1995 Stumpjumper Headset recommendation
Old 02-24-21, 05:39 AM
adrockr
Hey. My headset is thrashed and while I could get by with just getting the bearings, I just want to do the headset. It's a threadless. I don't want to spend too much. I'm not riding it very hard. I don't need stock, something more modern would work if possible. Help me out, I'm a headset noob (edit: "nube" ??) . What am I looking for?? It appears to be 1 1/4.
adrockr is offline
Old 02-24-21, 05:50 AM
dsaul
Quoted: 714 Post(s)
Liked 800 Times in 475 Posts
Any 1 1/8" EC34(External Cup 34mm) threadless headset will work. Cane Creek 40 series is the best value for the money, but there are plenty of less expensive headsets that will work fine, as well.
dsaul is offline
Likes For dsaul:
Old 02-24-21, 07:45 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
Originally Posted by adrockr
Hey. My headset is thrashed and while I could get by with just getting the bearings, I just want to do the headset. It's a threadless. I don't want to spend too much. I'm not riding it very hard. I don't need stock, something more modern would work if possible. Help me out, I'm a headset nube. What am I looking for?? It appears to be 1 1/4.
WHAT appears to be 1-1/4”? The diameter of the steer tube of the fork?
There were some 1-1/4” threadless steertubes out there in the 90s, but 1-1/8” was more common.
Kapusta is offline
Old 02-24-21, 07:50 AM
DorkDisk
Quoted: 576 Post(s)
Liked 1,001 Times in 488 Posts
Most likely 1-1/8". +1 on anything. Just mind the lower stack height, as older headsets were all over the place and this impacts the geometry quite a bit.
DorkDisk is offline
Old 02-24-21, 08:21 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
+1 on either the Cane Creek 40-series or Velo Orange's Gran Cru headsets. Both are reasonably priced and have good sealed cartridge bearing. The Gran Cru has a "split" crown race which allows tool-less installation.
HillRider is offline
Old 02-24-21, 09:01 AM
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times in 601 Posts
I doubt it's a 1-1/4. Make sure of the size. My '94 Stumpy is a threadless 1-inch.
2cam16 is offline
Old 02-24-21, 09:23 AM
HillRider
If it is 1" threadless, Cane Creek's 40 is one of the few headsets available in that configuration.
Old 02-24-21, 09:36 AM
DorkDisk
Quoted: 576 Post(s)
On the early 90's steel models, the standard rigid models were 1", the FS with suspension were 1-1/8"
DorkDisk is offline
Likes For DorkDisk:
Old 02-24-21, 09:47 AM
adrockr
You are correct! My Mistake. 1-1/8"
adrockr is offline
Old 02-24-21, 09:48 AM
adrockr
Yes. My mistake. It is 1-1/8. I just went out and measured the fork with calipers.
adrockr is offline
Old 02-24-21, 09:50 AM
adrockr
The fork is 1-1/8.
adrockr is offline
Old 02-24-21, 09:56 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
The fork is 1-1/8.
Then dsaul' rec is a good one. But really, any cartridge bearing headset of that size from Cane Creek (the 40 is good, as is the 10 if you want to save a few bucks), FSA, or the like will do. Just look for a standard 1-1/8" external headset.
Kapusta is offline
Old 02-24-21, 04:34 PM
2cam16
2cam16's Avatar
Exactly.
2cam16 is offline
