Topstone vs Checkpoint
Quoted: 722 Post(s)
Liked 353 Times
Both are new and seem decent if you had $1200 what bike do you get
I assume we're comparing a Checkpoint AL 3 to a Topstone Sora, right?
If so, the Sora is $1050 and the Checkpoint is $1199. As they're both mechanical Sora and aluminum frames, I'd absolutely go for the Topstone and use the $150 to get some accessories.
I've got about 35-40 miles on a Topstone demo and own a Checkpoint (a carbon model). So my direct comparison of these two bikes is somewhat tangential. But you could do a lot with the $150 (slick tires, nice shoes, some new shorts, maybe some lights, whatever you might need).
Bikes: Kona Unit, Kona Kahuna, Kona Dew DL, Scott Big Jon, Trek Checkpoint ALR4, KHS Urban Soul, Haro Team Issue, GT Force Expert Carbon, Bernardi Quadra.
Quoted: 31 Post(s)
Liked 48 Times
I've never seen or ridden a Topstone but I own a Checkpoint ALR4, have had that bike for almost a year now and I absolutely love it, you should try riding both bike or at least analyse their geometries well because, in my opinion frame geometry is the most important thing, figure out which frame suits you better. Components can be changed but the frame geometry ramins the same.
Get the Topstone, better frame than the AL Checkpoint... unless you move up to the ALR Checkpoint.
Bikes: TCX & CAAD3 SAECO
Quoted: 147 Post(s)
Liked 118 Times
I might be wrong, but does the Topstone have more tire clearance? By looking at them the Checkpoint looks more aggressive as well. But that being said I know nothing.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
I get the bike that fits me best.
-if both fit the same, then...-
I get the bike that can fit bigger tires to either use bigger tires or have clearance since both are important.
-if both have the same clearance, then...-
I get the bike that has the nicer frame and better components.
-if both have nice frames and components, then...-
I get the bike that looks better.
-if both are good looking, then...-
I get the bike that costs less.
As some point there is a differentiation, and its usually right at the 1st one since its rare for 2 bikes to fit the same.
Reno/Seattle/NYC
Definitely agree with above, figure out which fits better first, then move down the decision tree from there!
I have the same dilemna
I am stuck between a Topstone Sora or a Checkpoint AL3. The Checkpoint it seems would need new tires but is the bike built better? I wonder what lends to the higher price tag? Is it simply components? I've read that the Checkpoint has "tubeless ready wheels". That intrigues me and I wonder if I should make this a major consideration.
There is a 3rd bike that is coming in as a possible contender, Specialized Diverge E5 Elite. A bit steeper price tag and it seems impossible to find but I wonder if I should be considering this bike as well.
I don't buy bikes very often. I have had a Gary Fisher Kai Tai for the past 12 years and over the years have ridden it quite often. Usually gravel trails or paved trails for 10-20 miles at a time a few times a week for 4 or 5 months of the year. Lately I've been riding more aggressively in regards to maintaining a high constant speed which makes me feel like maybe I need something that is more in the way of a road bike/drop handle bars so I can get in the proper positions. This will be my first new bike purchase since the Kai Tai all those years ago. I just want to be sure that I am buying the right one.
My main takeaway thus far would be to get on all the bikes I am interested in and buy the one that fits and feels best to me. Thanks in advance for any further input. The input so far has been helpful.
Quoted: 1872 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
I'm buying one of them tomorrow. I have a few decisions to make. If I go with the Trek it will be the Black AL3 (size 56) which I'm not a huge fan but local dealer is willing to give me a deal. If I Go with the Topstone I'll go with the Green Sora which I like quite a bit. Only have to decide between a Medium or a large.
Both Bikes have pros and cons
The Trek has more of a road gearing with 50/34 and the Cannondale has 46/30
The Trek comes with Slick 32s (up to 38 stated on the website and the Cannondale comes with 40mm stock
The Trek as better brakes and wheels.
The Trek has mounts for a front rack and the Cannondale only on the back.
I like the saddle of the Cannondale and wouldn't have to change a thing Not a fan of the Trek saddle.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Liked 692 Times
You sure about that? I've seen nothing but the contrary.
example: https://www.cyclingabout.com/2019-ca...touring-bikes/
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 1975 Post(s)
Liked 232 Times
Liked 232 Times
They weren't advertised as tubeless read on my CAADX either and thought I'd have to set them up ghetto tubeless but after pulling the tires off they have a nice shelf and lip to lock the bead and just needed a layer of tape, set up just as easy as my stan's rims on the superx
Liked 232 Times
The stock wheels on my Topstone Sora were not tubeless ready at all. That spot on the hoop where you can see the butt of the 2 ends meet will just seep sealant. I tried everything I could think of, just wouldntw work. Thought I could get em to seal, I've gotten a few sets of older mtb wheels to seal up that weren't tubeless. Made a mess, learned a lesson.
Ended up with new wheels anyways and there were a breeze.
GravelKing 700x35. I originally just used stans tape on the rear, then couldn't get that to seal so I swapped over to Gorilla Tape. That didn't work either, and that's all I've used on 2 of my mountain bikes, 3 coworkers mountain bikes, a dirt jumper for a friend, and the girldfriends Felt f40x.
Thanks!
Liked 692 Times
I've ridden everything from a proper high end steel bike, to a straight up carbon race CX bike, to this alloy Topstone. In every case the smoothness was 100% determined by the tires and the tires pressure. That combo makes up such a large percentage of the overall feel of a bike I can't help but think the "steel is real" and "alloy and carbon are harsh" mantras are bull when it comes to gravel.
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
New carbon Topstones.
Quoted: 31 Post(s)
Liked 48 Times
The Topstone has more tire clearance (42) than the Checkpoint AL (38), but the ALR might have it beat by just a little (45). Neither go super huge. The Topstone was definitely a more relaxed ride than the ALR, at least, which fit a little more aggressively. I don't know how the AL compares.
Likes For MAGAIVER:
Quoted: 8 Post(s)
Liked 10 Times
The stock wheels on my Topstone Sora were not tubeless ready at all. That spot on the hoop where you can see the butt of the 2 ends meet will just seep sealant, and the lip looks stout but sealant was draining from there as well. I tried everything I could think of, just would not work. Thought I could get em to seal; I've gotten a few sets of older mtb wheels to seal up that weren't tubeless. Made a mess, learned a lesson.
