Pinstriping
Bikes: 82 Trek 710, 90 Trek 750, 86 Vitus, Nishiki Cervino, 1989 Bianchi CdI, 2 Nashbars, an Italian Steel MTB, Sears Spaceliner, and a 74 Schwinn Speedster. I also manage a fleet of Volcanic Patrol bikes, 83 of them.
Quoted: 109 Post(s)
Liked 234 Times
Pinstriping
Not sure if this is the correct subform or not but I am looking for advise.
I bought a frame off Ebay that is lugged steel, Champion 2 and I would like to pinstripe the lugs. I found several different ways to apply, brush, Vintage Beugler Striper De Luxe and a cheeper one on Amazon.
My question is has anyone used the Beugler striper or a brush and what does anyone recommend for an amateur?
Picture for reference...
Randomhead
Liked 3,696 Times
The people I know of that do pinstriping use a buegler, which are still available new. And possibly a Kemper fluid writer and brushes. If you get a fluid writer, buy the large.
I have thought about getting a buegler, but I have no immediate need, so I keep putting it off. I imagine the main thing is just to practice.
Quoted: 4204 Post(s)
Liked 3,861 Times
The Google Groups "Classic Rendezvous lightweight vintage bicycles" group speaks well about using a Kemper Fluid Writer for lug lining, where a thin line is considered the nicer look. I would think for pin stripes a slightly wider line is the better look. For box lines back to the thinner width. So I guess a well equipped painter would have a few different tools. Andy
AndrewRStewart
AndrewRStewart
Quoted: 109 Post(s)
Liked 234 Times
Thanks, the Kemper Fluid Writer looks interesting. It looks like you might need to fill it every time you line a lug.
I was trained as a graphic artist so I've used different pens for drawing lines (Rapidograph) pre-computer aided drawing tools I just haven't tried anything lie this. I'm probable going to order the Beugler and try it out.
framebuilder
Joe Bell is the one that got me started using the Kemper Fluid Writer. I think that is what all my pro colleagues use now too. I've used a number of tools/methods over the years. Paint pens were popular for awhile until we got wind of the Kemper. Besides the application is also the problem of bits of removal if necessary. I've used toothpicks among other options. .
Likes For Doug Fattic:
Quoted: 109 Post(s)
Liked 234 Times
I just saw another thread that, I don't remember what to call them, pens were used. I used these in a past life as a graphic artist. I only used ink but a video show them being used with paint. I have a bunch of Testers enamel paints I'm going to try.
I was able to find mine. They need cleaning but I think they'll work.
https://www.bikeforums.net/classic-v...ing-brush.html
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
https://youtu.be/1Oo9WwzsR7g
Those are ruling pens, I have used them and while they are good I have found if not careful small scratches can occur and it is difficult to turn a corner (maybe I need more practice/patience.). What is nice about them is for box lining they leave a sharp not a round end on the line that you are making.
For box linning, I have used thin cardboard as a guide....Put a layer of blue tape 1/8 of an inch away from the line you want to make and then overlay/lap the thin board as the guide. Much like we find on templates where there is a little space left so that the ink/paint will not flow under the template.
I have also had great success with Koh-I-Noor Rapiographs, which you may have in your arsenal. 4 or larger....thin the paint so that it flows easily. These are much easier to control than the others mentioned that have been mentioned because they are like a pencil or pen.
But for my cars, nothing beats a striping brush!
Best, Ben
Rapidograph's
Super old school....harder to control....but it can make letters!
Nothing beats One Shot Enamel...if using Testors, be sure to thin it well, otherwise, it will not flow properly.
Voltaire
Voltaire
Quoted: 109 Post(s)
Liked 234 Times
Boy Ben, those Rapidographs take me back! I only have one left and its really small so it probably won't work.
I found a store by me that carries the One Shot so I'll try that. The thin board for a guide is a great hint, thanks. I also ordered a Kemper Tools Fluid Writer Pen to try my luck with. I have a Nashbar frame I'm going to use as practice.
Liked 2,181 Times
Try eBay for a Rapido's 4-6-8 they are there,
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Liked 2,181 Times
Joe,
Just be sure to get the board or acetate sheet high enough so that the paint doesn't bleed through.
Good Luck, Ben
Good Luck, Ben
Voltaire
Voltaire
Randomhead
Liked 3,696 Times
I am pretty sure I still have my Rapidos from when I did drafting. How do you clean paint out of them?
Quoted: 109 Post(s)
Liked 234 Times
Ben,
I'm guessing you're using One Shot Enamel in the Rapidiograph. Do you thin it so that it flows in the pen or are you using it at full strength?
framebuilder
One thing I want to mention about doing pin striping and that is pin striping specific paint has more pigment so a couple of applications is not necessary so the paint color underneath is not visible. There is nothing more problematic that doing a nice job but the paint doesn't cover well enough and you can see through it to the base color. If one thins down regular paint so it flows more easily, then it can be too thin to cover the undercoat color adequately.
House of Kolor makes a pin stripping pain that comes in a very small paint cant. Of course it is expensive but they come in a variety of colors.
Quoted: 809 Post(s)
Liked 1,022 Times
The video below was posted on the C & V section about the Taylor brothers bike business. At 25 minutes in, I believe that it may be Jack Taylor that is box lining a tandem frame. He does it so effortlessly. Of course, he has lots of practice.
It looks like a Beugler, with a wheel, however, it may be an English made one. There was also a video of Raleigh DL-1 getting box lined and the woman lining the frame used a similar device. So, this English wheeled pinstriper may pre-date the Beugler.
Wheels are good for pinstiping and boxlining. If you are talking about lug lining, then a wheel would not be the right tool.
I used a drafting ink tip with Testors paint. It worked, however the lines were not as thin as I would have liked. When I tested it on paper the paint made nice thin lines. When I moved to the bike frame the paint, the gold paint flowed out a bit more and became fatter than I would have liked. I was unsure if I needed to thin it more because it was already flowing too much. So, I am still looking for a better solution or need to improve my technique for lug lining.
Randomhead
Liked 3,696 Times
I think you meant about 12 minutes in. It does look effortless.
Liked 2,181 Times
Long straight lines use a thin piece of cardboard over a layer of acetate sheet or dbl masking tape so the paint won't bleed.
Best, Ben
Voltaire
Voltaire
Liked 2,181 Times
Voltaire
Voltaire
Likes For xiaoman1:
Quoted: 28 Post(s)
Liked 60 Times
Likes For GrayJay:
