An Old Jo Routens Randonneuse!
Quoted: 981 Post(s)
Liked 1,844 Times
Hello all,
I'm finally diving into the French scene with a splash after receiving a box from France last weekend. This afternoon I took the time to assemble the bicycle as purchased...
It's a Jo Routens randonneuse that probably dates from the 1950s, based on the description of the seller (who also thought it might have been a Sabliere) as well as a handful of other notable collectors, who at least all agreed that it was a Routens! The frame and fork are made from lightweight FOBUR tubing (you can look that up if you're curious) that was commonly used by Routens and contemporary builders in the region during the immediate post-war era. The frame was modified to accommodate modern gearing sometime during or after the 1970s, as the Huret hanger, derailleurs and shifters attest to. However, the lovely sealed-bearing Maxicar hubs are the first generation with blue caps on the cartridges, which means they pre-date 1947. Besides that, there is the neat proprietary stem, nicely integrated fenders and front rack, Stronglight crankset, Lyotard 460 pedals, Mafac levers and calipers, AVA rims, and a rather crusty Ideale saddle... The seatpost was cut to accommodate the rear brake cable that passes through the seat tube, so I have it set 3cm lower than I usually ride and will need to find a replacement.
I re-greased the headset putting the bicycle together but everything else needs to be gone through and all of the consumables need to be replaced as well. However, it rode super quietly and smoothly down the road as is with just around 40 pounds of pressure in each of the old Wolber tires.
There are two other project bicycles nearly complete in my queue and then I'll move onto this one. I'll get it into tip-top mechanical condition before any major cosmetic work gets done. However, I'm already wondering if it's a tad small for me and debating whether or not that'll seal its fate before I even begin the restoration process... If it's not to be, then I'll probably pass it on to one of you fine folks! Cheers!
-Gregory
-Gregory
Likes For Kilroy1988:
avecReynolds531, bboy314, bear_a_bug, Bianchigirll, billytwosheds, bulgie, cudak888, cyclic_eric, darkmoon, Dfrost, djkashuba, droppedandlost, Dylansbob, ehcoplex, El Chaba, Ged117, juvela, Kabuki12, machinist42, mrv, non-fixie, northbend, Paul Waque, PilotFishBob, polymorphself, poprad, rustystrings61, santa fe 2926, scarlson, seypat, SJX426, Soody, Straightblock, The Golden Boy, velomateo, Vonruden, zookster
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Wow!!!
Likes For 52telecaster:
Likes For fender1:
Likes For Force:
Quoted: 3464 Post(s)
Liked 2,831 Times
A bike of the decades.
needs to be Black I think.
Likes For repechage:
Quoted: 3814 Post(s)
Liked 3,345 Times
shall definitely look forward to following along here - whenever it will be that it becomes a front hob becane
if Stronglight spindle at all contemporaneous to cycle it shall have a two digit number stamped into one of the taper flats on the drive side
the two stem binders and the seat binder are ALGI bits
have a set of MAXI's similar to these with the blue anodised caps but alas electrolysis got going between the hub shell and the spokes so that the flanges have become somewhat dematerialized
congratulations on this wonderful find and thank you for sharing it with the forum
Likes For juvela:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Likes For cudak888:
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times
Congratulations! You have certainly stepped into the world of French bikes in fine style.
Brent
Brent
Likes For obrentharris:
Likes For Imazagi:
Likes For velomateo:
Likes For Vonruden:
Quoted: 874 Post(s)
Liked 2,290 Times
Beautiful bike . I hope this gets the full treatment, although it is presentable as it stands. I have not gotten into the French touring bikes myself , save for a Motobecane or Peugeot. This is in another league.
Likes For Kabuki12:
Likes For jet sanchEz:
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 470 Times
Hi Gregory, what a machine you've found! Of course, I am going to scurry over to French eBay now given your example. I know with your attention to detail put to work on this thing, the bike will be made ready for another 70 years of service.
When I've searched for similar, they are always too small. It seems to me that few larger-sized bikes were built - I hope this fits you, but if it doesn't, it looks like it would fit me...
Likes For Ged117:
Quoted: 981 Post(s)
Liked 1,844 Times
Good morning, folks! Thanks for the compliments, I'm very excited about the bicyle for sure.
repechage If it gets to the point where I know I'll be keeping it then a new paint job is definitely in order. For the time being the plan is to do a dark blue with red single box lining akin to a handful of Routens I've seen in their original paint.
juvela Thanks for the information on the ALGI parts, and all will be revealed once I start tearing it down again! Will keep an eye on that spindle.
Kabuki12 I hope I get a chance to restore it completely as well! I have already purchased a reproduction set of the main downtube decals and will wax and polish all of the parts as is while getting it back into top riding condition. A second tear-down and paint will be in order if it works for me, otherwise I don't want to do that and then sell it to someone who might have a different color in mind!
jet sanchEz The paint is not original. The bicycle would have probably originally had a stay-mounted rear derailleur and one of Routens proprietary front derailleur mechanisms, and the associated braze-ons were removed and the dropout hanger added at some point in time along with the current paint, by the look of things.
Ged117 I'll keep you in mind as #2 on the list!
Since I'm sure some are curious, the seat tube measures 60.5cm from center-to-top with a 56cm center-to-center top tube. This is almost identical to some of my other bikes but the way these frames were meant to fit is a bit different, so we'll see... Cheers!
-Gregory
-Gregory
framebuilder
One way you could tweak the fit of this bicycle is to have a new stem made. Any good framebuilder could copy that style. Of course the original stem was made so it is level but it could be angled up just a bit. And the length could be altered so your seat and handlebars are in the perfect position for you. And the new one could be painted to match.
This style of bicycle was made to ride comfortably not win a race. Most likely that means a slightly higher handlebar position.
Likes For Doug Fattic:
Quoted: 981 Post(s)
Liked 1,844 Times
Doug Fattic Thank you, Doug. I already engaged with Mark (gugie ) prior to even receiving the bicycle and I'll likely only need the tube that's brazed into the steerer extended about an inch and a half with the original stem, which Mark would then add material to the bottom of so it still sits flush atop the headset. Then I'd get it rechromed. That's the plan, anyway.
I'll clean and paint the stem as is and should be able to judge how much more effort I'll put into it all.
I purchased the required consumables this morning and will report back in a few weeks with fresh photos and a ride report!
-Gregory
-Gregory
Randomhead
Liked 3,699 Times
I like the way that front rack is mounted. I have always thought that a Berthoud fender would work as a rack if there was a way to support a bag.
Likes For unterhausen:
Likes For OTS:
Quoted: 874 Post(s)
Liked 2,290 Times
When Mark finishes the stem modification you may want to look into nickel plating, I think it is more appropriate for such a rare piece. Also , pardon my ignorance , but the stud(s) on the side of the stem are for....?
Quoted: 981 Post(s)
Liked 1,844 Times
-Gregory
Quoted: 874 Post(s)
Liked 2,290 Times
I am sure there is a nice bell out there somewhere that would be appropriate! Thank you for the clarification , as I say , no knowledge of these type bikes . Just a huge appreciation . Joe
Likes For Kabuki12:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,801 Times
"Triple" chrome is Copper - Nickel - Chrome in that order, restoration work is typically this method (best quality), so nickel is almost assuredly avaialble.
Likes For gugie:
Not lost wanderer.
Quoted: 886 Post(s)
Liked 998 Times
The fitment of the tubing and the brazing that holds it together is amazing. Looking forward to the cleanup and build.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Likes For bwilli88:
Liked 5,801 Times
If'n I do a stem mod, it'll be easy to get a vintagy bell integrated properly.
Cause, constructeur.
Likes For gugie:
