What is the "official" name of this:
This kind of setup is normally known as "worm gear clamp", "worm drive clamp" or "worm screw clamp". So, the screw itself can be referred to as worm screw (when used in this role specifically)
Quoted: 1944 Post(s)
Liked 2,164 Times
Incomplete.
John
John
Its a very close up picture of a machine screw with No Context.
So how big is it? use standard dimension numbers..
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
Then it's a worm gear, like a worm gear hose clamp.
Stuart Black
Stuart Black
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
You're looking for a "headless screw" or "grub screw", as commonly used in a worm gear.
Take the part(s) you have to a hardware store with a good fastener selection. Even if the store doesn't have a headless screw like the one you need, they'll have other screws and nuts you can use to determine the nominal diameter and thread pitch. With those numbers, you can possibly find a supplier online if the store can't get you the item.
Or if you need something ASAP and can't wait for an order, buy a bolt with the right diameter and thread pitch. Cut it to length and use a file or Dremel to cut a slot in the end so you can use a straight edge screwdriver to turn it.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
I would be surprised if you found that to be some standard pitch threading. It would be pitched to match the grooves in the clamp.
Lotus907efi
Bicycle Mechanics
4
05-20-19 05:42 AM
cajunpedaler
Bicycle Mechanics
11
12-01-14 06:09 PM
