Crack or Scratch?
Crack or Scratch?
Old 06-29-20, 08:06 AM
shanlon
Liked 4 Times in 1 Post
Crack or Scratch?
I just picked up a clean Vintage TA Cyclotouriste crankset on EBay, but after polishing discovered what appears to be cracks on the non-drive-side arm near the top of the arm. Are these cracks or cosmetic scratches?
shanlon is offline
Old 06-29-20, 08:29 AM
Eggman84
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times in 35 Posts
Not sure what to see in the 1st photo so no opinion on it. The 2nd photo, my opinion is it is a scratch stretching left to right. The reason I say that is at the left end, it appears that a two "features" on the left merge at a very shallow angle, which I interpret as a short scratch merging into a longer scratch. But if you think they are cracks I would not suggest not using it; from what I hear a breaking a crankarm can lead to a serious crash. You could try to find a lab that can do an ultrasonic inspection to see if it is a crack.
Eggman84 is offline
Old 06-29-20, 08:44 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
Agree the first photo tells us nothing but that "scratch" shown in the second photo appears to indeed be a scratch. However, it's deep enough and in a high stress location that I would worry about it being a "stress raiser" and could lead to a real crack and failure. I personally wouldn't use that crank.
HillRider is offline
Old 06-29-20, 09:10 AM
shanlon
Thanks, guys. I appreciate the educated guesses. I will do some further inspection, and perhaps an ultrasound as you suggested.
shanlon is offline
Old 06-29-20, 10:05 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Surface scratches can be filed/sanded/polished out to remove the stress risers. This is commonly done on airplane propellers to restore nicked and dinged surfaces to airworthiness. Information you may find useful starts on page 23 of this Advisory Circular: https://www.faa.gov/documentlibrary/.../ac_20-37e.pdf
dsbrantjr is offline
Likes For dsbrantjr:
Old 06-29-20, 11:13 AM
shanlon
Thanks for the tip. I might try to have it buffed out.
shanlon is offline
Old 06-29-20, 12:02 PM
krecik
Quoted: 137 Post(s)
Liked 86 Times in 54 Posts
krecik is offline
Likes For krecik:
Old 06-29-20, 02:07 PM
FiftySix
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times in 795 Posts
Looks like a deep scratch to me, too.
FiftySix is offline
Likes For FiftySix:
Old 06-29-20, 06:47 PM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
I'd call that a gouge rather than a scratch. To use that unit, I'd definitely sand/file/grind it out so that it has a gradual taper to the main part of the unit. Take a piece of wood about the same size and try breaking it. Now put a deep gouge/scratch like that in the same area of the piece of wood and try breaking it. You'll most likely be able to break that piece of wood fairily easily and the break will happen on or close to where the gouge/scratch is. that's why it's called a stress riser; it concentrates stresses to that locale.
Cheers
Miele Man is offline
Likes For Miele Man:
Old 06-29-20, 06:51 PM
shanlon
Thanks for the recommendation. This seems to be the course of action that I need to take if I want it to retain its integrity.
shanlon is offline
Old 06-29-20, 07:09 PM
Miele Man
You want the change from the bottom of that gouge/scratch to the top surface of the item to be as gradual as you can make it. It'll be less noticeable as well as stronger that way too.
Cheers
Old 06-29-20, 07:13 PM
shanlon
Cheers
Thank you. I will definitely do this, as I don’t want it to be at all noticeable.
shanlon is offline
Old 07-01-20, 10:01 AM
Steelman54
Bikes: Allegro Model 77, Gitane Team Pro SLX, Waterford R2200
Quoted: 68 Post(s)
Liked 57 Times in 38 Posts
Cracks are not that straight, so like others have said, scratch or maybe better term gouge?
Steelman54 is offline
Old 07-01-20, 02:29 PM
GamblerGORD53
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times in 248 Posts
It's a gouge. Anyway we need a better pic of the whole part. I thought it was a dented rim looking at the pic. LOL
Is it CF ?? WTH.
I would DEMAND my money back from the bugger that sold it.
GamblerGORD53 is offline
Likes For GamblerGORD53:
Old 07-01-20, 06:12 PM
shanlon
Thanks, GamblerGORD53. It’s a TA Cyclotouriste crankset. I got it for a song on EBay, so I’m not complaining.
shanlon is offline
Old 07-02-20, 06:15 PM
quindecima
Bikes: Flex, Volkscycle MarkX
Quoted: 26 Post(s)
Liked 12 Times in 5 Posts
Why not have it Tig welded********************?
quindecima is offline
Likes For quindecima:
Old 07-02-20, 06:23 PM
shanlon
i want the bike to look brand new. It’s about pure aesthetics.
shanlon is offline
Old 07-02-20, 06:26 PM
quindecima
Quoted: 26 Post(s)
You could have that Tig welded and polished out and NOBODY would know.
Old 07-02-20, 06:27 PM
shanlon
Oh, and I forgot the most important part: it’s a scratch, not a crack.
shanlon is offline
Old 07-02-20, 06:29 PM
quindecima
Quoted: 26 Post(s)
Doesn't make any difference, a good tig welder could clamp that up and make a quick pass over it and be done. I haven't tig welded in years but I know I could do it.
Old 07-02-20, 09:32 PM
AndreyT
AndreyT's Avatar
Quoted: 244 Post(s)
Liked 55 Times in 30 Posts
There's no size/scale reference in these photographs. Is this molecular, atomic or subatomic level?
AndreyT is offline
Old 07-03-20, 09:11 AM
FiftySix
I'm the anecdote.
I'm guessing on the width of the crank arm in the bottom photo that the scratch/gouge is not over 1mm wide.
FiftySix is offline
