Zipp Service Course SL Stem & Quadlock Handlebar/Stem Mount
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1947 Post(s)
Liked 1,469 Times
Does anyone have experience installing this Quadlock mount on the top of a Zipp Service Course SL stem?
Cycling - Handlebar/Stem Mount - Quad Lock® USA - Official Store (quadlockcase.com)
The bottom of this mount seems to be designed for a perfectly round stem. Would it mount flush onto a Zipp Service Course SL stem?
I just bought this stem and it seems to have a bigger stack height and a wider clamp width than my Cannondale C3 stem, so installing it would displace my Quadlock Out Front Mount Pro.
I don't know why this stem is so huge. It must be built for Donkey Kong (in Mario Kart 8).
Quoted: 741 Post(s)
Liked 412 Times
Liked 1,469 Times
Quoted: 173 Post(s)
Liked 57 Times
I hope you're kidding. I never understood why people avoid using certain products because they fear looking like a poser. If you like it, use it. I had a Zipp Sprint SL stem on my bike because I liked the way it looked. I mean, I can sprint pretty quickly, but that's besides the point. Use what makes you happy and don't worry about what other people might think.
Liked 1,469 Times
Quoted: 173 Post(s)
Liked 57 Times
I also ran into this issue. My K-edge out-front mount is standard length. The Zipp faceplate protruded a tad more and clamped with a wider footprint. There may have been 1mm between the faceplate and my Garmin. It felt like the garmin was just barely making contact with the faceplate whenever I would dismount it. If you look at the shape of the garmin, they had this in mind when designing it.
Likes For colnago62:
Liked 1,469 Times
In the mean time, I have ordered a Deda Elementi Zero 100 stem.
Liked 1,469 Times
The zipp stems work great, but I wouldn't strap something that big and ugly onto mine and then add a 200 gram phone to it. I like my tiny cateye computer with speed, cadence and heart rate.
Liked 1,469 Times
Yes, that is certainly an inelegant solution, but I am not going to bike without my phone. I wish my phone was only 200g; my iPhone 8+ was 202g, and my new iPhone 12 Pro Max is 228g!
Hey guys, I'm currently building up my wife's tarmac. Adding Specialized aero bars and a Zipp stem (to match the wheels of course). Thinking about an SL Speed 90mm with the Quickview out front mount for here Iphone. What's the best attachment to get the phone on the mount? TIA.
I like speed
I don't think you'd have an issue putting the Quadlock on there. I use the same stem and don't think the profile will be an issue.
It sounds like you're using your phone as a cycling computer? Maybe use this as an excuse to put an out front mount and new comp then stick the phone in your pocket.
Quoted: 1528 Post(s)
Liked 718 Times
I put a cheap Aeronova knock-off on my bike and the front end got ridiculously flexy. Swapped out the Kalloy Uno for one of these Zipp stems, and it was perfect.
You might want flexy bars, but a flexy stem is mucho sucko.
