Help calculating differences with changing cogs
Old 05-14-15, 07:10 AM
wvrick
Bikes: TerraTrike Rover , Giant Boulder SE
I need a little help calculating differences with changing cogs and the increase in speed on my recumbent trike. I'm trying to use a phone app and not sure if it's correct. What I'm looking at is if I change my rear cog from a 20t to 16t the increase in speed. Specs... chainring 42t (170mm arms) 20t cog (current) 20x1.75 tires I get 15.2 mph max with my cadence. The app says 19.1 mph with a 16t. Does this sound about right?
Thanks!
wvrick is offline
Old 05-14-15, 09:02 AM
welshTerrier2
welshTerrier2's Avatar
Quoted: 67 Post(s)
Let's start at the beginning so you'll understand this better. There's a piece of data missing with the numbers you provided.
First, you need to understand the concept of "gear inches". Gear inches (also called development), is how far the bike will travel with each revolution of the pedals. The distance varies based on the following formula:
gear inches = wheel diameter * teeth in front chainring / teeth in rear sprocket
So, given your 20t setup, you would have 20 inches * 42t/20t = 42 gear inches
On edit:
This means that for each revolution of the pedals (in those gears), the bike will move forward 42 inches times pi (use the circumference of the wheel (pi * d)).
Now, changing the 20t sprocket to 16t, you would have 20 inches * 42t/16t = 52.5 gear inches
This means that changing from the 20t sprocket to the 16t sprocket, for each revolution of the pedals you would travel 10.5 inches times pi further.
When you add the element of speed to the discussion, you have to know your cadence which is the rate at which your are spinning the pedals. Given your app's statement that you would be traveling at 15.2 mph (it has to know your cadence to provide this information), changing from the 20t to the 16t sprocket would yield a speed of 15.2 * 52.5 gear inches / 42 gear inches. This would yield 19 mph. This means that making the switch, if you maintain the same cadence, would increase your speed from 15.2 to 19 mph.
You cannot convert gear ratios to speed without considering cadence. Without extra effort, you would not see any increase in speed at all. Going from 20t to 16t, without extra effort, will increase your distance per pedal revolution (i.e. gear inches) but it would correspondingly decrease your cadence because it would be harder to pedal.
By the way, there are more things to consider when changing a single sprocket. You should also consider the jumps between the next higher and lower gears. There's something to be said for keeping a consistent relationship from one gear to the next.
Hope this helps.
Last edited by welshTerrier2; 05-16-15 at 04:53 AM. Reason: corrected development to use circumference instead of diameter
welshTerrier2 is offline
Old 05-14-15, 12:22 PM
hueyhoolihan
Quoted: 86 Post(s)
Liked 4 Times in 4 Posts
the faster you pedal (cadence), the faster you go, no matter the gearing. you need to decide what cadence is max for you. they vary from individual to individual, a lot . and there is a time interval involved in your 'max' to consider too.
hueyhoolihan is offline
Old 05-14-15, 12:32 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Plug in your numbers and let someone else do the math:
Mike Sherman's Bicycle Gear Calculator
caloso is offline
Old 05-14-15, 12:56 PM
Little Darwin
The Improbable Bulk
Little Darwin's Avatar
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times in 7 Posts
If you can maintain the same cadence with the higher gearing the speed is relevant. On a recumbent, you are fighting less wind resistance than most cyclists, so it could be doable.
However, it sounds like you are riding a single speed, you need to remember that the smaller cog will make starting from a stand still (or accelerating from low speed) more difficult, and also any hill climbing could be more difficult.
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
Little Darwin is offline
Old 05-14-15, 03:31 PM
wvrick
Thanks for supplying the formula, I found the result from Sheldon Brown's site after posting but will remember how to work it now.
Yes I'm riding a recumbent and with a internal hub (Nuvinci N360) and I think I'll not have a problem maintaining my cadence since when I max out my speed I spin out as well... like I'm looking for more overdrive.
wvrick is offline
Old 05-14-15, 03:43 PM
wvrick
cadence
This was an unknown while I was riding(I never counted), while I was using the android app I used the known data I had from the cheap meter: Max speed (15.2), and from the hardware specs: wheel(20x1.75),crank size(170mm),chainring(42t),cog(20t) and with this entered in the app the slider for cadence I moved until my speed showed 15.2 and this is where I got cadence. I'm not sure that worked like that but when I changed the cog to 16t from 20t I got 19.1 mph.
wvrick is offline
Old 05-14-15, 03:47 PM
GhostSS
GhostSS's Avatar
Bikes: 2012 Switch Performance BlackSkin LE Urban, 2013 Leader 725, 1975 Fuji America, 1990 Giant Cadex 980c, 1986 Peugeot PH10LE, 1995 Trek 2120 Carbon ZX
Quoted: 5 Post(s)
Liked 22 Times in 13 Posts
Use Sheldon Browns calculator
Sheldon Brown's Bicycle Gear Calculator
GhostSS is offline
Old 05-14-15, 04:09 PM
groth
astro
Bikes: Raleigh Sports, '72, Bianchi Volpe, '97 (no more, it died), Greenspeed GTVS6, '05, Trek 520, '13
Quoted: 43 Post(s)
Liked 51 Times in 25 Posts
You guys are making this too hard. If the cog is changed from 20t to 16t and everything else, including the cadence, stays the same, the speed goes up by the ratio of the teeth: 20t/16t = 5/4. 5/4 x 15.2mph = 19.0 mph.
- Ed
groth is offline
Old 05-15-15, 07:06 PM
dave42
dave42's Avatar
Bikes: 1989 TREK 400, Suntour accushift drivetrain. 80's Raleigh mtb all Suntour.
not quite right regarding development
But close.
Gear inches refers to the wheel diameter you would have if you were riding a penny farthing.
Development...distance traveled, is gear inches times pi.
assume a 700x25tire...
So, 26.4x 42÷16x3.1416= =217.71288inches traveled.
/12x60/5280=.206
.206 x cadence= mph.
shorter formula is this:
Gear inches times 0.00297 times cadence=speed.
just remember the .00297 and yer good.
dave42 is offline
Old 05-15-15, 07:09 PM
dave42
dave42's Avatar
I like this one real good... Sheldon Brown's Bicycle Gear Calculator
dave42 is offline
Old 05-15-15, 07:53 PM
BlazingPedals
BlazingPedals's Avatar
Quoted: 1514 Post(s)
Liked 734 Times in 455 Posts
This means that for each revolution of the pedals (in those gears), the bike will move forward 42 inches.
Nope, the gear inches are the equivalent diameter of a tire if it were using a 1:1 drive (tricycle wheel.) The development is how far you'd travel, which is the gear inches times pi.
BlazingPedals is offline
Old 05-16-15, 04:48 AM
welshTerrier2
Quoted: 67 Post(s)
Thanks, that's correct. The development needs to use the circumference and not the diameter. I'm going to edit the original post to correct the error.
Old 05-16-15, 12:22 PM
dave42
dave42's Avatar
Welsh, it won't let me quote you...
Hope i didn't come across wrong. Long day, and text is a cold medium, anyhow.
I like your 336 number. Ill have to use it more.
easier than .00297
dave42 is offline
Old 05-17-15, 12:38 AM
CycleryNorth81
Quoted: 350 Post(s)
Liked 203 Times in 118 Posts
[QUOTE=shorter formula is this:
just remember the .00297 and yer good.[/QUOTE]
The math doesn't work out:
Gear inches x 0.00297 x cadence= speed
(20 inch wheel *42T/20T as stated by @welshTerrier2) x 0.00297 x cadence= 15 mph (as stated by OP)
42 gear inch x 0.00297 x cadence = 15 mph
cadence= 15/42/0.00297
cadence= 120
cadence is quite high
CycleryNorth81 is offline
Old 05-17-15, 08:52 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
Sometimes I feel like an analog man who's been trapped in a digital universe. I think that you're working at this too hard.
1. Forget about speed for a minute. If you put a Ferrari transmission into some econo box car, it still won't go 150 MPH. You have to have the power to push it.
2. As you ride, when you feel like your feet are spinning too fast, shift into the next hardest gear. If that gear feels too hard, you need a cassette with closer gear spacing.
Retro Grouch is offline
Cen
Track Cycling: Velodrome Racing and Training Area
40
09-26-18 03:54 AM
rgr555
Road Cycling
53
03-29-18 04:11 PM
Elysium32
General Cycling Discussion
8
10-23-14 03:43 AM
oneidabow1
Singlespeed & Fixed Gear
4
08-20-14 01:58 PM
Howard
Classic & Vintage
3
10-01-12 07:32 PM
