned.
Panaracer Smoke Compe tires 26 x 2.1
Price $175 shipped. Venmo preferred but paypal also accepted
Quoted: 5887 Post(s)
Liked 3,469 Times
Just to be clear, these wheels require a 7 speed suntour cassette and the buyer will need to track one down as the existing cassette is no good, right?
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Is it a Microdrive freehub? The cassette would have had the last two cogs as a unit. The largest cog is probably a 24 or something if it is.
Likes For Unca_Sam:
The dropped
Liked 1,014 Times
I keep watching this, and it's getting dangerously close to "buy it anyway" pricing!
I have an '89 Cinder cone I restored to full Suntour XC components, and I have a second wheel set I still need to replace the front hub with the XC Comp hub gathering dust in the basement. I have (!) a 7 speed Suntour cassette installed on both rear wheels, plus an extra Microdrive cassette and hub (Microdrive was Suntour's name for their compact drivetrain). I stuck with the normal stuff because I didn't intend to swap out cranks for the smaller MD rings to make the smaller MD cassette more manageable for me, a mere mortal.
The only reason for the second wheelset is because I want to be able to make a 'pony' CX ride out of the Cinder cone, and the narrow 26" Matrix rims on the second wheelset are ideal to mount the narrow Schwalbe CX Pro tires I have and keep them narrow. I just measured the outside width of those rims as 20mm, which means your set might be using the same width (assuming the 16 is for the IW). It's unfortunate that the AP cassettes are so rare, and therefore expensive.
Liked 1,354 Times
@Unca Sam I won't be able to go lower on pricing but let me know if you're interested.
Shipping to eastcoast has gotten a bit more expensive even with shipbikes.
The dropped
Liked 1,014 Times
