SIDI Heal Replacement Problem
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
So I picked up a pair of SIDI shoes cheap. They're used. The reason they're so cheap, the heals are worn out. I tried to unscrew the Phillips head screw, but it's been worn down some and I can't get a good purchase with any of my Phillips head screw drivers. I know I can't be the only one who's had this issue. So how has anyone gone about getting that screw removed so they can get the old heal off to replace it?
Thanks
Thanks
Roccobike BF Official Thread Terminator
Quoted: 42 Post(s)
Liked 26 Times
Use an EZ-out. It's kind of like a reverse threaded tap. Costs about $8 for a cheap set of them which will be fine for what you need, and takes two seconds to use.
Quoted: 18420 Post(s)
Liked 15,564 Times
Or if you don't have a saw, maybe you can cut/break off the remaining piece of heel protector and get the screw out by using pliers or a vice grips to turn it.
Dremel a slot. The end result will be the same as a hacksaw - just less chance of slotting the carbon/plastic sole from an oversized tool.
Flyin' under the radar
Looks to me like the screw head is packed with dirt. Take something sharp and pointy and scrape all that crap out. Then try a #1, #2, and #3 phillips head to see which gives you the best purchase after you've gotten all the crap out of there.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Bikes: Independent Fabrications, Raleigh Glider
I've had this problem regularly. To date, I've had success taking a knife to the remainder of the heel around the screw and slowly cutting it away from the screw head. That's the solution suggested by indyfabz above (#4). It's quite an effort but once enough has been removed I can get a grip on the screw head with some pliers. A small turn to unfreeze the screw is usually enough that a screwdriver can then be used.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
That's what I do. And the one or two times it didn't work, I brought it to my LBS and they were able to do it successfully in less than 30 seconds.
For the first try pick out all the dirt, then place the screwdriver and give it a whack with a hammer. It will seat better and loosen the screw. On cleats save the worst for last and then rotate the whole cleat. Use a fresh bit not some old worn out screwdriver.
This one goes to 11
Bikes: Scott Solace 30, Kona Sutra, Jamis Beatnik, Dahon folder
Quoted: 5 Post(s)
